Question about Olympus Stylus 770 SW Digital Camera
Yep. another lens stuck.
Hey. i've had my 770SW for a while now. today at the beach. the lens became stuck open. it appears to be loose, with a bump on either corner the lens can be knocked a couple of mm from the fully extracted position.. when turned on i can view my photos but i receive a black screen if i try to take a photo. an audible noise is heard from the lens trying to retract. is this a problem i can fix myself?
  • 1 more comment
  • Anonymous Feb 13, 2008
    my camera's lens got
    My camera's lens got stuck open. I can only review pics that was taken. When i use it for taking pictures, the screen is blank aside from the print that says D : 5f08 8234.
  • Anonymous Mar 14, 2008
    Used the 770 in a swimming pool and then two days later lens cover is stuck open and camera will no longer take pictures, it is about 8 months old. only went down about 5 feet!!! now looking to fix it, any suggestions please.
I used my camera at the beach and now the lens doesn't close. he camera still turns on. I didn't think you had to clean the camera if it's a water proof camera. SO need help what to et fixed for my husband it was a very expensive camera.
Posted on Jul 17, 2011
I had this problem after putting it in a jug of bear (i know, i know...not so smart)...i washed the camera with a small amount of dishwashing detergent and a good rinse and it seemed to solve the problem for me....not sure if this is the recommended way of dealing with it though.
Posted on Oct 27, 2007
My 2007 mitsabishi triton A/T gear shift is stuck in drive.I believe it could be a solenoid.It happened after driving on the beach. Cheers
Are you sure it's not just the linkage jammed up with sand? If it is internal, drop the pan and you should be able to see if a solenoid has broken, as they usually come loose from the base. Good time to change filter and fluid too.
Jan 15, 2015 | Cars & Trucks
The camera starts up and shows the blue sanyo screen. Then the screen turns black then shuts off. The lens doesn't even open. I've tried charging the battery and that is not the problem. What's...
Hello ..Yes please make sure your batteries are fully charged..If battery is charged and still shuts down..There is a good chance lens was hit or bumped.When lenses are bumped the camera will try to extend lens upon power up as part of cycle.If camera detect problem with lens not opening..Then it will shut down...
Sep 23, 2011 | Cameras
The lens cover on my olympus stylus 770sw is stuck open and the camera will not turn on.
I have a u770 with a broken lens. I would like to either buy yours to repair mine or I am willing to sell mine so you can repair yours. Email at (g4)(kpp)@(hotmail).(com) - remove the brackets - trying to avoid spam
Oct 17, 2009 | Olympus Stylus 770 SW Digital Camera
770SW Olympus needs a factory reset, lens stuck open
Contact Olympus for the factory reset code.
Sep 01, 2017 | Cameras
L730 wont turn on, lens stuck half way
Hi, Lens is jammed, lens motor gearbox requires restting. If you in the U.K I can help you out.
p.m me at kiddo242@hotmail.com
Aug 09, 2009 | Samsung Digimax L730 Digital Camera
Nikon Coolpix S550 Lens Error.. Need fix without spending
No, even if you could find a lens for free this is not an easy camera to replace the lens on. Even a qualified tech would take up to an hour to replace. Understand that today's cameras low cost makes replacing the camera a better option than repairing a camera who's value used is less than the repair cost.
Jul 03, 2009 | Nikon Coolpix P1 Digital Camera
it depends on what the problem acctually is. In my experience with cammeras such as these, a problem of this nature is not worth the trouble, but if you really like the cammera then take the covers off by removing the screws around the cammera body. Start by removing the back peace. you wont need to remove the door for the batteries or the two screws around the mount on the bottom of the cammera that hold the screw tripod mount in place. once you remove the backing you will expose at least one more screw on the side that holds the front cover on. you will want to very carefully remove the wires for the backing by pulling back the ribbon cable retainer clip and the ribon cable retainer clip must be pulled back carefully for the shutter switch as well when removing the front pannel of the cammera. Unplug the yellow wire for the micro switch in the front if applicable and then you will have exposed the lense. remove the screws holding the lense assembly in and then look around at the operation. THERE IS A CAPACITOR IN THE FRONT OF THE CAMMERA THAT WILL SHOCK YOU!!! DO NOT TOUCH THE BOARD. I've been shocked by the thing at least 3 times today so dont get all hasty. you will probably notice one of the gears are stuck or something you can buy a new lense assembly and install it but it is probably just as much as the cammera. I would sugges trying to repair it or if it is too damaged throw it away. It depends on what you find. you can look up small gears on line but it also may just need to be set back in or cleaned. You may also want to replace the cammera battery while you are in there. When removing the back pannel start from the bottom of the cammera and slightly hinge up and pull the backing away genly as to not snap the retainers in the upper part of the cammera or yank out the ribbon cable. REMOVE THE BATTERY BEFORE YOU BEGING. WITH THE BATTER REMOVED THE CAPACITOR WILL STILL SHOCK YOU. be careful.
Aug 16, 2008 | Olympus Camedia C-4000 Zoom Digital Camera
NIKON L15 LENS ERROR
Lens errors, must be fixed by a camera repair shop. They are usually caused by impact of the lens with an object or sand from a beach. Repair estimates range from $50 to $100. Get a new camera if it is closer to $100. Suggest a internal zoom lens like the Fuji Z10fd.
Mar 19, 2008 | Nikon Coolpix P1 Digital Camera
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Lens cover is stuck
I did the same repair...however, I found that those little wheels are completely optional. All they do is keep the lens cover from prying away from the camera, but if you're careful, the lens cover will work without them.
Sep 07, 2006 | Canon PowerShot S45 Digital Camera
Olympus Stylus 770 SW Digital Camera Logo
214 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
