Question about Motorola Mobility Bluetooth??¢ HF850 Car Kit Wireless Headset
BLUETOOTH Car Kit Type No. BTHCK 100
HI,
I have a new car, and the above car kit needs to be fitted into it.
I do not have the wiring or installation details, the audio guy just cut the wires when removing from the old vehicle. Pls send info and any operational
guide as well.
To make it come through the car audio system, muting the radio whould also be a bonus.
many thanks
Arthur
arthur.wiggins@federalmogul.com
  • Anonymous Apr 18, 2009
    i have a wireless bluetooth bthck100 and need to know where the negative and positive wire must go. i do not have the diagram or the installation kit can you help
    marius
    Problem Solver:
  • 6 Answers
Connect the fuse kit's GREEN Ignition Sense wire (3 amp fuse - switched) to an ignition switched location on the fuse block. When the ignition is off the sense line is low.
Connect the ORANGE entertainment mute wire to the vehicle's entertainment system. (that is if your stereo supports it)
Connect the RED Positive primary lead to a 4-10 amp fused connection
Connect the BLACK ground wire to the vehicle chassis.
YELLOW & BLUE are not used.
Posted on Aug 24, 2008
I have the same car kit BTHCK 100, question is how to pair the blue tooth, please help me .
Thanks
Posted on Sep 12, 2008
When i fit the green wire to the ignition the bluetooth say's not ready what do i do wrong?
Posted on Apr 18, 2009
Mki 9100 parrot to fit in my 03 plate merc clk. do i need an extra cable?
They advise using a professional installer. And I found this
http://dbinstall.parrot.com/compatibility_pdf.php?model=1031&ck=12
For the CLK there is a special kit
http://www.ebay.com/itm/MKI9100-CT10MC02-Mercedes-CLK-Class-Parrot-Bluetooth-Handsfree-Car-Kit-/141233049285
and mentions a lead
Kit Consists of the following:
  • MKI9100 Parrot Bluetooth Handsfree
  • CT10MC02 Parrot Wiring Harness Adaptor Lead
Parrot MKi9100 https://parrotcontact.parrot.com/.../MKi9100_User-guide_UK.pdf · PDF file Parrot MKi9100 - 4User guide Installation WARNING: We advise our customers to have the Parrot MKi9100 fitted by a professional. Before you begin
Dec 30, 2015 | Cars & Trucks
Tip
Jabra Bluetooth Headset Pairing Instructions
<span><span>Connecting a Bluetooth headset or car kit</span> <span> You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free. <ul> <li>For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile. </li> <li>Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual. </li></ul> <ol> <li> <span>From the Home screen, press <span>MENU</span>, and then tap <span><span>Settings</span> &gt; <span>Wireless & networks</span></span>. </span> </li> <li> <span>Tap <span>Bluetooth settings</span>. </span> </li> <li> <span>If the <span>Bluetooth</span> check box is not selected, select it to turn Bluetooth on. </span> </li> <li> <span>Make sure that the headset is discoverable. </span> </li> <li> <span>Tap <span>Scan for devices</span>. </span> Your phone will start to scan for Bluetooth devices within range. </li> <li> <span>When you see the name of your headset displayed in the <span>Bluetooth devices </span>section, tap the name. </span> Your phone then automatically tries to pair with the headset. </li> <li> <span>If automatic pairing fails, enter the passcode supplied with your headset. </span> </li></ol> The pairing and connection status is displayed below the hands-free headset or car kit name in the <span>Bluetooth devices</span> section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls. </span></span>
on May 23, 2011 | Cell Phones
Hi i have look over the net to get my iphone 5 to work in my x type jag 53 plate with no touch screen in the car help please chris
you need a aftermarket jaguar bluetooth kit fitted, to interface with the audio head unit, have fitted several. in the past, hope this helps
Mar 16, 2015 | 2003 Jaguar X-Type
How do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Jun 21, 2011 | Jabra Bluetooth Headset with Adjustable...
How do i pair my jabra bt250 to my htc desire hd
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon howtoimage.aspx?id=12046 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
May 23, 2011 | Jabra BT250 Consumer Headset
I have just bought a jag s type . with a nokia car kit already fitted .it has no name or number ,its just a button next to the gear stick and the specker is by the internal mirror . my blckberry picks up...
hold down the nokia button till you hear a long bleep, this will clear the memory and allow new pairing. Please note this Nokia kit is not 100% compatable with Blackberry phone and you may get an echo. worth a try anyway, if you need an engineer to look at it look at nokiacarkit.com
Feb 28, 2010 | Nokia Ck - 7w Bluetooth Wireless Hands -...
Bluetooth wiring diagram
you will need to search for a wiring diagram for your model of car radio
car kit blue - connect to ignition cable OR connects to switched 12v cable going to radio
car kit red - Direct to +terminal of battery OR to constant 12v cable going to radio
car kit black - connects to GROUND going to radio
car kit yellow - connects to mute function of radio if your radio supports it.
OR
connect blue and red together and directly to battery
and connect black to Body of vehicle
(not recommended as could result in draining of battery, even thought the kit is supposed to prevent this).
Jun 30, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
To fit a bluetooth parrot mki9200 hands-free music kit
go to metraonline.com and your car then select kits choose the kit for your car and then hit product instructions. you should see radio removal procedures for your car dash.
May 10, 2009 | Car Audio & Video
Vauxhall zafira towbar wiring diagram.
what make of towbar wiring kit was fitted ? You can get a Whitter grey (S) fitting kit but this connects to their own black (N) wiring kit I would think any supplier of the N wiring should be able to supply a S kit.
JB
Nov 07, 2008 | Car Audio & Video
Motorola BTHCK 100 car kit
hi ya bthck100 i can hear them in car but they cant hear me thanks dave help needed please
Sep 12, 2008 | Motorola Mobility Universal Bluetooth...
Motorola Mobility Bluetooth??¢ HF850 Car Kit Wireless Headset Logo
1,654 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
