Question about Nintendo DS Lite
Damage on the back of my ds
There is a damage on the back my DS when i keep opening the ds the top screen turned black i need real help I NEED SOLUTIONS
    Scholar:
  • 133 Answers
Your cable is destroyed. It will have to be repaired. Look online for VIDEOS on how to replace the top lcd. It requires rolling of the top lcd to fit into a small hole and I've torn a number of those my first time. Good thing it wasn't my money I was spending ;)
Look on Amazon and you can get top lcds for under $20.00!
Any more questions, good luck
Posted on May 30, 2009
Ds goes black and white
Hi Tristan,
Does the ds still turn on, which hinge is broken? Left,right or both as you open the lid?(very carefully though if you damage the ribbon cable for the top screen it'll need replacing for sure.
Jul 31, 2012 | Nintendo DS Lite Console
DS Lite Console: My nintendo ds lite top screen is black. I can mo...
If you want to buy a Nintendo screwdriver and work patiently, this is an easy fix.
One of your ribbon cables is being pulled out or is not connecting when you open your DS.
If you go to www.powergamingparts.com you can find manuals to assist you in opening the DS and where to locate the "clips" that you will need to tighten.
If you need any further assistance contact me.
May 17, 2010 | Nintendo DS Lite Console
The top screen on my ds lite keeps flickering lines. this gets worse the longer it's on for but it does seem to help if i play while on charge or close and re-open the ds. I'm not sure what needs replacing...
It might be worth checking the ribbon cable for the top screen is tight in the socket on the main board, this could explain why the screen gets back to normal when you close the ds then reopen. The ribbon cable for the top screen is in the hinge on the left side of the ds when open, the only way to check this is to take the back of the ds, to do this you will need a small philips screw driver and a tri-wing screw driver which you can get of ebay quite cheap. The worst possible fault is the top screen is faulty and needs to be changed, if you do a search in youtube you will find videos on how to do this, they are good and quite detailed. hope this helps.
Feb 17, 2010 | Nintendo DS Lite Pink Console
Top screen Ds black spot exploded
the top screen will need replacing.. this is a very fiddly task, unless you are confident at fixing things probably better to let an expert do it otherwise you may end up causing more damage
Jan 04, 2010 | Nintendo DS Lite Console
When you flip the ds open after you turn it on the
looks like you might need to replce the screen easy enough to buy on ebay and replace it plenty of how do video's on ebay on how to do this hope this helps and by the sounds of it when you have droppped it you have damaged the lcd screen
Paul
Oct 30, 2009 | Nintendo DS Console
DSI lite top screen keeps going black
The top screen is worked by a strap thru the hinge, it looks like you may have damaged it, if you look on the internet you can but a replacment screen with the strap, you can also get instruction on how to do it and what tools you will need, if you dont think you can do it, their are places you can get it fixed, just look on the internet.
Oct 18, 2009 | Nintendo DS Lite Console
DS top screen cracked!
buy a new top ds lscreen, good and cheap place is www.dealextreme.com with free delivery. its tricky job though so better if someone who has knowledge does the job, otherwise there are reliable ppl online that qoute good prices 4 fitting new screens.
Apr 07, 2009 | Nintendo DS Lite Console
Red screen
your DS is definetly faulty, find recite and take it back, or find one of your local games repair shop before problem gets worse
Apr 19, 2008 | Nintendo DS Lite Console
Nintendo ds lite,green light on but not the screens
I had the Same problem on my wifes DS.  First problem was that it kept swithing itself off, so sent it to Nintendo for repair.  Within a week it was broken again.
This time the green light was coming on, but no sound and no sign of life in the screens.
Well, I'd already had to pay nintendo for the first fix (different region, no warranty, apparrently).  So I thought seeing as it's out of warranty anyway, why not open it up and have a look.
To open it you need specailist tools, I don't recommend it if you've never done anything like it before.
Anyways, the bios chip was no longer connected to the main PCB.  I simply plugged it back in and added some slips of post it note to stop it coming off again.
You can see in the picture, the chip easily plugs back onto that white clip on the board.
Once it was back on. the DS has been working fine.
Feb 27, 2008 | Nintendo DS Lite Console
DS Lite has red lines in top screen?
It could also be running fluid from the screen's gel padding. I doubt that, though... It's best to buy or order a replacement screen. It's actually not too expensive and is not too hard to DIY. The problem with that, is it's really easy to accidentally break something while opening up a DS, especially the DS lites. Another problem is, you need a triwing screwdriver to open up the DS, which can only be found online. So, if you don't want to buy anthing online, you should just ask gamestop or something to repair it for you. It'll come at a price though...
Jun 28, 2007 | Nintendo DS Console
Nintendo DS Lite Logo
53 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
