Question about Kirby G6 Bagged Upright Vacuum
REMOVING HOSE END
I HAVE A KIRBY G6 2001 LIMITED ADDITION- THE ENDS ON THE HOSE GOT CHEWED UP BY MY DOG. HOW DO I REMOVE THE END ON THE HOSE SO THAT I CAN REPLACE IT?
I had to replace the hose end on my Kirby, the motor end. I have the Diamond edition. Just take a hair dryer and get the end of the hose warm, and then us a screw driver. Works like a charm. It stays warm long enough to put the new end on.
Posted on Nov 10, 2009
  • 357 Answers
Hello!
Inside the machine end of the hose is a round rubber ring that holds the hose into the hose end. Take a flathead screwdriver and push the edge of the rubber ring towards the center and downward. MAKE SURE THAT YOU DON'T STAB YOURSELF IN THE PALM WITH THE SCREWDRIVER! lol
It should come out with some hard pushing. Now, just push the edge of the ring inwards again and hold it in place with your other hand. Put it up inside the new hose end and then use the screwdriver to smash the edge back out again to hold it in the new hose end. Hope this helps! Here is a link to find the repair part that you need to fix your hose...
http://stores.shop.ebay.com/CLICK-HERE-FOR-GREAT-DEALS_hose-parts_W0QQ_fsubZ19761820QQ_sidZ122982163QQ_trksidZp4634Q2ec0Q2em322
Marci
Posted on Jun 28, 2009
  • 3 Answers
The hose end is normally glued on the Kirby vac's you have to cut the hose and trim back the end then either replace it with a new end or re-attach wtih rubber cement...
Posted on May 29, 2009
My dog chewed the plug off the power cord, is there a way to replace it. I love my dc-17 dyson animal
Yes. You can splice the cord together. But when you pull it it will want to separate, so when you splice it add something ...like a wire tie..super glue it to both sides before you tape the splice. If it is the whole cord you will have to take it apart and make new stripped ends and just remove the old piece..put the new end on. This is not as easy as it sounds, I have done it but I am handy with tools and a little common sense.A handy man can fix it for you.
Oct 29, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Replace coupling to Kirby G4
Hi There,
I think what you are asking is how to fit a new hose machine end, (hard plastic bit that connects the hose to the kirby body) to the rest of the corrugated hose?.
If this is right it does vary with the really old models but for the G3 and newer which is everything up to about 20 years old it is the same and quite easy.
All you have to do is heat the end of the hose up with hot water - not boiling or you will shrink the hose and kind of twist the new end on. You will need to have removed the old one first which is the same just heat up and twist off.
If you need kirby parts in Australia visit VacuumSpot.com.au
May 17, 2012 | Kirby G4 Bagged Upright Vacuum
What is the best way to remove the fittings from the original hose to replace onto a new hose
If you dip the ends in very hot water for a few minutes to soften the material, they will pull off much more easily. On the machine end, use a screwdriver on the inside to bend the rubber into a "kidney bean" shape, and pull the connector off.
May 13, 2011 | Kirby G4 Bagged Upright Vacuum
How to attach Kirby Heritage Suds-o-gun?
To use the suds-o-gun you need to convert you Kirby to blower mode. First remove the carpet head.
If you have all of the standard kirby attachments there should be a plastic cover to go over the front of the kirby where the carpet head attaches. Its round with square holes in one end. If you don't have this no biggie. Just leave the carpet head on the machine and rotate the belt to the off position so the brush rool bush on rotate. Remove the bag for the machine attach the hose where the bag was use the same end that attaches to the front on the machine. There are notches on the inside of the hose connector the fit over the tabs on the bag port. Fill the suds gun tank with shampoo and water. Attach the suds gun to the kirby hose. The suds gun nozzle is funnel shaped with wire mesh on the end. This helps to make the suds finer. Also the suds gun should have a knob to set how much suds come out when you pull the trigger. Turn on you kirby and suds away.
I hope this helps.
Feb 05, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Hose for G3 Kirby doesn't fit Sentria
Yes G3 and G4 had different gasket thus the suction blower connector connecting Kirby hose to the unit on later models is different. You do not need to replace entire hose but just the plastic part that connects to the vacuum. You can find it HERE. To remove old connector you may have to submerge the end of the hose into hot water (not to hot to touch) so the vinyl becomes soft and you can bend it in with finger bringing plastic end over the lip on the molded end of the hose.
Good Luck
Jan 30, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I havent used my shampooer for over a year, and i am now having t
These are the parts-Tank,tray,brush roll,brushroll housing,belt,hose,foam screen(small,quarter sized plastic screen)large foam air filter,(should be on the air inlet at tank).
Starting with brushroll,install belt over brushroll,and place brushroll in the trayInstall the brushroll housing over the top of tray..Looking thru the back,turn the belt lifter knob until the hook inside picks up the belt.Raise the height adjuster on the Kirby all the way up.Attach the entire assembly to the front of maching,and lock it on.Now turn the belt lifter clockwise until the belt drops onto shaft.Snap the elbow end of hose to tray.Before attaching the other end of hose to tank,make sure the foam screen is fitted onto the small outlet at tank,then install hose.Note:Sometimes the screen will be in the tank end of hose allready.Without this screen,you wont get foam,only solution.Make sure the foam air filter is installed in the large opening at the tank,or dirt will get into tank,clogging it.Install the tank to the blower side of machine.You should be ready to go.Lower the height adjustment all the way down.
Dec 15, 2008 | Kirby G4 Bagged Upright Vacuum
Unclogging drains?
Hi!
You need to take the power nozzle off and attach the thing that looks like a little plastic cup with two hooks on it. This is the intake guard. Attach it to the front. Now remove the cloth bag and put the hose on the hole where the bag was. You'll have to line the arrow on the hose up with the notch on the Kirby and push the hose arm toward the Kirby until it pops on. If you need to, lube up the edges of the hole with a wee bit of vaseline or hand lotion. This makes the hose engage easier. Now, turn your massage cup (in your basic set of attachments inside out and hold it on the drain hole. If there is an overflow hole in the sink, you may want to cover it so that you won't be splattered with gunk. lol Now, turn the Kirby on and it will attempt to blow the clog on through the pipe. Sometimes it works...sometimes it doesn't. :0) Hope this helps...
Marci
Jul 19, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby sofa cleaner
Hi, my name is Jon and I have an Ultimate G Kirby and have sold Kirby and the solution to this problem it is very simple. All you have to do is first disengage the belt by lifting the hood and twisting the plastic thing that says Kirby. Twist it all the way till the red arrows meet up then you will know that the belt is disengaged. Next you're going to disconnect the front by pushing the small metal lever/lock under the hood to the right and the front end should come right off. REMEMBER put the vacuum on the highest setting so this will be much easier to do. Then what you want to do is connect to hose and you will do so by connecting the hose in the same manner in which you would connect the front. There is a perch for the hose or any of the other attachments to rest their "feet" on as you will see the end of the hose is contoured to fit the Kirby in the same way the front end does. Lock the hose in place with the metal lever/lock by putting it over to the left. REMEMBER to disconnect the belt when you take off the front end and ALSO to reengage it when you put the front back on. I hope to have solved your problem, and I'll talk to you later!
Nov 18, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Cleaning upholstery with the Kirby?
it depends on the make of the kirby you are using but most kirby systems come with a portable shampooer and special shampoo. I would not recommend using your zip brush for shampooing purposes, the zippbrush is designed to loosen up dog hair, dirt, ect. when vacuuming. to shampoo upholstery do the following: remove bag from side of machine, place hose where bag goes, remove power head from front of the machine, place air intake valve on front of machine where power head was (intake valve kinda shaped like a pig nose with small holes on end) attach portable shapooer to end of hose and fill with water and kirby shampoo spray shampoo witch is foamy looking on whatever you are shampooing, rub into fabric w/a brush and let sit till dry. when dry turn kirby back into a hand held vacuum by putting powerhead back on front of machine and putting bag back on side of machine, then vacuum furiture. (make sure it is 100% dry before you vacuum because Kirby is not a wet vac!) Hope this helped ya out a little
May 23, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
540 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
