Question about Compaq Presario CQ50-215NR Notebook
Compaq presario laptop screen flickering
When i move my screen (ex. opening and shutting) it has to be just right or it flickers with these bluish green lines running horizontally. Other than that it works fine, it is just when you move it.
  • 1 more comment
  • austinsmeme May 29, 2009
    Yes it is still under warranty.
    How do you can your computer ram chips???
    oops I meant cane your computer ram chips
  • austinsmeme Jun 01, 2009
    Thanks, that is what I will do!
  • Compaq Master
  • 4,806 Answers
Hi there.
It sounds like you may have a loose inverter cable or the ribbon cable behind the screen is loose.
Is the machine in warranty? I
Posted on May 29, 2009
  • Lee Hodgson
    Lee Hodgson May 29, 2009
    Its nothing to do with the memory modules (ram chips) but rather a bad connection. Rather than void the warranty i would recommend that you take advantage of the warranty and send it in to be looked at.
    Its better to be safe than sorry especially when its still covered.
    Good luck
  • 73 Answers
Please cane your computer RAM chips
  • nas john
    nas john Jun 01, 2009
    then its far better to take the computer to the nearest compaq vendor in your area to fix that since its still under warranty.
  • nas john
Fix flickering screen
Flickering screen is often caused by a defective cable. Check all the cables attached to your monitor.
If you think all your cables are in good condition, the problem is probably with the environment. Monitors are sensitive to magnetic fields. Change the position where you have your laptop.
The problem might also be caused due to refresh rate not properly being set. In this case your screen will flicker when you open images or videos. Just adjust the refresh rate that will be available in graphic properties.
If the above solutions don't work, you probably will have to change your display.
Sep 17, 2012 | HEWLETT-PACKARD Compaq Presario CQ62-225NR...
My LCD screen has been flickering.
Sound like the display panel needs to be replaced
Aug 16, 2012 | Compaq Presario CQ62-215DX Laptop
Laptop lcd screen flickering
compaq is worst......i m also having the same problem with the LCD of my laptop compaq presario CQ40....wat to do????
Jun 30, 2012 | Compaq Presario CQ40-104AX CQ40-104TU...
Laptop screen flickers
Probably the flex cable on your laptop is damage.
try to contact your nearest service center shop to check on it.
Dec 03, 2011 | HP Compaq Presario V5000Z Notebook
Compaq presario cq60 screen been flickering ocassionally then coming on, now flickering then going blank, any ideas please.
Could be a loose cable. Over time with the openning and closing of the cover the video cable is moving and in a few cases can become loose or pinched. If it is pinched it may need to be replaced. If it is just loose then it is fairly simple to remove the plastic piece above the keyboard and reset the video cable. Sometimes there are screws holding it in place but usually that piece is just snapped in place.
Apr 05, 2011 | Compaq Presario CQ60-220US PC Laptop
Sir My CQ 40 144 TU Compaq notebook screen flickers many times when I turn on the system and move the screen to and fro. At only one particular position it does not flickers. Please tell me a solution to...
that may indicate that something is wrong probably with the inverter board. its a hardware issue and may require you to have unit dismantled and checked.
regards
Mar 24, 2011 | Compaq Presario CQ50-215NR Notebook
My Compaq 14" laptop (LED
does it keep flickering? If so, there is a small circuit board in the top below the screen that can go bad, resulting in your screen eventually going dark---I had to use a flashlight to see anything. I would have it checked by a service tech soon.
Feb 14, 2011 | Compaq Presario CQ50-215NR Notebook
Laptop screen flickering CQ50-110US
unseat and reseat the LCD cable behind the LCD and also where it connects to the motherboard. If that doesn't solve it, then try another lcd cable. If that doesn't fix it then that means the LCD is bad and would need to be replaced.
Apr 19, 2010 | HP Compaq Presario CQ50-110US Laptop
Screen flickers unless I press on the speakers.
This might be a easy fix for you most likely it is that the cable has come loose which with this model they are known for this. The cable for the LCD is in the left corner. If you need help with get back in contact with me.
Feb 10, 2010 | HP Compaq Presario CQ50-110US Laptop
Compaq presario v2000 monitor is having horizontal purple lines that flicker.
Try reloading the drivers, delete the device in device manager and reboot. It should then pick up the drivers and reload them, if that does not work I would suspect the screen is on its way out (flickering normally means the screen or its connection is bad)
Jan 26, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario CQ50-215NR Notebook Logo
2,463 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
