Question about Kensington Electronics - Others
I cant open it
I have a problame in my kingston 8gb pen drive.i conect the device my computer show me the pen.but i cant open it or do any other things.allways see error massage the massage is (insert disk to drive i,h)i connect the pen my all usb ports and other computers.but allways see that massage
  • Kensington Master
  • 27,725 Answers
W 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if you need more help with this or if i have missed the problem post a reply
Posted on Mar 01, 2013
pankaj_dic
  • 1252 Answers
SOURCE: My DT100/4gb data traveller (kingston) pen drive is not working.
check the status of your drive on some others system , if the problem remains the same , replace it
Posted on Nov 03, 2008
philmik
  • 107 Answers
SOURCE: 8gb pny pendrive not working
Try to connect it to another usb . If it still does not see it do check disk with fix errors. I had such a problem many times and usually check disk helps.
Posted on Apr 18, 2009
SOURCE: transcend 4gb pendrive gets detected bt says inserd disk
my pen drive Please insert a disk into drive problem
Posted on Jun 21, 2009
SOURCE: pen drive is showing o bytes
ple hielp me my email id is mannapur2000@gmail.com
Posted on Oct 05, 2009
softwareguru
  • 78 Answers
SOURCE: 8gb Transcend Pen-drive is not getting detected
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
Posted on Jan 03, 2010
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
When connect my pen drive ( kingstone 8GB G2) it can connect.....it showed on my task bar........and when i open drive of it in my computer it say "please insert a disk into drive H: "...
the computer may have recognized the device as a card reader instead of a thumb drive, try inserting it into a different usb port. And if that doesn't work ,back up the files on the drive and try reformatting the drive.
Jun 17, 2011 | Computers & Internet
Dear Sir/Medam My Pen drive Not opened and Not formeting How to open my pen drive. plese tell me. this problam cont. two months abow.
plug it in to a USB slot open windows explorer (my documents) my computer you will see your pen drive right click select opehope this helps
Sep 15, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Pen drive issue
Try a totally independant PC away from the ones you tried....if no go drive has failed and data will be lost sorry.
Jan 07, 2010 | Kingston (SDCZ2-512-A10-KT)...
Kingston 8gb pen drive problem
format the pendrive...need to remove virus
Dec 08, 2009 | Kingston Technologies 512MB DataTraveler I...
Pen drive not opening or formatting
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jul 10, 2009 | Pen Drive IVO MP3 Player
Cant open cant formate my flash
hmmm....hello friends...your pen drive is corrupted...its better to change this pen drive because kingston pen drive is in 5 yr warrenty period... so dont wrry and change it.....or you can try this pen drive to any other computer ...if behaviour is same then i would request to you , change pendrive as soon as possible
Apr 25, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Cannot reformat my USB 4gb kingston
the reason is ur pen drive has lost its capacity to store datas. u cant use that pen drive anymore and it cannot be formatted also. try for a new pen drive
Jan 18, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Electronics - Others Logo
59 people viewed this question
Top Kensington Electronics - Others Experts
Are you a Kensington Electronics - Other Expert? Answer questions, earn points and help others
