Question about Briggs & Stratton Garden
WONT START WITH KEY BUT WILL WITH JUMP
I HAVE A MURRAY 16 HORSE RIDING MOWER AND IT WILL NOT STAR WITH KEY BUT WILL WITH A JUMP START
  • Samuel Charles Spriggs May 11, 2010
    When you jump start it are you using the key/switch to crank it?
  • 376 Answers
Check the inline fuse first. If good, disconnect the small wire plugged into the bottom of the solenoid and hook a test light to it. Lock the clutch/brake pedal down and turn the key to start. If it lights up, replace the solenoid.
Posted on May 29, 2009
Why mower wont jump of
Positive to positive and negative to negative. Be sure mower lever in off position and setting in the seat to activate operator presence switch. Key switch on.
Jan 05, 2017 | Murray Garden
Why murray riding mower wont crank when being jumped off
Some mowers have safety switches that unless you are sitting on the seat and the clutch pushed in they will not start. Not sure if this is the answer.
Why will it start only if I connect a wire from batt to R,H,S,of solenoid?
What you are doing is jump starting the engine Look for a problem with the key switch or wires to the solenoid from the key Also check for voltage at the key
Jun 13, 2015 | Murray Garden
I need a Murray riding mower electrical wiring diagram?
need to no if wont turn engine over
Sep 03, 2014 | Garden
Murray owners maual book 12.5 hp
mower was giving to me ,have not idea what the moder no is . i was told that its 1980 12 horse with 32" cut murray riding mower
Jun 07, 2013 | Murray Garden
I have a 14.5 hp murray riding mower i tightend the valves and now mower wont start
Steven, I think you have diagnosed your own problem. Check the specs you used to set the valve clearance. If you don't have any specs, set them both to .020" and it should run fine. Be sure that you set both valves just about 15-30 degrees before TDC on the compression cycle. (both valves closed)
junkl
Dec 16, 2012 | Murray Garden
Need diagram to replace murray 42 inch cut belt
http://www.ereplacementparts.com/ type in model number of your mower ie 40560x50c All parts and diags ypu need ,Yours Henry
Aug 07, 2010 | Murray 38 Lawn Mower Blade Belt '90'96...
I am looking for a belt placement diagram for a 42" murray riding mower-drive belt.
Use your model number & go online for Murray Riding Lawnmower & search. Most of the time you will find it. If not reply back with model numner & HP (horse power)
Aug 03, 2010 | Garden
Riding mower won't start from key switch
Do you have power to the switch? This is the only thing that jumps out at me, as you already did the right things.
Check that. I bet it'll get you going!
Regards, --W/D-- Feel free to rate my answer.
Jul 24, 2009 | Champion International Champion& Small...
Murray Riding Motor Running but not Starting
does it have spark & gas let me know at wadembly@aol.com thanks,wade
Jun 07, 2009 | Garden
Garden Logo
228 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
