Question about Uniden DCT5285-2 Cordless Phone
Fading in and out
My second handset fades in and out while talking to someone, sometimes its clear and the next sounds like the person is far away.
A friend of mine has the same phone. his main phone does the same things fading in and out
5 Suggested Answers
SOURCE: Background static
I have staic on one phone and the other sounds lke someone voice goes and come during a conversaton as if the person was ina tunnel.Both phones are pansonic cordless phone 5.8ghz,please help I cannot have a deciet converstation.
Posted on Feb 01, 2008
  • 1800 Answers
SOURCE: Uniden Power Max 5.8 - (TRU8880-2)
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
please rate this post
Posted on Aug 25, 2008
  • 12 Answers
SOURCE: After talking for about 5 minutes, the voice fades away on the
If you have a speakerphone on the base, try using that to make a call. If you have the same problem there is something fundamentally wrong with the phone. If not, try a new set of batteries in the handset. MAKE SURE you are using the same type of batteries that came with the phone in the first place. Don't let anyone in a tech store tell you 'that should be fine', check on the uniden website if you don't still have the box/manual/original batteries and make sure you get the right ones.
If that still doesn't work, Uniden will repair phones within warranty, send it off to them.
Posted on Apr 08, 2009
  • 2992 Answers
SOURCE: My wireless phone is about
Try disconnecting the cordless phone base unit from the phone jack where it's connected and plug in a basic corded phone. If you still have the noise, the trouble is in the phone line itself and you'll need to contact your telephone service provider.
If the phone line isn't at fault, the trouble is in the base unit. Most likely, the power supply filtering isn't working, and you're hearing hum in the audio as a result. If the base unit uses an external plug-in adapter (a "wall-wart") with a DC output, you can try replacing it with a new one. Radio Shack sells replacements. Just be sure to get one with the same voltage rating, the same or higher current rating, and the right polarity plug. It may be that the old adapter isn't filtering any more because of its age.
If the adapter is an AC output type, or the base has a built-in power supply with a regular AC power cord, you should probably shop for a new phone. The trouble is in the unit itself, and you'll spend more trying to have it fixed than it's worth.
Posted on Dec 26, 2010
Cb puts out good sound but when someone try to talk to me it all you hear is static
same thing sometimes happens to me. Usually it is because the person who is talking to you might have a weaker antenna. Sometimes people put a very strong transmitter with them and talk to people but you cant talk back.
So really they can't hear you good either. Just because you are too far away.
Jan 11, 2011 | Cobra 29 LTD CB Radio
Will get sound for the first 30 seconds then it fades out. Tried seperate speakers to same problem. Cleaned contacts with contact cleaner to get it to go that long?? Sound card or board maybe?
the sound ic will be not working properly..the sound fades after the ic gets a tech person & tell him to replace the sound ic.
Jan 18, 2010 | Televison & Video
Stereo Amplifier fades out. My Sansui dolby pro
No that's how to describe a problem, folks - with details. Using internal FM as the source is always the preferred way of troubleshooting system-wide receiver audio problems (no cables or setting in the way).
Does the sound come on immediately with power and then fade or is there a small delay while the electronics stabilize, a click and then sound that fades?
The fizzle probably means something is rapidly overheating or a capacitor is malfunctioning. If both channels do it, I'd suspect a common power supply problem. Can't help much more than that.
Dec 12, 2009 | Audio Players & Recorders
The sound from my speaker fades in and out, but the handset works fine.
Since this problem just started, I would first check to make sure there is nothing stuck inside the mic's port. Also, if you have a fan on in the room, that can also cause your speaker to fade in volume.
I say both of these because if the phone thinks you're saying something, your speaker will fade in volume. Whether you're talking or it's just air noise, the volume will fade.
May 22, 2009 | Vodavi 30-Button XTS Telephone
My skype sound keeps fading in and out.
Change skype sound setting. TO do that :
Take Tools from the menu bar.
Then select options.
When a new window opens choose audio Setting.
Then below microphone volume untick - "Automatically adjust microphone setting".
Then drag the volume to maximum.
Mar 15, 2009 | Skype IM
Samsung television sound fading, now no sound at all
My Samsung tv has sound and then it fades away
Jul 06, 2008 | Televison & Video
No picture,but sound ok
check your ribbon connections coming from power supply board there is 2 of them it will be the second one,theses ribbions connect to signal board.Sometimes causing set not to come on.
May 11, 2008 | RCA D52W19 52" Rear Projection Television
Uniden powermax 5.8 handset
place both handsets on the recievers for 24 hours so they can register to there spots
Dec 28, 2007 | Uniden TRU8885 Digital Answering Machine
My Screen fades away!!
I might know how to finish that problem
I think you might have to go to settings in the sansa and go to backlight. Then choose On.
If this isn't what i'm talking about, try looking for another person that helps.
Hope i helped!
Dec 07, 2007 | SanDisk Sansa e270 MP3 Player
Uniden DCT5285-2 Cordless Phone Logo
227 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
