Ricoh Aficio 1515 All-In-One Laser Printer Logo
K
Kerrie Smiles Posted on Jan 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I clear the memory - Ricoh Aficio 1515 All-In-One Laser Printer
Jeff Hughes
Level 2:
Sniper:
  • Expert 97 Answers
  • Posted on Mar 03, 2014
Jeff Hughes
Expert
Level 2:
Sniper:
Answers
97
Questions
Helped
162534
Points
250
SP5801-001 Memory Clear: All Clear
How do I clear the M memory from my Casio DM-210 calculator
To clear the memory on a Casio DM-210 calculator, follow these steps:
  1. Press the "AC" button. This will clear all values and functions from the calculator's memory.
  2. Press the "M" button. This will access the calculator's memory menu.
  3. Press the "C" button. This will clear the memory.
  4. Press the "EXIT" button to exit the memory menu.
If you want to clear a specific memory location on the calculator, you can do so by following these steps:
  1. Press the "M" button to access the memory menu.
  2. Press the number of the memory location you want to clear (for example, "1" for memory location 1).
  3. Press the "C" button to clear the memory location.
2helpful
How to clear Memory?
If the memory is filled up when a fax is received ... when there's no paper, or it is jammed (so that it can't print) ... you can print the fax (in Memory, after putting in new paper, or fixing the jam) by pressing the START/MEMORY button. After it prints, the memory is cleared.
If the memory is filled up when you're scanning and storing a document into memory (to be fax out), press the START/MEMORY key to transmit the pages that's already in memory. After transmitting the content in memory, the memory will be cleared/emptied. You'll need to scan the remaining pages to transmit (as a separate fax)
1helpful
Hi & thanks. There is a small 'M' on the top center right of the 'number' screen. How do I get this to go away? Remove the battery? Thanks again & regards, -louis
This M does no harm. It merely reminds you that you stored something in memory. You can try pressing the AC (Clear All) button. Alternatively, store 0 in all the memories. If I am not mistaken you have 3 memories. Try
0 STO 1 to clear Memory 1
0 STO 2 to clear Memory 2
0 STO 3 to clear Memory 3.
15helpful
2answers
What does MC, MR, & MS mean?
Welcome to Fixya. Heres the meaning that you're looking for.
MC - Memory Clear. this clears all contents of the memory
MR - Memory Recall. This displays the current content in the memory
MS - Memory Save. This saves the current display to memory.
M+ - Memory Add. This adds the current figure to the value already present in memory.
Thanks for using Fixya.
3helpful
How to remove memory from scienfic calculator
To clear a memory location, just store 0 in it.
0 [STO] M clears memory M
0 [STO] A clears memory A
0 [STO] B clears memory B
etc.
In use/memory light up and it won't let me fax.
To Clear the memory simply switch of the printer and power it on again. This will clear the data in the memory
FO 5700 Won't print from memory
You have memory lock up. to ram clear the machine we need to clear out all memory. ( like it came out if the box )
1. have machine turned on
2. press 8,*,9,#.7 ( this will git you in to the programing of the fax )
3. press start
4. press the # key till memory clear
5. press start !( will clear out all memory )
it should print out a memory clear report
6 press stop key 2 times now lets se how it worked
let me know
good luck
2answers
Clearing memory Brother 8360p
Press quickly......MENU 2864 then press 91
1helpful
Memory full ux300
to clear memory(which i must warn will clear everthing) first press function then press the number 9,next press * (asterict) then press the number 8 then press the # key then 7 key, press start, you should see a ram version on screen,then press start again,next press # key untill it say's memory clear,press start and it should say memory clear.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
