Question about HP Compaq Motherboard
Finding the exact model number and manual for my MB
Finding the mb # and rev?? My MB says Processor Board Designed by Compaq Houston, TX The only number I can find on the board is very small.... G1I2N3A4 and under the processor mount is: SP# 283983-001 DG# 261982-000 AS# 261981-001 P58B40R9VO9B2N rev - 0R Compaq 2001-2002 I forgot to mention that the puter won't boot. It is a friend's and he tried to put PC133 memory in it and now the good stick of memory isn't reading either. I get 1 long and 2 short beeps and NO video when trying to boot up.....So, I was trying to ID the motherboard to find out what a replacement would cost.....I don't have another stick of DDR to try in this machine....so I am not sure if it needs a new MOBO or just another stick of memory......It is a work in progress......LOL Thank you very much for your reply :)
  • Dawn
    Dawn May 29, 2009
    thank you joe. I will id it shortly. First I am going to try removing the batt & Cord. I know it is a memory problem....but just not sure if he messed up the memory slot...or the memory is bad....or the mobo is bad...since I can not boot it up~~! He tries to be a techie....on his own puter......he is learning~~! :)
  • Dawn
    Dawn May 29, 2009
    leecom....it does look like this board. I have never seen a board with so little markings ~~! What's up with that?? LOL
    Thank You......Will let you know in an hour....................
  • HP Master
  • 4,806 Answers
Hi there.
Is this your board>>>>>>>
If so they are not cheap to replace, about $150+ , you may get one second hand a bit cheaper, maybe $60-80
You mentions it beeps, the beep codes described is a Video (Mono/CGA Display Circuitry) issue
this can be memory related, so take out the main power supply (the power cord) and the motherboard battery for an hour, then put back in the memory, the battery and then the power cord and try to boot up.
Post back if you need help.
Good luck
Posted on May 29, 2009
  • Lee Hodgson
    Lee Hodgson May 30, 2009
    well the thing is with that is its an OEM board (original electronics manufacturers). Company's like HP employ/pay other makers to put their name on the boards, hence Compaq being the name.
    this number identifies the board >>>>
    SP# 283983-001
    DG# 261982-000
    AS# 261981-001
    Sniper:
  • 67 Answers
The SP-Number is the SPARE PART number of compaq. use this as an sufficient number to exactly identfy this board.
What processors will are compatible with an hp 3396 motherboard
That motherboard uses the CPU Socket 1155 LGA. Pretty much any processor for that socket should work. (Source: http://browser.primatelabs.com/geekbench2/1112660)
Popular CPUs for this board are:
  1. Intel Core i5-3570
  2. Intel Core i7-377
(Source: http://openbenchmarking.org/linux/motherboard/HP/HP%203396)
Feb 25, 2015 | HP 339661-001 HP PCIx Cage DL760 G2 Mfr...
I dont have mother board driver for system model awrdacpi
The Intel® Desktop Board D915GAG supports one Intel processor in an LGA775 socket. See the table below for a complete list of supported processors.
Processors not specifically listed by type and rated speed can have requirements that are not supported by the design of the desktop board. Use of unsupported processors can result in improper operation, damage to the desktop board or processor, or reduced product life.
Processor Family System Bus Frequency L2 Cache Size BIOS Version Intel® Pentium® 4 800 MHz 2 MB 0391 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 533 MHz 1 MB 0477 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0475 or greater
533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater
DOWNLOAD LINK IS GIVEN BELOW...........
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22Intel+Desktop+Board+D915GAG%22
Sep 22, 2011 | Intel D915GAG Socket 775 Motherboard -...
MSI atom 330 mother board memory?
I believe MSI makes several motherboards that support the Atom 330 processor so you wll need to be more specific. Examine the motherboard or manual closely to find the MB part number.
Your best bet is www.crucial.com. Call them if you cannot find your MB on their Memory Finder.
If this helps please vote for my solution.
Dec 26, 2010 | Computers & Internet
MY LAPTOP'S MODEL IS HP COMPAQ 315. WHAT IS THE MAXIMUM RAM AND MAXIMUM PROCESSOR OF HP 308C KBC MOTHERBOARD.
For RAM info, go to www.crucial.com and run the system scanner. For the MB you will need the mfg model number to research it on their website. Compatible processors are subject to the slot type that the MB accepts.
Jun 26, 2010 | HP Compaq Motherboard
Will a hp compaq 6735s support spore?
This is something simple you can do yourself. In the future, look up your model laptop then the specs on game, use google.
"HP Compaq 6735s spec"
http://www.cdfreaks.com/hardware/product/86792-HP-Compaq-6735s-Notebook-PC.html
Processor Processor family AMD Turion X2 Dual-Core Mobile Processor RM-70 Processor clock speed 2000 MHz
Memory Memory upgrade <8192 MB GB Internal memory 2048 MB
Video Video card features ATI Radeon™ HD 3200 Video modes resolution 1280 x 800 WXGA Disk drive Total storage capacity 160 GB
"Spore spec"
http://www.spore.com/what/specs_spore
  • FOR WINDOWS VISTA
  • * 2.0 GHz P4 processor or equivalent
  • * 768 MB RAM
  • * A 128 MB Video Card, with support for Pixel Shader 2.0
  • * At least 4 GB of hard drive space, with at least 1 GB additional space for creations.
Everything seems good, the only thing is how much HD space you have.
My computer>Roll over your mouse above the C drive and you will see how much is free out of your 160gb space.
Sep 10, 2009 | HP Compaq 6735s Notebook
In need of a pci/pnp 586 manual. anyone got?
BIOS INFORMATION :
BIOS MANUFACTURER : PHOENIX BIOS V.4.05 R 1.0 - (C) 1985/1995
BIOS ID : UNKNOWN
BIOS DATE : 11/23/95
BIOS ROM SIZE : UNKNOWN
CHIPSET : ALi M1511 REV.4
SUPER I/O CHIP : SMC 665GT REV.2 FOUND AT PORT 3FOH
CASE LABEL :
COMPUDYNE - PENTIUM PROCESSOR
P/N: 91.AA884.003
S/N: 1900001233
INSIDE THE CASE :
3 ISA SLOTS
3 PCI SLOTS
4 EDO MEMORY SLOTS
1 ALi CHISET - M1513 A1 - 9542 TS2 - AC7129SB
1 ALi CHISET - M1511 A1 - 9538 TS5 - B40958SB
2 ALi CHISET - M1512 A1 - 9537 TS2 - B40954SA
SOUND ONBOARD - CRYSTAL - CS4232 KQ EP - 33 PIN CN11 WAVE TABLE - 07 PIN CN12 AUDIO MIDI
PHOENIX MULTIKEY - PHOENIX 1987-1993 ER129
PHOENIX MB - 586 PCI PNP - PHOENIX TECNOLOGIES - A448416
INTEL PENTIUM PROCESSOR 133
NUMBERS IN WHITE INK ON THE BOARD TOP SURFACE :
95115-1
V50S MB
and
48.57001.011
MADE IN TAIWAN R.O.C.
Aug 29, 2009 | Intel Motherboard
There is a small, free utility that will check your motherboard, cpu, and memory and will list all details on tabbed pages.
I have tried this utility on a Compaq ENS 800, and it does show the motherboard model and number.
Maybe the utility CPU-Z from CPUID will help you find the numbers you want.
May 29, 2009 | Compaq Computers & Internet
Hi guys, i sold a compaq mainboard as asecond hand hw, but the seller did't have a mb-cd or manual. Maybe ican get a drawing about that board? best regards herebrt
On The Mainboard is a model number
Google "Chipset Divers + (the model number)"
You will find it in no time!......If you don't, post a reply and the model number and I'll get it for you k!
Apr 21, 2009 | Computers & Internet
WHAT KIND OF PROCESSOR COMPATIBLE TO FOXCONN P4M800MO1
you can enter in your Mb any type of intel processors ranging max speed bus 800 mhz , for example you can enter intel pentium 4 hyperthreading 3.00 ghz , 800 mhz front side bus 1 mb cache, number 530, 530 j or better than him.
Apr 08, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Motherboard won't boot
u can go to ur mb bios nd check ur processor setting.may be 845gvsr not support intel crl processor.u can give load bios default from ur bios press F6 or F7,
Sep 19, 2008 | Intel D845GVSR Motherboard
HP Compaq Motherboard Logo
1,366 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
