Question about Pioneer DCS-222 System
Can i use headphones on a lg HT503PH sound surround system
I have found what looks like a headphone jackplug point but when i plug my headphones into it the sound still comes from my speakers and not my head set . am i doing something wrong
  • 1 more comment
  • terry_hltn May 29, 2009
    on the LG HT503PH Cinema sound surround system the jackplug for what seems to be for headphones is on the front lefthand side panel a has a little flap cover i cannot see any labels on ie icons ,letters , words
    so looking at this i cannot use headphones on the LG HT503PH Cinema sound suround system or can anyone suggest away to solving this problem
  • Samuel Charles Spriggs May 11, 2010
    How is the jack labeled? Icon? Letters? Words?
    President:
  • 1,489 Answers
From viewing the user manual, I would say the jack in question is an input jack not an output jack.
Here's the manual:
http://safemanuals.com/user-guide-instructions-owner-manual/LG/HT503PH-_E
Posted on May 29, 2009
I have a 32inch tv but cant find headphones jackplug
In some models there would me no headphone jack. May it only have RCA audio out and optical out.
If you wish to get some details about television repair then check the following link
http://electro-medical.blogspot.com/
Aug 22, 2016 | LG 32LD450 32 In. LCD HDTV
Turning off
I got a DAV system that had exactly the same problem, ie. it was stuck in "headphone mode", this mode should be active when headphones are attached then it should revert to amplifier mode when the headphones are removed.
I opened the cover and removed the amplifier output board (the one where the speaker wires connect to) and soldered the following dry joints.
1) large brown capacitor on the amp output board.
2) dry joints on the rear headphone socket (the one that has the connecting lead from the front headphone socket)
3) Then one of the surround channels didn't work so I soldered further dry joints on all the coils (white vertical rectangular blocks)
I tested all surround chanels before putting the lid back on (careful, watch the mains) and found all was now working ok.
Mar 11, 2008 | Sony DAV-S500 System
Problems getting sound to both channels
Try this see figure to get the idea...
How was it?
FIXYA me on this one... THANKS
Feb 06, 2008 | Olympus VN-3100PC Digital Voice Recorder
Keeps going to headphone mode when not plugged in
  1. Thats a general complaint by the connectorplug itself a minijack or a jackplug has a metal contact inside thats not making good contact anymore spray some contactspray or wd40 inside it and wait a few minutes and put in and pull out a few times in a row . thats the simplest way .
Because the main line is broken if the plug is inside and must be back in activated (mechanical ) by remove the plug. or replace the headphone connector.
Jan 15, 2016 | LG G2
No sound coming through to headset
need to know more. while headset is plugged in try very gently pulling the jackplug out of the socket, if you get sound with the jackplug positions you may have the wrong six
ze plug or the headset may be faulty. try the headset on other devices that function correctly. Also plug another headset into the socket that the headset is currently is plugged into. If another headset functions then the headset must be faulty. It is a matter of experimentation to find what the problem is but you might need a known working headset to carry out the testing procedure.
Good Luck
May 26, 2015 | AUVIO Stereo Wireless Headphones
Want to buy earphones. What connection on the lead is needed to connect to system?
You may need to use an adapter to connect the mini stereo plug if the front panel PHONES connector is standard size.
Mar 16, 2015 | Pioneer Audio Players & Recorders
I need to connect a surround sytem to my tv but cannot find an audio out on it
Depending on the TV you have and the surround sound system you can use the following:
An optical out cable.
Headphone jack to headphone jack (a cable with a 2.5mm headphone jack on both ends) you then plug this into the headphone jack in the TV and the other end into the audio in jack in your surround sound system.
You can also use a standard scart lead to plug into your TV and surround sound system.
May 03, 2011 | Televison & Video
My acer notebook 5517 says : no bootable devise, acer notebook 5517 It says to open disk drive and insert reboot disk, can not open disk drive
Please follow the below steps. On this image "E" is the headphone and speakers jack. You can insert the speakers here.
Component Icon Description A. Speakers Provide audio output when headphones or amplified speakers are not plugged in. B. LCD panel release latch To open the LCD panel, slide the release latch to the right. C. Battery status indicator
  • LED blue - battery is fully charged
  • LED purple - battery is charging
  • LED blinking - battery charge is very low
D. Power status indicator
  • LED on - notebook is on
  • LED blinking - notebook is in Standby mode
  • LED off - notebook is off
E. Microphone jack mic.gif Plug a microphone into this jack. The built-in microphone is turned off when a microphone is plugged into this jack. F. Headphone jack headphone.gif Plug amplified speakers or headphones into this jack. The built-in speakers are turned off when headphones are plugged into this jack
Jul 03, 2010 | Acer Computers & Internet
How do i connect my headphones? when i use a red/white tulip - jack out cable and then connect the headphones jackplug there is no sound, using the 'variable sound out'. should i use an amplifier like a...
If your TV does not have headphone jack outlet, then there is not much you can do, the Audio line level out RED and WHTIE RCA jaks are not made to drive headphone directly, it does not have enough power to drive low impedance load such as headphone which has about 8~32 Ohms impedance, the line out RCA is made to drive high impedance load 20,000 Ohms and higher.
If you want to use headphone, what you can do is to get cheap powered PC speaker system that has headphone out jack, then just connect the powered PC speaker to the audio line out of the TV, but the TV must have an option on the audio setup to turn off the built-in speakers.
http://s807.photobucket.com/home/budm/allalbums
Jun 12, 2010 | LG 26LC2R 26 in. HD-Ready LCD Television
No sound from 5.1 surround system
If you're connecting a "5.1 surround system" to a single jack that you plug your headphones into, it's not going to work. Headphone jack is Stereo, 2 speakers. You need at least 3 input jacks for 5.1, plus one for the subwoofer. If you don't have these, you'll have to buy an add-on card.
Dec 04, 2008 | Computers & Internet
Pioneer DCS-222 System Logo
425 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
