Question about Refrigerators
Daewoo FR 251 refrigerator cuts off automatically very frequently
My Daewoo FR 251 refrigerator cuts off automatically very frequently. 3 times in the last 2 days. When I press the reset switch it starts back to function normally. What may be the problem and what is the solution.
    Sergeant:
  • 313 Answers
CHECK ALL ELECTRICAL CONNECTIONS FROM PLUG TO UNIT.
IS THE COMPRESSOR GETTING VERY HOT, COULD BE LOW ON GAS. THERMO CUT OUT.
IF ITS OLD, ITS TIME TO REPLACE IT.
Posted on May 29, 2009
  • KHALOO NICOLAS Aug 04, 2011
    I WANT TO HAVE THE ELECTRICAL PLAN FOR MODELNO :FR-250
My Daewoo FR-291 fridge with freezer at topleaks 1/2 cup or so a day & onto floor sometimes. Hired one for $150 as told to turn ours off for 2 days. Leaked nxt day again. Thxs NZ
a thorough inspection of the tubes, filter, solenoid, ice maker and water dispenser should reveal the leaking component
also a thorough inspection of the defrost drain, drain tube, and dryer pan
Apr 08, 2017 | Daewoo Refrigerators
Programming the cn101a timer
CN101A programmable weekly digital timer
Buttons
C = Master Clear, erases all program settings and current day/time.
C/R = Control/Reset, used to access programming mode and to clear individual programs.
You must press and hold this button for approximately 4 seconds to enter programming mode if there is a lower case "a" to the left of the time display. The system will revert back to active mode (with the lower case "a" to the left of the time display) after 30 seconds with no buttons pressed.
If this button is momentarily pressed while viewing a program, that program will be erased, but ONLY the On or Off program that is being viewed will be reset. The corresponding On or Off program in that cycle will NOT be reset.
Clock = In programming mode, this button is held depressed at the same time as one of the D+, H+, or M+ buttons to set the current day and time. When editing the programs, this button is used to exit when done.
P = Program select, each press will advance through the On and Off programs (presets). There are 16 On/Off cycles available (1 On, 1 Off, 2 On, 2 Off, ... 16 On, 16 Off).
D+ = Used to change the day when setting the time, or day(s) when changing a program.
When changing a program,
the following 15 different day combinations are available using the "D+" button.
MO; TU; WE; TH; FR; SA; SU; MO/WE/FR; TU/TH/SA; SA/SU; MO/TU/WE; TH/FR/SA; MO/TU/WE/TH/FR; MO/TU/WE/TH/FR/SA; MO/TU/WE/TH/FR/SA/SU.
H+ = used to change the hours when setting the time or a program.
M+ = used to change the minutes when setting the time or a program.
Manual = This button will cycle the output relay from AUTO to Manual OFF, back to AUTO, then to Manual ON, and finally back to AUTO. Programming mode must first be accessed using the C/R button to use the Manual feature. The manual On or Off settings will override all programs until switched back to AUTO.
There is a Lithium Ion battery which is intended to keep the clock going for up to 3 years during loss of external power, but the output relay will not work on internal battery power.
Jan 17, 2012 | Hardware & Accessories
Hi, I'm Reyna Gonzalez. My Daewoo Refrigerator (FR-510) don't start and a technical is very expensive, I think is only a part, because someone put it directly to the energy and function OK. Thanks by...
I've got the same problem with my Daewoo FR-510. Can you tell me which one is the drain pipe from the frost free elements so I could try fix it myself?
Sep 25, 2010 | Daewoo Refrigerators
I bought the water resist watch from walmart this evening it doesnt have a name brand on the watch but i think its a casio but it didnt come with the instructions on how to use it, the number on the back...
Thank you for contacting FixYa.
  • There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
  • 2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
  • 3 Press the start button to change minutes.
  • 4 Press the reset button again to switch to hours. You will know it worked when the hour starts blinking instead of the minutes.
  • 5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
  • 6 Press the reset button to switch to the date, starting with the month, and press start to change it.
  • 7 Press reset one last time to switch from month to the day, and again press the start button to switch days.
  • 8 Press the mode button to finish the changes.
  • Sep 14, 2010 | Watches
    Daewoo FR-064 Refrigerator clicking sound but wont come and not cooling
    As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
    Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
    Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
    http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
    Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
    http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
    Refrigerator Compressor Start Capacitor and Start Relay
    http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
    heatman101
    Jun 05, 2010 | Daewoo FR-064R Refrigerator With Ice Box
    How reset time?
    Set the date and time
    You can set the date and time from the control panel. When a fax is transmitted, the
    current date and time are printed along with the fax header. The date and time format
    is based on the language and country/region setting.
    Note If your HP all-in-one loses power, you will need to reset the date and time.
    1 Press Setup.
    2 Press 4, and then press 1.
    This selects Basic Fax Setup and then selects Date and Time.
    3 Enter the month, day, and year by pressing the appropriate numbers on the
    keypad. Depending on your country/region setting, you might enter the date in a
    different order.
    The underline cursor is presented initially beneath the first digit; it automatically
    advances to the next digit when you press a button. The time prompt
    automatically appears after you enter the last digit of the date.
    4 Enter the hours and minutes.
    5 If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM.
    The new date and time settings appear on the control panel display.
    Regards...
    May 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    I have an MTD8 timer, that fits into my main electrical board
    MTD8 Timer - Instruction manual
    1. This timer has a total of 8 ON / OFF programs.
    2. MANUAL ON / AUTO / MANUAL OFF for easy setting.
    3. Switchable 12 / 24 hour mode.
    4. 16 timer combinations are available as follows:
    Monday
    Tuesday
    Wednesday
    Thursday
    Friday
    Saturday
    Sunday
    Mo, Tu, We, Th, Fr, Sa, Su
    Mo, Tu, We, Th, Fr
    Mo, We, Fr, Su
    Mo, We, Fr
    Tu, Th, Sa
    Mo, Tu, We
    Th, Fr, Sa
    Sa, Su
    Initial operation:
    1. When the timer is first connected to mains power, it will take up to 12 hours to charge the internal battery.
    2. The settings can be defaulted by depressing the R (reset) button.
    Setting Current Time.
    1. Press the C+ (clock) button and hold, then simultaneously press the W+ (week) button until the actual day is displayed. Continue by pressing the H+ (hour) or M+ (minute) button until the current hour or minute is displayed. When setting, the W+, H+ and M+ buttons can be held down for rapid forward counting.
    2. Release both buttons. The weekday and time will be set according to your selections.
    3. To set incorrect time (etc.) repeat the settings.
    Settings for programs:
    1. Press the Timer button (Clock) and release. The first ON setting can now be made.
    2. Press the W+ button to set the day or blocks of days. Select the ON time by pressing the H+ button and then the M+ button.
    3. Press the Timer button (clock symbol) again to finish the first ON setting and enter into the first OFF setting. Repeat step 2 to set the first OFF setting.
    4. Press the Timer button again to finish the first OFF setting and enter into the second ON setting. Repeat steps 2 and 3 to program the remaining settings.
    When setting block dates, the ON and OFF times apply to all dates in the block.
    I.E. Selecting block Mo, Tu, We, Th, Fr, Sa, Su and setting ON to 10:00 and OFF to 16:00 means that the selected times automatically apply to all the indicated days in that block.
    Specifications: 230Vac 50 or 60Hz. 16A Inductive load. 20A Resistive load.
    Battery backup >100 hours. Accuracy: +/- 1 minute per month. Temp: -10 to +40 deg C.
    Apr 18, 2009 | Hardware & Accessories
    Some times water flowing from bottom side of the fridge
    There should be a drain pan directly below the icebox which needs to be emptied from time to time. Some units have a drainpipe connected at the back, if yours has one, it may have become blocked.
    Mar 13, 2009 | Daewoo FR-064R Refrigerator With Ice Box
    Fridge keeps tripping electricity
    I assume by "earth leakage" you mean it is on a GFI circuit? Some older GFI outlets are sensitive to and do not work well with motors or other inductive loads like your refridgerator compressor. As for the compressor feeling hot, this is usually normal.
    If this is a GFI outlet, try replacing it with new unit. If it is a GFI breaker, try replacing that.
    Dec 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Refrigerators Logo
    583 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
