Question about ACCO Brands Water Heaters
Is there a safe design to put around an ascot water heater as the tiny flame is blown out by the wind and it gets wet in the rain
The little flame which burns constantly in the ascot gas heater gets blown out by the wind
  • 520 Answers
Judging by the fact that the wind and rain are a factor here I would recommend that you build an enclosure around this unit. as long as you leave about 6 inches all the way around the water heater and put a large vent in the door then an enclosure is a good idea. Hope this helps. Good luck.
Posted on May 29, 2009
Gas burner wont stay lit
Is it the Pilot, or the main burner that won't stay lit?
The pilot has a little 'flame rod' in the path of the pilot flame, that conducts a tiny current thru the flame, to a detection circuit-- assuring that there is a pilot flame-- If that rod get's dirty, it can cause false trips. Is that any help?- Mack B
Oct 25, 2013 | Honeywell Pilot Burner for Natural Gas,...
Water heater flame going out
clogged orifice,found at the end of piloy tubeing(it looks like a tiny thimble) clear orifice with a stripped bread tie. if that doesnt do it, you need to replace the thermocouple. thats the metal sensor that your pilot flame heats. if the thermocouple is not up to temperature by way of flame ,nothing will work. these are cheap and easy to replace
Dec 19, 2012 | Water Heaters
Would high winds and rain cause pilot light on a rannai tankless water heater to go out?
Yes.
High winds can cause reversal of air flow down vent pipe causing pilot flame to blow out.
If situation happens frequently, then special roof cap has to be added.
Have plumber check natural draft up vent pipe.
Other things can cause same problem, for example if vent fan is located in same room as water heater, or house is tightly insulated, and vent fan is ON, then it will draw air down the water heater vent and blow out pilot.
http://waterheatertimer.org/pdf/Bosch_Checking_the_draft.pdf
Oct 29, 2012 | Water Heaters
Our Bosch Water Heater has gas smell next to it. Anyone had this problem?
is it power vented or is it draft vented if it is draft vented that is not uncommon sometime u get tiny back drafts and u smell a little burnt gas if u are really concerned get a carbon monoxide detector and place it within 4 feet of the unit @around 4 feet off the ground
Feb 21, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
My water heater is leaking water at the foot stand, should I shut the heater off and do I need a new water heater?
Make sure that the water is not coming from the drain valve, the relief valve or some top fitting and running down the insulation inside the visible outer skin of the heater.
If it is truly a bottom leak, which is common when the heater fails, if the leak is getting on the flame or pilot, you should shut it off. If the water creates an unacceptable situation, for example, leaking on a finished floor, shut the water off.
If the water is leaking slowly and the flame is not being wet down, you can call a plumber and use the tank on an emergency basis.
Dec 10, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot light goes out randomly on 6 year old Bosch Aquastar tankless water heater. When I restart it it may work for a day then goes out again.
The pilot light can be blown out just by the main gas being ignited especially if the pilot flame is a little weak. Some times a bit of grit gets into the pilot nozzle reducing the flow and hence a weak flame. Try cleaning the piolt jet nozzle with a fine piece of wire. You may have to dismantle the jet nozzle to clean it properly.
Aug 30, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
C4 13 error code
it could be either of the 2
flame sensor
or circuit board
you will need the code and contact rheem
Jun 23, 2010 | Rheem Tankless Hot Water Heater...
I have an Ascot wall hanging hot water heater.The wind frequently blows out the pilot light. Can I make a safe housing around it to protect it from wind and rain
Yes you can, but make sure that it has access to air. Leave at least 6" of space between the shelter and the pilot. Is it outside? I've never seen one outside.
May 29, 2009 | Water Heaters
A ascot wall mounted gas water heater
The gas will be the one you can unscrew and mostlikly not cooper.
Please rate. Thank you. jj505
Mar 28, 2009 | Water Heaters
Bosch 1600H won't work on windy days
The incorporation of an anti-back flow, flue pipe insert may be your solution, also the pilot flame control may need to be adjusted up a little.
Good luck
Aduz
Mar 24, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Water Heaters Logo
60 people viewed this question
Top ACCO Brands Water Heaters Experts
Donni Steen
Gil Shultz
Are you an ACCO Brands Water Heater Expert? Answer questions, earn points and help others
