Question about GE Profile JTP18 Electric Single Oven
Takes forever & doesn't heat hot enough anymore-
Oven, 8 yrs old, seems to take a looooonnnger time now to reach the preheat temp --- And then, I have a feeling it's not really going as high as I program it to? What could it be? Need service or to replace something? Is this a common problem to have every so often?
  • 323 Answers
You may have a bad timer, or heat sensor, or a combination of both. Buy yourself an inexpensive thermometer approved for ovens and check your temp and times manually while watching the inside thermometer.
You may find that it is performing better than your sensors tell you.
On the other hand, the heating elements make need changing, a relatively small cost. Note: Always change both the top and lower. Call any appliance parts supply house and give them the model number, and perhaps the serial number.
It's a small investment to determine whether or not its time to replece your unit.
Sirwriter
Posted on May 29, 2009
  • 3,600 Answers
Most likely the element has gone bad and needs to be replaced element will cost average $40.00 plus a service call, to do it yourself you would need to unplug the socket and then work on the unit as the voltage is 220 so unless your handy at figureing out how to unscrew the parts apart and being able to take the part in I would suggest you call a tech to fix it. If I had a picture of the element I could tell you how to take it out but then there would be no warrenty if the guy comes out and fixes the problem he or she would warrenty the fixed problem for a certain amount of time.
Frigidaire stove is about 12 yrs. old. My oven will not heat past 250 degrees and it takes along time to reach that temp. The stove never indicates that the preheat temp. is reached. This just started last...
Hello, welcome to FixYa.
If you can provide the complete model number (usually on inside of door frame or around the bottom door opening), I'll see what I can find for you.
There are many possible scenarios as I hope you can appreciate being this is a global repair site, even within' the Frigidaire brand so I'll need to clarify the make & model before moving forward.
Regards,
Macmarkus :)
Aug 14, 2011 | Ovens
Not sure which model my oven its but it takes a long time to preheat then does get warm enough. I put an oven thermometer in it and if you set it for 400 it beeps that it is up to temperature at 300 then...
I have a kenmore electric range/ultra bake, after using the self-cleaning mode on the oven, I cannot get the oven to heat up when I put it in the preheat mode. What should I do?
Apr 06, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
Feb 26, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
I have Jen Air expressions built in oven. It takes forever for the oven to preheat. What could be the problem?It is about 13 years old.
Both the broil and the bake heating elements are on during preheat. I would take a look as it appears that your broil element needs to be replaced.
Jul 12, 2009 | Ovens
Kenmore 30425 Oven will not reach target temp
the ignitor is moast likley bad, look for a hot spot on the ignitor showing a open on the filament.
Dec 25, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Seems to be taking a long time to cook
To preheat oven just select the temp you intend to cook at and wait until the red light goes out,it is then preheated
Then you can put your food in and carrying on cooking.
Yes you do put it on fan symbol, but make sure it is on the right one , as some ovens have fan only as well as fan and heat.
Plz rate this solution.
thanks.
Dec 14, 2008 | Ovens
Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Nov 29, 2008 | GE JGRP20 Gas Single Oven
Oven takes a long time to heat up
your ignitor could be going out. the ignitor has to get hot enough in order for the gas to turn on and heat your oven. if your ignitor is going out, sometimes it doesn't glow hot enough for the gas to turn on, or it could be that is takes longer than normal to get hot enough to turn the gas on. I would replace the ignitor and that should solve the problem. Joe
Nov 15, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
GE Profile JTP18 Electric Single Oven Logo
144 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
