Question about Fisher and Paykel Dryers
Fisher & Paykel dryer will not tumble
The dryer will not tumble and a buzzing sound can be heard. If I shake the dryer slightly it may commence tumbling but extremely slowly and an electrical burning smell is produced.
  • 2 more comments
  • ANGEL34 May 29, 2009
    Thanks. I have removed the belt and although it is about 10yrs old it was still tight around the drum and looks in pretty good shape, only a bit worn.
    I will look for a replacement belt tomorrow. If you think it could be anything else before I go looking for parts please let me know.
    Cheers
    Paul
  • ANGEL34 May 30, 2009
    I have replaced the belt as advised by the earlier expert and this did not fix the problem.
  • ANGEL34 Jun 10, 2009
    I have replaced the belt and capacitor and the dryer now tumbles. However it will now only spin anti-clockwise and when it is due to change directions, it will just stop and a slight burning smell results. Any suggestions as to the problem would be appreciated.
    Will I require a professional to align the rotor or rewind the motor? This issue seems to be getting more complex.
    President:
  • 1,865 Answers
The most probable cause is motor bearings are failing. When the motor bearings fail, the rotor is dragging on the stator, and causing the motor to run slowly. Shaking the dryer causes the rotor to dislodge from the stator somewhat and turn slowly.
Replace the motor.
Posted on Jun 11, 2009
  • 854 Answers
You may need to check the alignment of the motor of the dryer. This I think needs to be rewinded or align the rotor.
Posted on Jun 10, 2009
  • 378 Answers
Check electrical connection for any lose contact. burning smell sometimes due to loose connection of electrical wiring. check the switches for any loose. open it and clean using compress air or vacuum. Beware of electrical shock sw. off before removing cover.
    Novelist:
  • 130 Answers
Many clients are facing this same problem as yours.they replace many unnecessary parts but nothing solves the problem.but the actual problem is not the belt.its the capacitor problem in the machine.that is faulty so machine is not tumbling and making the buzzing noise.
to get the capacitor
Take the back panel off & search around motor for a small round white plastic capacitor with two wires attached. If this has failed then motor will groan & struggle to start. They usually bulge out on the ends or sides or even split open when faulty. just replace the capacitor,it don't cost very much.the number of capacitor will be mentioned on its body.just get the samne exact capacitor and fit it.its easily available at local electronics hardware store.
thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on May 30, 2009
    Sniper:
  • 73 Answers
Dear, Checked the belt, This could be a worn out or loose belt. thats why the motor is giving the sound and smell is due to the friction with belt.
You can get to it through an access panel on the back of the machine.
Just make sure the power is disconnected first!
Hopefully a replacement belt will be easy to obtain in your area.
Regards
Posted on May 29, 2009
  • Muhammad Ilyas
    Muhammad Ilyas May 29, 2009
    I am much sure about belt problem but it could be a capacitor problem, it also produce the similar problems. You can check it too, but safety must be on priorities.
    Good luck in correcting your problem.
Tubmble dryer wont turn
Sounds like you have a bad idler and/or belt.
May 31, 2012 | Fisher and Paykel Dryers
Fisher & Paykel D04 dryer, makes a load buzzing sound when I turn the dial to any "on" position. Any ideas?
Yup... you have a bad motor... the buzzing is the motor trying to start and not starting...
You will need to replace the motor...
Check out this tip for further info on this problem...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 30, 2010 | Dryers
Hi i have an old fisher & paykel whiteway 405 dryer and its making an awful noise and wont tumble. any suggestions
I have never worked on one of these but I have a manual I can give you. I imagine it is a bad roller or idler.
Happy holidays DEGX1 repair manny
Dec 04, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher paykel dryer DE04-US6 just get a buzz sound when i push start button.
Open up the door and push the door switch and hit the start button and try to turn the drum by the baffle in the dryer and it it starts to go then you need a new motor.
Aug 20, 2009 | Fisher and Paykel Dryers
Fisher & Paykel top load electric dyer makes loud squeaky sound
to be honest i doubt that a bad belt would make a squicky noise and for a high class dryer like that i would suggest just call repairman  they are very complex
Jun 08, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel Dryer will not spin, motor buzzing
take top off. set it going and give the drum a push by hand. if it starts and keeps going then the fault is the motor capacitor - cheap part
Nov 14, 2008 | Fisher DEIX2 Dryer
NOISEY DRYER
The drum is probably hitting the housing or internal structure because of a failed bearing.
Sep 04, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Fisher & Paykel ED52 electronic tumble dryer. Since several power failures two days ago, when power button is activated & "start/paus" button pressed it beeps 4 times & won't work. I...
I found advice on the Fisher Paykel web site that suggested the problem could be the door lock. In fact the catch had not properly engaged & when I fixed that the dryer worked.
Jun 19, 2008 | Dryers
Fisher Paykel dryer
buzzing sound generally come from the motor assy, not necessarily a bad motor however. try opening the front door and along the inside of the top of opening is 2 phillips screws the top will tip back and then removing 2 5/16 screws from inside the font panel will remove giving you access to the motor blower assy.. it is possible that something( baby sock, small undergarment) has fallen inti the blower preventing free spin also resulting in a buzzing noise, if so simply remove debris and reassemble.
May 09, 2008 | Fisher and Paykel GWL11 Top Load Washer
Open Questions:
Dryers Logo
112 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
