Question about Whirlpool GB2SHKXL Bottom Freezer Refrigerator
The freezer will not cool adequately and the freezer ices up.
I purchased this applaince 4 days ago.
  • 3,267 Answers
Check the amount of cooling gas and since under warrant, immediately report to the Dealer/distributor & it will be free of cost........sodeep
Posted on May 29, 2009
2002 GE Artica Fridge stoppped cooling and freezing.
Hi monica ,
the heating element in your freezer might be bad or the thermostat. that is way your freezer is not melting the ice inside and the noise that you hear it's the fan that prob' tuch ice or also is getting bad.
let me know if you need more help...
Jan 08, 2010 | Refrigerators
MSD2656GEQ The coils on the freezer side ices up, then does not cool the refridgerator side
Hi, It's a common problem with no-frost refrigerators, you have a defrost problems, two scenarios. (1) hot air entering freezer/refrigerator, examples. hot summer days, regular openings, high room temperatures, hot foods and broken door gasket, leaving freezer/refrigerator doors slightly open overnight, could cause your evaporator (coils) to freeze/ice up. cases like this, unplug/disconnect your refrigerator, remove produce, clean and let it defrost, for an hour, make sure all ice melted. plug or reconnect your refrigerator let it work/ run empty for another hour, then put back your produce. sure it will work perfect for the next 3-4 days. (2) next type of defrost problem could be faulty defrost heater, defrost thermostat, you will have to open back panel on freezer side to check. check your defrost heaters, defrost thermostat and defrost timer, it's better to change defrost timer and defrost thermostat together, or change faulty ones independently. but before you change any parts, clean and defrost refrigerator first, could just be regular openings, hot days, etc. if after 3-4 days it started to ice up, then check following parts. defrost heater. defrost thermostat and defrost timer, let me know if icing occurs after 3-4 days then we can check those parts i suggested. remember to always disconnect/unplug your refrigerator, before attempting any repairs. good luck
Aug 21, 2009 | Maytag MSD2656G Side by Side Refrigerator
Fridge not staying cool, freezer still freezing
Try defrosting freezer, sometimes when the defrost thermostat fails it causes ice too build up behind the walls of the freezer then it restricts the air flow to the refer side. If it works after defrosting then you probably need to get a new defrost thermostat.
Mar 14, 2009 | Maytag MBB1956GES Bottom Freezer...
Refrigerator not cooling--has thawed/ but top freezer is cooling
Their is a fan that blows the cold air from the freezer to the refrigerator section, on some models. If thsi fan is  frozen or bad what you havwe discribed wil bew the result.
Nov 26, 2008 | Whirlpool Refrigerators
Regrigerator stopped, now freezer too.
It is due to the defrost timer is not working. Once it is replaced, you should be good for another year. The information is given by the repairman. I have this replaced two days ago. The MayTag part number is: 61005988.
Aug 07, 2008 | Jenn-Air JSD2789GES Side by Side...
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
We have a Whirlpool gb22dk refrigerator freezer. The bottom freezer keeps meat frozen but will not keep sea food ice cream bread ect frozen. This fridge came with our house which we purchased 2 years ago...
1st.Check the freezer door gasket for any place it maybe torn or not making a 100% seal when you close the door.That would make temperature drop. 2nd.take off bottom kick plate so you can look under the refrigerator.Using a flashlight make sure there is not alot of lint / dust stuck on the coils .If there is remove it carefully and you will see temperature lower. PLEAS RATE THIS!
Jun 09, 2008 | Whirlpool Refrigerators
Amana double door freezer side is not working
you can visit the local applaince dealer. frost on onle the top few coils is an indcation of a low charge, restriction of freon, or inneffceint compressor, after 10 years wouldnt image that would be a worth while repair, way expensive here where i am lookna t 500 or so.
Mar 16, 2008 | Refrigerators
Whirlpool GB2SHKXL Bottom Freezer Refrigerator Logo
95 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
