Question about Amana ARS2464B Side by Side Refrigerator
My fridge is working constantly it stops only when i select zero at the thermostat switch
My fridge does not stop working unless i select zero on the thermostat control
  • 21 Answers
Sounds like the cold control is bad.Does the fridge work ok otherwise?The cold control is what you are having to turn to 0,and are usually set at midrange.0 to 9,set at 4.The control has a temperature sensitive tube that opens or closes the contacts in the control,and they do go bad.This is where I would start.You can get a replacement control at an appliance shop.Get the model and seriel number of the fridge located usually inside of fridge on a tag on the inside wall.Use these numbers to get the part.Hope this helps. Gregg
Posted on May 29, 2009
  • greggwright1 May 29, 2009
    Why inappropriate?
I have a kenmore bottom freezer refrigerator model # 795.78304.804 bout 10are11years old just stopped working nothing will come on . checked power at box and it's good
main switch/thermostat control inside of fridge needs replacing...to prove...tap/bump switch a couple of times and you should hear fridge power up...if so replace switch/thermostat...
Oct 16, 2016 | Kenmore Refrigerators
I have a westinghouse frdge freezer bj 385 motor constantly running with the door close motor stops intermidently open door motor stops recently moved fridge
Hi Peter, It it's not freezing the fridge up then it needs regassing but it it's freezing the fridge up then could be the thermostat, Good luck mate..... CHEERS..
Apr 04, 2016 | Westinghouse Refrigerators
Ok, not knowing the model# I guess freezer bottom and fridge top?
Well somewhere in the middle there should be a fan and a thermostatic flap, opening to force cold air to the top. If that does not work to cool the top portion, and since the thermostat is located in this portion, the thermostat will never reach a stop temperature and it will keep running. Best I can do with info received, if you locate such flap, check for free movement, many things can stop it from moving, such as ice build up. If ice build up also check defrost timer as culprit.
Hope this helps.
Jan 29, 2014 | Kenmore Refrigerators
Fridge works intermittently
Some Of These Fridge Freezers If You Open The Door For The Freezer There Is A Switch Between The Fridge And Freezer Door Mine Done The Same And I Had To Replace That Switch It Turns The Fan On When Door Is Closed And Off When Open
Nov 04, 2013 | Refrigerators
Sub Zero dripping noise from freezer when cycles off
Is this noise periodically or every time the fridge cycles off? Does it sound like water dripping on a hot surface?
Sub Zero Repair Tucson
Dec 05, 2012 | Sub-Zero 650 / O Bottom Freezer...
The alarm goes off by itself and the fridge will stop working. switch it off for two to three days and it work again for few days
switch fridge off and defrost it 24hrs. inside fridge remove panel and locate the flap on the thermostat. put something behind it to jar it open about half inch. restart fridge and see if it cures problem. if it does fridge thermostat requires replacing. jaring the flap open is only a temporary fix to diagnose problem. but i did mine 4 months ago and still fine
Aug 05, 2010 | Zanussi ZX97 / 5 Bottom Freezer...
Cools but constantly runs
you hit the nail on the head there,,,its the thermostat its dead!
change it they often stick in the on poshion when they stop working to save any food inside of the fridge
Jul 12, 2010 | Haier HSB03 Compact Refrigerator
Zanussi fridge freezer wont stop making a whirring noise
Sounds like the unit is goosed and is trying none stop to get the temperature down in the fridge.
That is of course unless the ice is building up like an iceberg inside the cabinet in which case the thermostat has gone
Dec 06, 2009 | Freezers
Hello. We moved into a house a year ago that had a sub-zero fridge/freezer. When we go on vacation, the freezer unit sometimes shuts off (from not being used??). To get it working again, we have to turn...
It sounds like it may be the thermostat. turn it down to a normal level and give it a good tap to see if it starts. you may need to leave the door open so it warms up bit so it will start, it wont start if its cold as the thermostat would be satisfied. If it does start the thermostat should be replaced. I hope this helps
Apr 18, 2009 | Sub-Zero Bottom Freezer Refrigerator
Amana ARS2464B Side by Side Refrigerator Logo
200 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
