Question about Dishwashers
Dirty dishes the dishwasher sounds and appears to be operating normally but the dishes are not getting clean. now i've noticed dishwasher soap still in the dispenser after the washing cycle has been completed. I'm thinking maybe i have plugged water jets? Anyone have any suggestions? Thanks.
  • kdorion2 May 29, 2009
    yes, the soap dispenser does open however much of the soap is still there after the cycle has finished.
  • 89 Answers
Plugged jets, possible
more likely it is leftover food reminance left in the pump area. and on certain dishwashers it could be a swollen check valve, not allowing the evacuation of the used dirty water.
does your soap dispenser open?
Posted on May 29, 2009
  • slypp187 May 29, 2009
    check the spray arms for debris in the jets,
    remove lower rack and take off filter cover
    pending on model, dissasemble to the pump resevoire, removing all debris along the way
    re assemble.
    if there is an accessable chopper blade (round metal mesh, with steel blade) check to see if it is operational or broken. (something as small as a toothpick can break the chopper)
Hello, our Whirlpool dishwasher is about 3 years old. It is not cleaning the dishes; I don't think the arms are turning because the door is always dirty, so no water is getting that far. Also, the cycle...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 26, 2011 | Whirlpool Dishwashers
The dishes are coming out dirty. it sounds as if water is spraying but the dishes are not wet as usual and not clean.
Hi
Feb 17, 2011 | Dishwashers
Asko 1996 appears "dead".....no lights flashing, won't respond to repeatedly pushing on/off button. Some water left in the bottom...siphoned it out, cleaned filters, no blockage there. Almost like it's...
Don't know if this will help, but my dishwasher has a "propeller" device above the top and bottom racks that spins while dispensing the water. If the dishes on either rack are stacked too high (i.e. if even one plate comes in contact with that propeller, keeping it from spinning properly) the dishwasher will go through its full cycle but will not use the soap (soap door will still be closed and soap packet still intact) and will not get the dishes clean.
However, it sounds like you either have a bit of a drain issue as well--or perhaps your dishwasher acts the same way as mine (if that's the case) but ceases to drain as well if blocked.
Jun 26, 2010 | Asko D1996SS Built-in Dishwasher
Dishes in top rack not getting clean
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
May 28, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Soap dish does not open during normal cycle on my maytag dishwash
the soap u use may be causing this try cleaning it out real good and use liquid soap
Apr 20, 2009 | Maytag DWU9962 Dishwasher
Dirty dishes
It would help to know the manufacturer and model number.
Generally the most common problem when a dishwasher is not cleaning properly is:
1. You switched to a different/cheaper detergent. Go buy a box of Electrosol powder and see what happens after two loads of dishes.
2. If problems continue, the heating element inside the dishwasher has probably failed. Getting it replaced will almost certainly return your dishwasher to one that cleans.
Apr 01, 2009 | Dishwashers
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishsoap stays in soap dispenser
ok, either a spring, trigger prob, on the latch, or a electronic prob. ok so to see if the latch is ok (or not) look closely for soap residue and scum, that may be hindering the latch or spring under. use metho, and warm water to clean this part. secondly go down to a white goods repair place and take your electrical component, button, lights its all one unit, simple unscrew it, i do think you will need a set of torque screws for that tho... anyhow ask the guy to get you a new or second hand one and install it. the timer will run, and the clip will release. good luck!
Sep 25, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
307 people viewed this question
Top Dishwashers Experts
