Question about Samsung Televison & Video
When i turn on my tv, after 5 seconds it will turn off..
When i turn on my TV set, after 5 seconds it will turn off.. are there any part that need replacement... Can anybody help me please... thanks
    Problem Solver:
  • 5 Answers
If it is an LCD (not DLP), there is likely a problem in the power supply /and or inverter circuit that drives the ccfl backlights. It is sensing a problem and shutting down to prevent further damage. Bad electrolytic capacitors are a common fault. They usually bulge at the top and chemical leaks out. These degraded capacitors wil cause unstable operation, and shutdown. www.badcaps.net/forum is a great resource for information.
Posted on May 29, 2009
Trouble turning the tv on
I will need the model number of the set in order to assist with the issue
Nov 22, 2011 | Magnavox Televison & Video
Tip
To Clear Green Screen Problem
Here are the proceedures for taking care of this problem:
1) Turn on TV
2) Make sure the remote toggle switches are set to "TV" and "VCR" respectively
3) Press the "Sleep" button
4) Simultaneously press "Display" and "Video Status"
5) Press "2" (Self Check)
6) Turn off the TV
7) Wait for fan to turn off (30 seconds or so)
8) Unplug TV
9) Wait for 30 seconds
10) Turn TV back on
Hope this helps
on Feb 21, 2008 | JVC HD-56G886 56" Rear Projection HDTV
Need code for asda remote model#URC20-D1F for use with my sony tv
URC20 D1F
Set up by Automatic Search
1. Turn TV on
2. Point the remote at tv and Hold SET and TV buttons at the same time and keep pressed for 3 seconds.
3. The LED flashes and the remote control starts the automatic search.
4.The OFF signal is automatically sent to the tv from the remote control.
5. Once the TV switches off press any button except SET to stop auto search.
6. Switch your tv on using the POWER button.
Sony TV codes
010,011,028,030,031,077,107,128,131,166,203,237,302,309,367,444,445,446,449,160
To enter. Just hold SET and TV at the Same time.
The red led light stays on you are in set up mode.
Enter the first code on the list and try power button.
Keep following the steps untill you can turn the tv off.
Then its set.
Feb 08, 2010 | Televison & Video
Reset parental lock for panasonic pt-53wx53
Hi, try this it works' on most pan. tv`s, ON REMOTE push the power button for at least 7 seconds, video-tek
Feb 11, 2009 | Panasonic PT-53WX53 53" Rear Projection...
My remote will not work and the tv menu is on the screen and goes through all the diffrent setting options automatically without stopping. TV buttons will not control the menu. Unable to make any setting...
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of time.it will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
Jan 17, 2009 | Toshiba 36A43 36" TV
Turn on and stay on
It seems that Your TV set may have a problem with its power supply circuit, the problem is intermitent bring it to the repair shop.
Nov 06, 2008 | Televison & Video
Magnavox 27
THANKS FOR THE INFORMATION ThaMp3DOCTOR. PRESSING THE VOLUME+and CHANNEL+ SIMULTANEOUSLY FOR 5 SECONDS WORKED!   THANKS
Mar 15, 2008 | Philips Magnavox 27MS343S 27" TV
Looking for programing codes
Turn TV on. Press and hold [Code Search] until LED stays lit. Repeatedly press [CH +] until the channel changes. Press [Enter] to save code.
Dec 13, 2007 | Universal Remote Control Remote Control
Televison & Video Logo
131 people viewed this question
Jerry Greenberg
Jerry Greenberg
