Home | Jenn-Air | JDB6510 Built-in Dishwasher | Jenn_air DW730W wat...
Jenn-Air JDB6510 Built-in Dishwasher
Problem for Jenn-Air JDB6510 Built-in Dishwasher
Jenn_air DW730W water does not drain
By keithc7777 on May 29, 2009
What area should I look into? Thanks! water doesn't drain
Clarification Request
Posted by sirwriter on May 29, 2009
Does it spin as if it is trying to drain? What has changed since it was installed? Is the drain pipe higher or lower than the drain hose?
How old is the washer? Have you cleaned the filter recently? When it goes into the spin cycle does the motor inside sound like it always has or id there a change?
Best Solution
posted on May 29, 2009
Very Helpful)
trpabc
Rank: Guru
Rating: 93%, 104 votes
The problem is most likely the drain valve. It is electrically operated, and it is common for these to fail.
If you need more help, post a comment.
Thanks,
Tim
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Jenn-Air JDB6510 Built-in
Questions and Unsolved Problems for Jenn-Air JDB6510 Built-in
Do you recommend Jenn-Air JDB6510 Built-in Dishwasher?
Answer
Answer
JENN-AIR DISHWASHER JDB6510 DOOR HANDLE IS STUCK IN THE LOCKED POSITION WITH THE DOOR OPEN. I CANT... (More)
Answer
Why is my dishwasher making a buzzing noise? It is almost 2 years old and is a GE brand we got from... (More)
Answer
Slow to drain, took apart bottom of dishwasher and there was a few things stuck in there but still... (More)
Answer
I have a Jenn-Air JDB6510AWP Diswasher and It leaks at the bottom of the door. I have changed both... (More)
Answer
we noticed that the soap container did not open, so we started a new cycle. That is when my wife... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Jenn-Air JDB6510 Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
