Question about Motorola Mobility RAZR V3m Cellular Phone
Lg code, need a 4 digit code 2 format the sd card in my phone my phone wont log on my of the applications everytime i click any button it opens the calender nothing else
I need a 4 digit code 2 format the sd card in my phone my phone wont log on my of the applications everytime i click any button it opens the calender nothing else
  • 57 Answers
The Default code is "0000"
but it could also be
1111
2222
3333
4444
5555
6666
7777
8888
9999
or lastly it could be the last four digits of your phone number but its most likely "0000"
Posted on May 29, 2009
Keeps saying low storage need to do an update on phone as i havent anything stored opn it an i have 4gb sd card
It seems all your applications are stored in the Phone Memory and/or your application data is taking up lot of memory. Consider performing the following steps:
  1. Go to Settings --> Applications --> Manage Applications. In this Menu you'll be shown a list of applications. Use the Menu Button to "Sort by Size" and get a list of the applications sorted from high memory usage to low (phone memory). Once this is done, you'll be able to view the memory being used by each of the applications. Click on the applications which you see are consuming more memory and then use the "Clear Data" button to clean up the data being stored by the applications to free up memory. This clears up any cache, cookie, temp files associated with the applications. Depending on your android version, you may also see an additional button "Move to SD Card". The best option to get more space would be to use this button and move the application to the 4 GB SD Card storage.
  2. Optional Step if you do not have "Move to Phone/SD Card" option available - From the Android Market, download and install "App 2 SD Free". Once done, this application should help you free up a lot of space by moving applications from your phone memory to the SD card.
Hope this was helpful. If so, please consider rating this solution.
-thanks,
M
Mar 08, 2011 | HTC Desire Cell Phone
My new SD card can not be read by digital camera
Hello, try using a card reader and plug your new SD card to your pc, it will appear as a removable drive. If it is detected by your pc, try to reformat it by doing this:
1. Click Start/Windows Button on the lower left of your screen, select Computer 2. A window will open, listing all the storage devices in your computer (Local Disk C:, etc) 3. Look for the removable drive, that is your SD Card. Then right-click on it, go to Format. It will format your SD card. 4. After formatting, remove your SD card from your computer then test it using your digital camera.
If it still doesn't work even with other cameras, it might be a defective SD card, try contacting the store where you bought it and have it replaced.
Nov 18, 2010 | Computers & Internet
My n70 phone is continuously sending a message that is not even in my outbox.. i can only see it in my logs.. it keeps on resending the same message to a number which is 339600396.. right now id have to...
Try formatting then entire phone, This is due to virus..
To Format the phone
1)Switch off the phone
2)Hold 3,* and Green button simultaneously
3)Now press the power button holding the 3 button, After 5 seconds leave the 3 buttons
4)You phnoe should say, formatting and all your data would be reset to factory orginal
CAUTION: You will loose all the data and contacts stored in phone memory, But this is the only way
Please rate this solution
RNJ VINODKUMAR
Nov 09, 2009 | Nokia N70 Cellular Phone
Pny micro sd memory card
Make sure you did not buy a micr s/d card for camera only....this could be the problem. you will need a s/d card for cellphones and pc.
May 29, 2009 | LG CHOCOLATE VX8500 Cellular Phone
LG KC550 PC Suite Problem
I speant Hours swearing at my phone because it would not read my music files, Tried the card on many different phones which would take Micro SD and all other phones read the music Just not the LG KC550.
I found that getting a Micro SD dongle reader, Insterting your 2GB Micro sd card in that and then putting your music files into the "sounds" folder works.
Instructions.
1. Insert Micro SD card into Card reader.
2. Insert card Reader to Computer Via USB.
3. Go to my computer and Open the USB Card reader.
4. Select the Music files from your pc Via Copy files
5. Go to open Tab (Where you can see your Micro Sd card) Open the sounds folder and Paste.
If you are finding it hard to get the 5 folders of images, Documents, Sounds, others and Videos on your Micro SD card. Format the card by going My computer, Right click the Card reader (with you Micro sd card inserted) and click format. Takes a few seconds. Insert the card into the phone, the phone will auto put the folders on the card. Then go to step 1 (above) and start again.
Hope this Helps guys.
Apr 04, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
LG KC550
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Mar 13, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
MP3 wont play in my LGkeybo
I have a Keybo 2 phone so I assume the procedure is the same for the first generation Keybo.
1) First of all, only MP3 format works, period. Don't waste time trying to load WMA or any other music format.
2) Get a micro SD card as this opens up other features of the media functions
3) Using the USB cable, connect your phone to the computer and there should be 2 file browsers that will show up: one for the internal memory and the other for the external memory (micro SD).
4) On the external memory browsing window you should find a MY MUSIC folder. Copy all your MP3 music files into this folder.
5) Unplug the USB cable and open your phone's music player. It will detect the new songs and build update the library.
There you go, you're all set! It took me a couple of hours of searching and tryouts but this works every time. Good listening!
Jan 18, 2009 | LG 10X DVD IDE 452000078
Most PCs are like that. I don't know what it is but the computer won't do it for mine neither. To put music and such on you sd card for your phone you must format the card while it's in your phone. Goto setting, Memory, Card memory, then click on opions. From there it will say "Format Card". Do it and the lock code is the last four digits or your phone number. After that's done to load music and such you put the sd chip onto you computer and transfer music to the folder on the sd card called "My_music", pix to "My_pix", and so on....
Oct 08, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Lg code
tian s ait code de nokia 5220 *"9990"et *"7760*
Feb 16, 2008 | Cell Phones
Lg shine - cannot access micro SD card which i have inserted.
I just got a new LG shine CU720 to format the card you go to settings, reset settings, master clear, memory card, my security code was 0000. Hope this helps someone else looking.
Dec 26, 2007 | LG Shine KE970 Cellular Phone
Motorola Mobility RAZR V3m Cellular Phone Logo
140 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
