Home | Hampton Bay | Cessna 04313 Ceiling Fan | I can't remove the gla...
Hampton Bay Cessna 04313 Ceiling Fan
Problem for Hampton Bay Cessna 04313 Ceiling Fan
I can't remove the glass globe.
By ifixart on May 29, 2009
I have removed the globe in the past by turning it slightly counter
clockwise and it dropped down. Now when I turn it the entire housing turns and I can't dislodge it. Any Suggestions?
GH
Comments:
May 29, 2009
- No. The only screws are under the globe and not assessable.
May 29, 2009
- not sure yet.
Clarification Request
Posted by scspriggs on May 29, 2009
Are ther not 3 or 4 screws in the edge of the housing which screw into the rim of the globe?
Best Solution
posted on May 29, 2009
Helpful)
scspriggs
Rank: Guru
Rating: 91%, 599 votes
If there is a way you can hold with one hand the part that is turning, and turn the globe with the other hand, try that.
If you can't do that or it doesn't work, I would suggest spraying the threads on the globe with spray cooking oil (like Pam). Let it soak for a while, when turning counterclockwise shake it slightly -- it should come out.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Hampton Bay Cessna 04313
Questions and Unsolved Problems for Hampton Bay Cessna 04313
Do you recommend Hampton Bay Cessna 04313 Ceiling Fan?
Answer
Answer
Help??? Do we have to but a new light ket to get something to fit?// Anyone?????
Answer
I broke the globe and i'm having a hard time finding a replacement part for it. I also need the... (More)
Answer
I do not know the model number/style of the fan. However the remote has PART NO. 85095-01 on the... (More)
Answer
the fan won't change speed or even turn off through the remote. The light does work through remote... (More)
Answer
My ceiling fan has started to make noise when on medium speed and high. Also a slight wobble. I have... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hampton Bay Cessna 04313...:
Top Electric Fan Experts
Rank: Wiz Wiz
Solutions: 897
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Electric Fan Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
