Question about Kenmore Ovens
F4 error code
Put new bake element in oven getting f4 error code
  • 6,784 Answers
Ok, test the element for its operational value. if the element is not getting a signal to warm from the control board, this will be the issue, considering that the element is new and able to warm. replace the Oven control in this case.
JUst to be safe, back track the installation to make sure every connection was properly united. make sure the element was installed correctly. if so, replace the control.
Posted on May 29, 2009
My Electrolux double oven goes from "bake" to "warm oven " after about 1 hour. I try to use the other oven and it will go start to "warm oven"
is the bake element getting hot?when you put the oven on bake both the broil and bake elements come on,if just the broil element is getting hot it might take it an hour to heat up.you might just have a bad bake element,if the bake element isn't hidden does is turn red? if not it's not getting hot.
Nov 14, 2017 | Electrolux Ovens
What's F4 error code stands for?
Hello Richard;
My name is Peter. I am a retired field service appliance technician.
You did not provide a model number and manufacturer. So, the following is a general description of a F4 code.
The error code "F4" will be displayed along with a beeping sound if the ERC (Electronic Range Control) or "clock" determines an open oven temperature sensor circuit during the "cook" (bake or broil) mode. The "F4" message will not be displayed in the time of day mode. The cause of the problem is a bad oven temperature sensor or its wire harness. The access to the oven temperature sensor plug and the wires is from the back only. You have to pull the oven out of the wall (if it's free standing) or remove it from the cabinet (if it's built in). Disconnect the power and remove the rear cover. Check the resistance across the oven temperature sensor. It is supposed to be about 1100 Ohms at room temperature. If the resistance is incorrect, the oven temperature sensor is bad and needs to be replaced. If not, check all the wires from the oven temperature sensor to the ERC. If it is not the sensor and wires, you have to replace the ERC.
To get the right replacement part just click on the link AppliancePartsPros, then type the model number of your oven in the search box, click on the "search" button and in the new window type the word "sensor" or the word "clock" in the "search by keyword" box and click the "search" button.
You can go into the following website put in your model number and get diagrams ans component part numbers.
Your model number is on a label either on the face of the oven when you open the door or on the side of the oven door.
Water Filters Lawn Garden Appliance Parts
Mar 11, 2016 | Ovens
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
My oven displayed F5 then F3 code I believe after a nearby lightning strike, When installing new sensor with supplied wire nuts I found black marks on oven side connector. Immediate F4 error code when...
When checking the sensor it shouls be checked at room temp (even if power off) at it should be between 1060-1100 ohms at room tempature. 16 ohms the new sensor is shorted the F2/F3/F4 all relate a faided sensor and the F5 error code says the clock (electronic oven control) is defective.
Test the sensor again at room temp...if only 16ohms its no good and will throw the F4 code everytime again a good sensor measured at room temp should be between 1060-1100 ohms
GENE
Sep 06, 2011 | GE JTP15 Electric Single Oven
GE single oven with touch pad settings. Getting error code F-4 after selecting any bake or broil function keys. Oven light works, fan for convection oven seems to be working. Makes no unusual noise. will...
Hi, the F2 error code means that the oven is overheating for an unknown reason. F3 and F4 indicate a problem with the oven sensor, which usually requires replacing the sensor.
Jan 21, 2011 | GE Ovens
Error f4
Your oven temperature sensor must be replaced.
Sep 28, 2009 | Tappan Ovens
Older Ge F4 error Code
Your oven temperature sensor is bad and must be replaced.
Feb 28, 2009 | GE JTP85 Electric Double Oven
Bake not working
Well, to ensure the element isn't bad, you can take an ohm meter to the contacts of it and measure the resistance. It should be around 20 ohms. If it is much greater or infinite, the element is bad. To get to the contacts you will need to unplug the oven, pull it away from the wall and remove the rear panel. Then disconnect the element wiring and touch the probes from the meter to the contacts on the element. Otherwise, usually, the temp sensor is bad if the broiler still works, this is a small pencil shaped rod on the inside top of the oven. You can test it the same way and it again should be around 20 ohms. You can order a new parts locally or from repairclinic.com. Let me know what you find.
Benjamin
Nov 13, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
178 people viewed this question
Top Kenmore Ovens Experts
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
