Question about Dishwashers
I have a LG LD-14AW2 dishwasher, today I set it to run and came in and although the lights were still lit up the tome was not moving, I turned the unit off and waited a while then turned it back on. The power turns on and I set the type of wash but when I press start it beeps twice and won't start. Can you help, I have had nothing but trouble with this dishwasher since it was installed!
V\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I had a similar thing. Every time I went to start the dishwasher it went "Ding Ding". I could press every button, turn it on and off OK, change cycles etc. I guessed the sound maybe because it thought the door was open, so set to work pulling it apart. This is how I fixed it.
Make sure you do most of this with the power off - there is probably mains voltage inside!
After pulling off the the cover of the door (with the door open, undo about a dozen screws), the front will fall off if you don't hold on to it, and the door swing closed, so be careful. When it has detached, move the metal part aside, and place the "brains" (circuit board etc) on to a chair or similar so the wires don't stretch.
A quick way to see if you have the problem is the same as mine is to remove the orange cable from the PCB as per below:
Turn the power back on, and press the power button, then the play button, things will hopefully work. If they do, turn it off right away and continue as per below to fix. If you are not worried about the safety mechanism - you could just leave it off and put things back together. However if you forget I think the entire kitchen could get very wet!
Reconnect the orange cable, and start by removing the handle. You will need to disconnect the cable block going in to the back of the handle mechanism, and remove the 3 screws as shown:
Once you have the handle off, remove the metal cover. I found I had to slide it down at an angle and back, ie:
With that off, you should then be able to carefully edge out the reed switch - this is the source of the problem. In the image below the arrow point to TWO hooks that need to be released as you slide it out. I found that the hooks got stuck on the seam as well, so go slowly.
I have a LG LD-14AW2 - 1422763.jpg src="http://i.fixya.net/uploads/images/1422763.jpg" alt="1422763.jpg" class="h_mi" />
Once you have the reed switch out, you can see if the local electronics shop has one the same (probably the best long term fix), or if you pry it apart, I lightly scraped the coI have a LG LD-14AW2 - 15b9270.jpgde it:
Once this was done, I could put the handle back together and test (I tested before putting the whole front back on). With a screw driver you can put the mechanism back to "close" the door, and things should hopefully work. Or to "open" the door, pull the handle, and use the screw driI have a LG LD-14AW2 - f93a689.jpgl it the rest of the way, ie:
Once you are happy it is all working, put everything back together and things should hopefully be away!
Posted on Sep 09, 2009
  • 3 more comments
  • kdframe Oct 26, 2010
    Fantastic article! worked a treat......... THANKS SO MUCH!
  • mstt_in_aus Sep 25, 2011
    Thank you so much :))
  • TimC Oct 27, 2011
    Awesome instructions. Only took me 20 minutes to fix. Our switch had some moisture in it - could be part of the problem
  • TimC Oct 27, 2011
    Awsome instructions. Worked a treat. Only took 20 minutes. Thanks heaps
  • zoltan Jan 28, 2012
    Thanks mate, i was getting cranky at yet another household item stuffing up but your help saved the day! Also guys, beware of stripped plastic threads where the handle ***'y screws hold: i used a slightly oversized screw to get 'hold' again. z
LG dishwasher LD-14AW2 starts up & tries to drain for about 2 mins & then the alarm comes on. The wash, rinse & dry lights are flashing. The hose is raised and not blocked because we can blow...
Hi Jeff - am not too savvy with LG - am a Electrolux/Miele serviceman is it possible to gain access to the drain pump from inside the unit? I think it does sound like there is a restriction somewhere perhaps the pumps not running freely.
To check you pour water inside , take the drain hose , operate machine to see how good the flow of the drain is, rule of thumb if you cover the outlet no flow then the problem.
hope this is a start..
Jun 17, 2011 | LG 24 in. LD-12BW5 Free-standing...
Where can I access / buy a lg dishwasher ld-14aw2 repair manual
go to google put in the manual you want and 5 sites will come up offering them at several prices
Feb 28, 2011 | LG Dishwashers
I hav a lg Dishwasher model # LD-14AW2 the problem
broken door cord. remove side panels and relace. this is a cheap and easy fit. make sure you replace both sides at the same time, you will most likely find it is only one side broken at this stage, but the cords do not last very long.<!-- from fixya rte -->
Jul 07, 2010 | Dishwashers
Model No LD-14AWZ Wash rinse and dry lights flashing. IE flashes on display board.Model no LD-14AWZ
not sure if im on the rite page we have move into a house that has a disherwasher LG Model LD/14AW2 there was no instruction book left at the house cant seem to get it to work even though it looks quite a new dishwasher do anyone know where i could get a instruction book from thanks noelene
Jun 26, 2010 | LG 24 in. LD-12BW5 Free-standing...
LG dishwasher model LD-14AW2 comes up with E 1 fault all the time
I took the side panel off and found the start capacitor for the pump motor burnt out.I purchased a new 5 uf capacitor for $9 and installed it.
Regards Neville OBrien
Nov 28, 2008 | Dishwashers
LG ld-14aw2 dishwasher
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
Aug 26, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
LG Dishwasher
Had a similiar problem I tried reducing water pressure from water inlet (external to dishwasher) and this worked to a certain degree, although may result in being unable to fill, if you turn down too far. Water silencer (try plumbing stores) was fitted between mains and dishwasher and this fixed the problem.<!-- from fixya rte -->
May 16, 2008 | Dishwashers
LG LD-14AW2 (03 error)
agreed O3 is not a LG error code. OE is more likely and if so it could be the main pcb faulty, a blocked drain pump or a blocked spigot under the sink where the drain hose connects onto.
take care.
May 11, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
Dishwashers Logo
680 people viewed this question
Top Dishwashers Experts
