Question about Dryers
Dryer runs but doesn't dry clothes. - Dryers
  • kgrizz13 May 29, 2009
    The dryer is a gas dryer and doesn't heat at all.
  • slypp187 May 11, 2010
    gas, electric?
    does it heat?
  • 38 Answers
Hi,check to see if element gets hot,run dryer for 5mins. open door and look at back of dryer.you should see a red glow.or you should feel heat.if not the element needs replaced.and make sure the tumble is tumblering. a dryer can sound like its running,but nothing is really happen.
Posted on May 31, 2009
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
My dryer doesn't want to dry clothes
is it getting hot if not maybe your heating element .There is also little sensors thru the dryer one may be bad
May 21, 2012 | Kenmore Dryers
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
My LG front loading dryer doesn't dry well
Check the exhaust vent when running and be sure there is a good flow of air. You may have to clean the exhaust pipes all the way through. Dryers require a good flow of air for proper operation.
Jan 10, 2012 | LG Dryers
Runs fine Doesn't dry clothes, not enough heat?
You will first need to determine where the problem is, I would disconnect the dryer vent from the dryer. Now if the drying improves, problem is not the dryer, its the vent system. If no change, does the unit heat at first then slowly fail to heat? Does it produce any heat? I need more information to direct you in the correct direction.
Please get back to me
Sep 08, 2011 | KitchenAid KEYS700LQ Electric Dryer
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
The dryer simply doesn't dry my clothes
Are the clothes warm after cycle? If not heater coils may be bad. Is lint trap cleaned out? Have you checked the vent that exhausts the air to the outside? make sure it is cleaned and kink free and the air is flowing freely. If you can get to the end of the vent outside you could try running the unit and check to see if you're getting good air flow outside from the vent.
May 27, 2011 | Amana Dryers
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
Dryers Logo
171 people viewed this question
Top Dryers Experts
