Question about Genius GM56PCI-L (FM9648001) Modem
Is the modem needs driver update
I am using Winfax to send fax out but fail due to "no dail tone" . I been connected Winfax with 'Genius"- Smart usb56k modem successfully. Is it fail due to outdate modem driver? if yes, Can you send me the latest modem driver?
  • 3,600 Answers
The win modems were junk and were software modems and worked about half the time, but if your modem says no dial tone then you need to try a new phone cord check that the phone cord is firmly pushed into the slot, if the wire fell out make sure the tiny wires are not bent on the phone card, so if you replace the old phone cord that will test that theory if it still does not work then try your modem setup, do you have the modem set faster than 9800 baud rate if so it won't work but would still not cause no dial tone. Also is the modem securely in it's slot? if it still does not work go to a command prompt and type ata and hit enter does the modem respond ok? if not you need to open control panel remove the modem and try reinstalling the software drivers hope this helps and good luck, if you buy a new modem buy a hardware modem, they are more expensive but are much more reliable.
Posted on May 29, 2009
    President:
  • 1,314 Answers
Usually the no dial tone error is not a driver problem but rather a problem with the modem itself. Modems are really finicky and even the slightest surge through the phone cord from an electrical storm can cause the modem not to get a dial tone. You will need to replace your modem and that will solve the issue.
I have a BSNL boardband connection, can you tell me how can I configured?
The internet connection that you use doesn't matter with WinFax, since WinFax requires a fax modem to send and receive faxes. You cannotuse your broadband modem to send receive faxes with WinFax PRO. http://www.getfaxing.com/forums
Dec 10, 2010 | Symantec WinFax Pro 10.0 for PC
I HAVE A SHARP UX-105 HOW DO I CONNECT TO COMPUTER; NO MAUNAL BOOK?
install winfax program on your pc.then when you want to print with your fax,inprint menu choose winfax,and then you can print .
Jun 07, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
MY WINFAX IS NOT CONNECTING TO SEND. THE LINE WORKS, I HEAR THE TONE DIALER DIALING, THEN THERE IS A LONG PAUSE WHILE "CONNECTING" MESSAGE APPEARS. THEN BRIEFLY THE MESSAGE DISPLAYS "NO CARRIER" AND CLOSES...
This is usually a line connection, or dialing problem. Are you sure the fax modem is connected to a working telephone line? are you sure your sending to a fax machine? Do you require any prefix (like a 9) to make an outgoing call? Are you dialing all the proper digits to make a call?
http://www.getfaxing.com/winfax
Feb 28, 2010 | Symantec WinFax Pro for PC
Winfax Basic
If you have the fax # correct, than it is the responsibility of the fax recipient to correct the situation. You cannot make a parametrical changes to someone elses fax machine. Thank you, Dana
Jan 18, 2010 | Symantec WinFax Pro for PC
I give up. I have winfax software on this machine, but I am new at the job. Please can you help me link my fax to the winfax software? I am not able to send faxes as I think you actually have to be...
You need to setup a fax modem to be able to send and receive faxes with WinFax.
In WinFax, click on Tools, Setup.
Click on Modems & Communications Devices.
Here you can configure your fax device.
You need a fax modem, a DSL modem or a cable modem is not a fax modem.
I suggest you read this:
http://www.getfaxing.com/winfax/2009/06/25/first-time-guide-to-winfax-pro/
Jun 29, 2009 | Symantec Computers & Internet
No Dial tone using Symantec Winfax Pro 10 on Windows 98
Check the physical connection of the phone line to the computer make sure that it is connected to phone line symbol of the Ethernet adapter. Then make sure that the driver of the adapter is installed properly on the computer or you can try to scan the hardware first before the re-installation of the driver using the adapter.
May 26, 2009 | Conexant chipset 56K V.92 PCI Data/Fax...
Slow Fax Transmissions with USR V92 External fax modem
Its possible you've set your faxes to send in FINE resolution (200 dpi), I am not sure about MS Fax, but in WinFax you can select both Standard Resolution and Fine resolution as the default for sending faxes.
Jan 14, 2009 | 3Com U.S. Robotics Faxmodem 56K
Configuratin of Winfax pro
You need a fax modem. If you only have internet connection, you will not be able to send or receive faxes unless you subscribe to an internet fax service called www concordfax.com
Jan 12, 2009 | Symantec Winfax Pro 10.03 (winfax10.03)...
I can't send to certain fax machines with WinFax Pro
Yes, some modems might have problems with Service Pack 3. You might need to update the Windows modem drivers.
Alternatively, there might be problems with the settings in WinFax for your specific modem.
You'll need to post more information on the fax modem you are using.
Jul 28, 2008 | Symantec WinFax Pro for PC
No dail tone report
some dial connections dont like the filters attached. does the new modem have more then one ethernet connection on it? have u tried it on another connection if u have on in the house? it may just be your settings in the computer. are you using the same computer for both broadband and dial up? if you are then you may need to adjust the settings in your computer, your isp should have done all that for you.
Nov 29, 2007 | Computers & Internet
Genius GM56PCI-L (FM9648001) Modem Logo
367 people viewed this question
Top Genius Computers & Internet Experts
micky dee
Alun Cox
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
