Question about RCA HDLP50W151 50" Rear Projection HDTV
Noise RCA HDLP50W151 When you turn on the television it makes a high pitched sqealing sound.Could it possibly be the cooling fan going down?It sounds just like a bearing would before it fails.Whatever it is,it must be a moving part,because it gradually slows down and stops when the television is powering down.
  • RCA Master
  • 8,617 Answers
Thats the color wheel part number 212184. You can get a new replacement Color wheel for your model at the following link.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-color-wheel-212184/cName/color-wheels
Posted on May 29, 2009
My toshiba mod. 52hm95 lamp cooling fan is making noise and i am having trouble locating a replacement
Fan like noise may be a fan or the color wheel---color wheel spins at high speed(lamp faces it) and when failing you will have a high pitched or fan like sound---hard failure and you will hear a grinding sound.
May 16, 2012 | Televison & Video
My laptop makes a high pitched noise
The high pitched noise you hear is most likely caused by the CPU cooling fan on your laptop. If you suspect that this high pitched sound is caused by the fan going out, you can spray your laptop with compressed air to get the dust off of the fan.
This solution will make your laptop work at a cooler temperature, and reduce the noise.
If the problem persists, seek a certified laptop repair specialist.
May 22, 2011 | Computers & Internet
WHEN I TRUN OFF THE TV IT MAKES A NOISE LIKE SOMETHING IS TURNING AND RUBBING SOUND.
2 solutions for problem. ONE color wheel is grinding. IF high pitched sound is heard. Second bad fan or fan contaminated with dust. Turn TV off unplug. LET cool down ... Using canned air clean all vents on rear of set. MAY also need to remove cover and find the 3 fans inside of set.
Feb 16, 2011 | Samsung HLR5067WX 50" Rear Projection HDTV
A noise had been gradually increasing from a grinding sound to a high-pitched whine. COntinues until the screen is completely off. Sounds like a fan motor may be out of lubrication.
THAT TV HAS WHAT IS CALLED A COLOR WHEEL WHICH SPINS AT VERY HIGH RPMS AND CAN MAKE HIGH PITCHED WHINING/GRINDING NOISES IF A FAN WAS BAD THE TV WOULD SHUTDOWN AND THE SOUND WOULD BE MORE DULL SOUNDING.
Dec 17, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Trouble turning on tv. High pitched noise/click.
The mainboard might have some loose components, or cold solder , or may be the filter capacitors are becoming faulty. Yes it is worth repairing, bring it to the repair shop. Cheers.
Nov 25, 2008 | RCA Televison & Video
Whining noise from pc tower
No transistor will make such noise... The problem is not in your M/B. The problem might be due to the fan that cools your processor. So clean dust around the fan thoroughly.
Sep 28, 2008 | ASUS NCT-D (90MSV430G0UAY) Motherboard
RCA D52W19 - High Picth sqealing noise
Thats usually a sign of the flyback or HV Splitter nearing the end of their operational lifespan. However its not an exspensive fix unless done ay a repair shop then it can be a few hundred.
Apr 21, 2008 | RCA D52W19 52" Rear Projection Television
An Annoying High Pitch Sound
Can be either noisey yoke or noisey flyback transformer........T.
Dec 12, 2007 | RCA F32450 32" TV
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
RCA HDLP50W151 50" Rear Projection HDTV Logo
379 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
