Question about Whirlpool WED6400S Electric Dryer
I got power to the dryer, but it won't run. Could this be the belt broken? How do you get to the drive belt?
  • 323 Answers
Okay. You have power to the dryer. Is it a 3 prong plu or a 4 prong? How do you have it wired? When you turn it on, do the lights come on the panel and/or inside the unit or is it completely dead?
Have you checked the breaker to make sure the 249 amp breaker, a double, is all the way on? If tripped, it will be in the halfway position. If it is, turn it all the way off, then back on.
Finally, you'd be surprised at how many times a wire has slipped out of a holder in a plug, or it just wasn't wired correctly. On a 3 prong plug, you have a white at the bottom, a red and black on the top two, doesn't matter which side.
Let me know how you come out.
Sirwriter
Posted on May 29, 2009
I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
see this causes and fix it. God bless you
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Sep 28, 2012 | Bosch Nexxt 800 Dryer
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
I have an amana dryer,,,it says drying but it won't start,,no sound or nothing....I tried the fuse wires at the bottom direct and still nothing...so I don't think its the fuse...thanks
Sep 28, 2012 | Dryers
Drum won't spin on it's own but spins freely by hand.Was slow to start spinng before. Took front off but can not see belt at all, if it has one?
drive belt is normally accessed from the rear of the machine or if sealed rear from underneath(bottom) the belt is normally easier to get off the drive motor pulley first . Sounds like your belt is either already broken or has come away from drive unit or drum .
Jul 25, 2011 | Maytag MDE508DA Dryer
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
Dryer heats up but the inside doesn't turn.
a dryer will not turn if the belt has fallen off the motor or if it has been broken    replace the belt
Nov 05, 2009 | World Imports Belle Foret N30002TB...
Press the start button and drum doesnt start but the dryer makes a humming noise.
motor running but drum not turning, good chance drum drive belt is broken or has jumped off drive pully.
UNPLUG POWER CORD TO DRYER.
open dryer and look for broken belt, if belt is broken use modle number from dryer to purchas the correct belt for dryer install belt and reasmbele dryer. reconect power and test dryer.
Oct 23, 2009 | Dryers
Whirlpool WED6400S Electric Dryer Logo
67 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
