Question about Compaq Armada M700 Notebook
Battery not charging
Product: Compaq armada m700
    Novelist:
  • 166 Answers
Company is replacing all such batteries. Its a manufacture defect found in your series laptops and Lenevo laptops. So don't panic and just consult compaq customer support for replacement.
Rate this solution if it was helpful to you.
With Regards,
Shyny
Posted on May 29, 2009
My laptop is compaq Armada M700 with Windows XP Professional version 2002, how will i know if my battery is already fully charged? i have been charging it for a day and when I disconnect the charger tha...
From your description it seems the battery hasn't been charged right, so there maybe something wrong with the battery or laptop. First, do a clean to the your Compaq Armada M700 battery and the connection chip on your laptop, then to see if there is something get better. When you charge you laptop, there will be a lights to note the state, do you have noticed? Else if your Compaq laptop battery are used for 2 years please try a new one
Aug 25, 2011 | Compaq Armada M700 Notebook
How will I know if my laptop Compaq Armada m700 is fully charged already?
Hi
You do not say which operating system you are using.
Right click on the toolbar at the bottom of the screen > properties > notification area > tick the Power under System Icons - Select Which Items to always show > Apply > OK > float the mouse on the battery icon to see % of charge and charge time remaining.
I hope this helps.
Aug 24, 2011 | Compaq Armada M700 Notebook
My Compaq M700 Armada , causing charging problem it run perfectly on direct supply from adapter but it do not charge battery. but was working perfectly few day ago....
hello,
Try removing battery and then re inserting. This can usually be done pretty simply by sliding lock to one side and the pulling battery out. This is under the laptop.
Hope this helps
Jan 08, 2011 | Compaq Armada M700 Notebook
Battery
Check New laptop battery, it is a worldwide retailer and wholesaler who provides all kinds of batteries(include Compaq Armada M700 batteries) and adapters for laptop.
Jul 08, 2008 | Compaq Armada M700 Notebook
Compaq Armada M700
Try this: Remove the power adapter and battery from the laptop.
Press and hold the power button for up to one minute to discharge the laptop. Try starting it.
Jun 02, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
Battery for Compac Armada M700
Hello Felcen:
It could be just a coincidence...but lets try a few things...
Remove the battery and unplug from the wall. Hold the power button on...and then plug back into power...after 8 seconds release the power button. Once your computer boots to desktop...shut down...and replace the battery.
Changing the harddrive should have anything to do with teh battery...
See if your battery starts charging after this trick.
Let me know and good luck my friend.
Seek PC Repair
Feb 12, 2008 | Compaq Armada M700 Notebook
Compaq Armada M700 Shut Off During Windows XP Pro boot
remove the battery and directly connect to power and see.
Oct 09, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700
Always start with the simplest solution first so start by cleaning all the contacts, AC adapter laptop plug, laptop socket, laptop battery contacts and battery contacts. How have you confirmed power output from the AC adapter? have you used a voltmeter to ensure you are getting power at the laptop end? Have you used a voltmeter to test the battery? Assuming you have tried all this don't forget that almost any component can interrupt power on some laptops, however you're 2 main culprits with this kind of problem are usually power controller (voltage regulator) and in some cases, on a laptop of this vintage, the charge controller built in to the battery. Try it with a different battery if you have one.
Aug 10, 2007 | Compaq Armada M700 Notebook
Compaq armada m700 power failur...
try removing the large battery and powering off wall supply only...if ok, then replace battery
May 30, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
159 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
