Question about Jandy Laars Lt 400,000 Btu Heater
Heating problem with laars lx400 boiler
Burner continues to operate when pump switched off. low pressure sw operates correctly, and 24v present at both white leads to gui. normally when pump switched off,heating ceases, and "low pressure" comes up on gui display. this no longer happens. heating works normally only when pool/spa/off is made to "off" after pool temp is brought up to required temp, then made to "pool" when heating required again.at no time does the "low pressure" warning come up.
    Top Expert:
  • Jandy Master
  • 5,775 Answers
Replace or adjust pressure switch to have heater go off when pump is off
Posted on Apr 29, 2016
5 Suggested Answers
  • 10865 Answers
SOURCE: My pool heater will not start. The power light is off and the pressure sw is lit.
You must turn on the pump and let water circulate through the pool and the heater before you turn on the heater otherwise you will ruin the heater
Posted on Apr 16, 2009
shuggie73
SOURCE: Laars lite II Pool and spa Heater LG model
Bad pilot generator? Flow issue?
Posted on May 25, 2009
  • 10 Answers
SOURCE: I have a Jandy Laars LX Pool/Spa Heater...when I
If the unit is lighting then shutting off then repeating it isn't rectifying, means not sensing the flame. May have a bad flame sensor or ignition control. I'm guessing your AGS is indicated on the GUI also.
Posted on Mar 07, 2010
SOURCE: I have a Jandy Laars LX Pool-Spa Heater
You have a serious issue call a qualified heating or mechanical contractor sounds like a lock out or solenoid which is designed to shut off gas/flame for things like not blowing your backyard up is doing it's job. Or take the advice of a faceless stranger and hope you get it right 400,000 btu is about 7 x's the average home furnace so should be quite a boom
Posted on Apr 08, 2010
LX400 low pressure switch
if good water flow through heater make sure if you have a bypass it is closed half way if not check pressure switch to see if 24 volts on both wires if not bad pressure switch or clogged copper line to it
Jan 02, 2012 | Teledyne Laars Laars Lx Pool Heater /...
Tip
Laars LX400 Manual Download
Laars LX400 Installation & Operation Manual
Models: LX250NL / LX250PL / LX400NL / LX400PL
Models: LT250NL / LT250P / LT400NL / LT400P
Have you lost your Users Manual / Owner's Guide for your Laars LX400 Pool Heater?
Would you like a digital copy of the Installation / Operation Manual for easy searching of terms and quick reference?
Click here to download your pdf version of the Laars LX400 Pool Heater guide.
I hope that helps.
on Apr 19, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
I have a Laars LX250 pool heater. The pump and heater are tied in with a timer that has a fireman switch. When operating properly the switch disables the heater for cool down before the pump shuts off. I...
If this answer does not fix your problem, pleasecomment with additional details prior to rating the answer. Positive feedbackis appreciated once your problem is solved! Thank you.
Aug 17, 2011 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
My new Laars JVS 225 boiler make a whining noise when heating up. It does it on all zones. This was a replacement for a Teledyne Larrs that had a leak but ran quiet. IPressure is 15 lbs and temp is 155...
My new Laars NeoTherm boiler (NTH150) was making a whining noise soon after install. The noise was audible through most of the home. Replacing the air/gas blower solved the problem. Correct sizing of pumps is also important to reduce (water-flow related) noise. Having done all that my Laars boiler still isn't particularly quiet in its start-up and (modulating) operation. It should NOT be located below or next to a bedroom.
Nov 19, 2010 | Heating & Cooling
Air flow failure indicated on heater
Mine does the same. Sounds like you checked the air pressure switch, but the high temp switch and bad airflow can also cause this problem. Check the two white wires that lead to the heat sensor vent drain tube exits. Make sure the spade connectors aren't shorted. Try testing the temp sensor like you did the pressure switch to make sure the circuit is properly closing when in use (or use a temporary jumper to bypass as a test.) Check the bottom of the pan for any dust or crud that could block the airflow below or around the burners and last of my options- increase clearance around the unit to aid air flow.
Jun 01, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
I have a Laars Max Boiler 75, 90K with white smoke out chimney
Hello
Yes,more then likely its moisture from the high effenicey system of the boiler.
I have a laars boiler at work and some mornings when its cold out it looks like there is a fire, which is really only steam.
As long as your not shutting down on low water failure or loosing pressure and holding temp.This is normal.
Hope this helps.
Jan 26, 2010 | Heating & Cooling
We have an LX250 gas fired pool & spa heater which was installed a little over a year ago. If the filter pump stops for any reason (usually leaves blocking it or reduced water level in the pool) the...
you most certainly have a potentially hazardous condition. there is a pressure switch that is suppose to detect low or no water flow and interrupt burner operation.i suspect it is out of adjustment. there is a section in the owner manual that details adjustment procedure.it is actually quite simple to do,but if you not want to tackle this ,i would suggest not using the heater until it is looked at.
Sep 14, 2009 | Pool & Spa
Laars LX400 Air Flo SW Error
is fan coming on if not bad fan motor also check pressure switch if 24 volts both sides that's ok make sure air flow switch hose is ok
Sep 09, 2009 | Teledyne Laars Laars Lx Pool Heater /...
I get a message saying Hi Lim SW when trying to heat my spa. What does this mean
Temp control failure (thermostat) high limit is safety to prevent over heat.
Jul 26, 2009 | Jandy LAARS LX400 - NATURAL GAS, DIGITAL...
I get a message saying Hi Lim SW when trying to heat my spa. What does this mean?
hi limit switch heating unit getting too hot what type of heater are you using
May 09, 2009 | Jandy LAARS LX400 - NATURAL GAS, DIGITAL...
Jandy Laars Lt 400,000 Btu Heater Logo
166 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
