Question about Toshiba Satellite P15-S420 Notebook
My com port disappeared
Device Manager no longer shows that I have a com port. According to Device Manager, all I have is one LPT port. How do I reinstall my com ports?
  • tspivak May 30, 2009
    How do I restore it to factory settings? I don't have the OS disks. They didn't come with the computer.
    Novelist:
  • 166 Answers
Yeah such problems happens when com port versions are mismatched with OS supporting drivers.
So in that case, you should repair you OS or restore it to FACTORY settings.
By doing this you will be able to regain your all configuration for all ports available.
I hope this will work out for your problem.
Rate this solution if it was helpful to you.
With Regards,
Shyny
Posted on May 29, 2009
Printer is no longer printing
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps
Aug 24, 2011 | Computers & Internet
Tried different ports, different usb cables. No luck. It shows in the devices but will not print
Check for the printer requirement for operating system and maybe it is not compatible.
Correct Printer icon name. Correct usb port driver needed. Check your device manager for usb port driver if properly installed. otherwise use LPT port if there is install driver for your computer.
Dec 16, 2010 | Office Equipment & Supplies
USB ports not working. Is it possible to repair the mother board or does entire motherboard need to be replaced? Have already tried disabling root hub, controllers etc. But still get unknown device...
have you tried updating the ports driver
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)right click update driver
hope this helps
Nov 27, 2010 | Dell Inspiron 1520 Motherboard
My iball 4gb pen drive problem.... when i connect it to computer shows usb device unrecognized...
the drivers might have been corrupted
control panel admistrive tools,computer management,device manager scroll down to universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)or communications port right click update driver
hope this helps
Nov 21, 2010 | Computers & Internet
CANT GET PARALELL PORT TO WORK DEVICE MANAGER DOESNT SEE IT ?
the laptop bios should support lpt port and if your doesn't have lpt port then you can not use the one for the docking station because no bios integration with the lpt port on docking station
Apr 18, 2010 | Targus Port Replicator, Docking Station,...
Ethernet indicator light always yellow
Go into device manager and then drivers and resources and change the comport there. One and three have same physical location and different addresses.
Apr 10, 2017 | IBM ThinkPad T41 Notebook
How to find the com port for the USB driver
You have to look in the device manager. Usually you can get there by right clicking on My Computer then selecting Properties then the Hardware tab and Device Manager. If the CS1504 pulled a virtual COM port it will be listed under Ports (COM & LPT) as Prolific USB to Serial Comm Port with the port named at the end of the line.
Oct 14, 2009 | Symbol CS1504 Handheld Barcode Scanner
My older hi-pro box will not work with my serial to USB adapter. It keeps saying it cannot find it on com 1,2,3,4. In the device settings it says the hipro is on port 2 and the serial/USB bridge is on port...
I just set up a serial Hi-Pro box for one of my customers on their new laptop. According to Beltone, the only usb adapter that will work with the Hi-Pro (or at least the only one they have gotten to work) is a Belkin F5U409. I know some usb serial adapters don't use true serial communications if that makes any sense, so there isn't really a baud rate. They kind of just send out the communication in bursts...
In any case, ive only tried with the belkin adapter and that worked fine with no problems. The other point here is that your Hi-Pro and Adapter are on different com ports... This is odd, the hi-pro should be on the serial adpater's com port. Also the software i was using - Noah, with a beltone module for programming hearing aids.. only looked on com ports 1-3. The computer put the serial adapter on com 8 - which would not do. I checked for available com ports and saw that 2 was unused. I set the adapter to 2 and was able to set up the program normally.
I did this on Windows 7 Professional 32 Bit. The procedure for selecting the com port is the same on earlier versions of windows.
First, open device manager, open the list titled "Ports (COM and LPT)". You should see your serial adapter in there. Double click it. In the window that opens click the "ports" tab, and hit the button labeled "Advanced" In the window that opens there will be a drop down list to select a com port. Select the desired com port and hit ok. That should fix it.
Jul 12, 2009 | Uniden Unipro PC100
LPT port
now you have to insert the System CD of the motherboard and when it auto run then install ALL the driver its shows and if the problem countinue then install the port manually using ADD NEW HARDWARE in th control panel.
Dec 02, 2007 | ASUS A7V8X Motherboard
Toshiba Satellite P15-S420 Notebook Logo
269 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
