Question about GE Spacemaker JVM1640SJ Microwave Oven
Displays F3 cannot use touch pad just surface light
  • 4 more comments
  • puma17 Nov 07, 2007
    Microwave started coming on, on it's own by turning on the vent then now have error code -F3- brand is as follows Hotpoint RVM1635 1000 Watts Microwave Oven
  • angellover Nov 24, 2007
    have been occurring more frequently now and alarms in middle of the night unplugging doesn't reset the microwave. I have GE model jes1036wf001 the touch pad doesn't work but light is on inside.
  • allenboy Feb 14, 2008
    Can't use key pad an F3 code is displayed and a alarm.
  • very inept Mar 11, 2008
    can't use control panel and have no surface light
  • Anonymous May 24, 2008
    I have the same problem with the F3 and the light and alarm.
  • Geneo1113 Nov 14, 2008
    Ge microwave spacemaker model JVM1650 displays "F3" and the touch pad is inoperative. Any ideas?
  • GE Master
  • 9,098 Answers
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 24, 2008
  • 4,889 Answers
Please specify the brand name the error codes differ with each brand..
Posted on Oct 22, 2007
GE JVM1440SH001 f3 error
see the commentaries and repair:
F3--Shorted key panel(touch pad), will occur if a shorted key panel is detected continuously over 60 seconds.
test the following:
1. Door is not closed (some models).
2. You waited to long (open and close door to wake it up).
3. Controller is confused (pull plug for a minute or two to reset).
4. Defective interlock switches.
5. Faulty controller or its power supply.
6. Touchpad or controller board contaminated by overenthusiastic cleaning.
7. Defective/damaged touchpad.
Jul 31, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
F3 code on frigadaire microwave?
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jan 14, 2012 | Frigidaire Microwave Ovens
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE microwave and F3 has just come up on the display screen???
F3 Shorted key panel (touch pad).
1. Will occur if a shorted key panel is detected continuously over 60 seconds.
2. Replace key panel (touch pad).
What you can first try before replacing the keypad is first unplugging the microwave. Then you can get access to the panel by first removing the top grill and then unscrew the top of the control panel. There is a strip that looks like tape which attaches to the control panel which you need to wipe off and then blow dry. may not work the first time but be patient. also clean the bottom of the door and the latches to make sure the connection is clean. After that is should hopefully work without replacing the touch pad.
Let me know how this works out for you.
Benjamin
Apr 26, 2010 | GE Profile Spacemaker Over-the-Range...
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave jvm 1430 error code F3
Jul 17, 2009 | GE JVM1430 Microwave Oven
F3 error
HI, the Key panel (touch pad) is shorted.
Jun 16, 2009 | GE Advantium SCA1001SS Convection /...
Microwave Oven
I report from owner manual.
F3 means : Short circuit on key panel (your touch pad).
You get F3 error if a shorted key panel is detected for more than 60 seconds.
Solution: . Replace key panel (touch pad).
Try first unpluggign power cord for five minutes.
If you think that the problem may had been caused by water inside the keypad you can try using an hairdryer on the keypad, taking care not to melt the keypad plastic.
If that does not work, then replace the keypad.
You can buy replacements here. or Order GE Microwave Ovens Parts Here
Mar 08, 2009 | GE JVM1630 Microwave Oven
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave f3 code
You have a shorted touch pad.. here is a link for a replacement.. http://www.pcappliancerepair.com/model-display.php
If you open up everything and examine the touch pad, you may see something that is causing the short and fix it, oherwise, you'll have to remove and replace it.. Hope this helps..
Sep 12, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,324 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
