Question about Samsung WE356A5W Washer/Dryer Laundry Pedestal
Samsung washing machine F1245 control panel stuck??
Switched on above machine selected cycle, forgot to put something in so switched off put item in, and now all the lights on the digital control panel are ON , but seem to be stuck on the highest cycle and wont move off it. All power on okay, seems like all the buttons are frozen, and the control dial will turn but the digital light wont budge from the the top cycle (cotton).
ive switched off at the socket , and when switch back on the same cotton cycle is there- BUTTONS DONT PRESS, DIAL WONT TURN TO ANOTHER CYCLE AND POWER BUTTON WONT PRESS IN EITHER..
H E L P please !!!!!
jan, uk
I have Samsung/korea-SW905Washer.When power is switched on the Fault-'1E' appears. what could be the reason.( narrate list of control component failure).
Bought in the year 1996 at India ( voltas mega washer top loading-7.5kg) and working till last month.
after few wash cycles the machine stopped at aforesaid indication and it is not functioning due to above fault indication'1E'
provide me remedial measures or electronic control board circuit.
Posted on Jan 07, 2010
  • 89 Answers
Try to unplug again, but this time allow the capacitors to discharge, approx 10 minutes.
if the controll does not reset, you are in need of a new control panel.
Posted on May 29, 2009
Ongoing problem with Frigidaire Dishwasher FDB1050REC.
Let see if I can help!
If the light stays lit it would mean that the latch switch is defective and is not opening (electrically) when the door latch is cycled. When you go through the power off circuit breaker it performs the same function as if the latch switch was cycled hence the machine will operate until the next time the end of cycle clean light appears.
During your earlier repairs the inner panel of the door is removed and it is possible the switch operation was interfered with either allowing it to work or disabling its operation.
When the door latch is cycled at end of cycle the clean light should go out.
Check switch operation, installation and adjust or replace switch if defective.
If the washer is currently not working and you had smelled burning you need to check the following.:
  • Electrical connections to the control board, pump and heater. After the maintenance of removing the connectors may had been dirty and do to a high resistance connection overheated and failed.
  • Check the control board for PC track failure where the copper traces and connections have failed. Replace control board
  • The motor for a shorted winding. Replace pump motor.
These machines are very good and I would repair.
Hope this helps?
Oct 03, 2016 | Frigidaire Dishwashers
All else appears to be working except the dryness level selection button does not light up and will not allow selection
How do I read the digital display panel and controls on my ...
www.samsung.com/uk/support/skp/faq/1025253
Samsung ElectronicsAug 12, 2014 - The Drying light will illuminate and remain lit until the cycle is ... the indicators will light up until you press the Start/Pause button. ... When you turn on your dryer the Cotton Cupboard Dry cycle is selected by default. ... Drying Level button ... If you do not turn the Drum Light off within 5 minutes of turning it on it ...
Dryer Control Panel And Functions - Samsung
www.samsung.com/ca/support/skp/faq/230147
Samsung ElectronicsJan 7, 2015 - To set Dry Level in the Normal, Heavy Duty, or other Sensor Dry ... An indicator light illuminates next to the selection. ... Temp Selection Button ... When using Manual Dry, you can select the drying time by pressing the Time Selection Button. Important: Clothes may not dry completely if the drying time is not ...
MACHINE OPERATION
docs.whirlpool.eu/_doc/501930002795EN.pdf
Material thickness: whenever there is greater load than the dryer can handle, ... Do nottumble dry: nylon stockings, delicate embroidery, fabrics with metallic ... The indicator lamp above the relevant button lights up to confirm your selection. ... Wait at least 5 minutes, to allow the laundry to cool down, before you unload the ...
501930001546EN.pdfDOWNLOAD
Jan 01, 2016 | Dryers
Control lock light is on , toke door lock off once cleaned it put it back on and it worked now its on aagain and washer wont work
1 close washer door and dispenser drawer
2 select Clean washer cycle
3 Press start/ pause
The basket will rotate,then the door will unlock,lock again,then the cycle will continue
Water should come in and run a short sensing cycle about 3 minutes
4 This will determine item in the washer
a if no items are detected it will move to step 5
b if item are detected wash any control lock light will stay on door will unlock open and remove any garments
If b pessnpower to cancel f code then repeat 1,2,3
Once cycle begins allow it to finish
5 after cycle is complete leave the door a jar to allow for venting and drying of interior
Only use HE high efficiency detergent
Jul 05, 2015 | Whirlpool GHW9100L Front Load Washer
Simpson swf85561 wont drain, spin or wash goes to end cycle
It sounds like your outlet is clogged. Unplug the Washer first. You need to take off the back, there is a plastic piece attached to the hose where the water comes out. It may look like an enclosed bowl. Items that get sucked in, socks, scarves, etc... tend to get caught into this. If it is supposed to be clear, but it isn't, then there is something stuck in there. You must pull it apart and remove the laundered item.
A way to avoid this happening in the future, if this is the cause, is to put small washable items in the center of the load. Do not overload the washer.
Thank you for contacting Fixya. Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Feb 22, 2014 | Simpson Washing Machines
Opened door after hitting start and now wont run
When you open the door in the middle of the cycle the machine will detect that the door switch sensor is open and suspend the cycle. When you try restarting the machine with a new cycle the control detects that there is water inside the machine and may prompt additional fault codes.
As you found out disconnecting and re-applying power most of the time is enough to restart operation. If you restart the cycle after power down the water in the machine will be drained in the initial part of the cycle and operation will follow as usual.
May 13, 2012 | Washing Machines
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Top load washer when you start cycle no water and it starts to agitate does it on all cycles
Hi, It could be faulty timer, the knob you turn to select cycles(programs) or faulty water level switch, the knob or button you select the water temperature, or size of water level, it depends on brand of machine. check water level switch by lifting top of machine, you will see tub, look at back you will see a small tube coming from wiring harness, where controls are, that tube comes from switch to connection on side of tub, remove tube from tub connection, wipe it, put in your mouth and blow air into it, you should hear a click sound whenever you blow into it, sometimes could get stuck, connect tube back to tub, manually fill with water, just a little above half, then start machine from the beginning of any program, let it complete to the end, then try it normally to see if it does the same thing, if it does, you will need a mechanic to check timer and pressure switch. good luck.
Aug 06, 2009 | Washing Machines
DCR-TRV238E handycan Sel/Push Exec scrolls through only the first two items in the menu list
The symptoms you told shows the defect in control jog switch and its available as "control switch block". If you wish, I can give you its part number.
Jun 23, 2008 | Sony Handycam DCR-TRV240E Digital...
Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
1,187 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
