Question about Dell Studio XPS 16 Notebook
Keyboard keys malfunction
My @ and " got interchanged. other key of the keyboard are also interchanged but not all. can anyone please help.
  • kevin May 29, 2009
    not the location of the keys. the keyboard is right... but not the function of the keys.
  • Chris Hingee
    Chris Hingee May 11, 2010
    Did a friend change the locations of the keys around as a joke?
    Or is the keyboard faulty?
  • 453 Answers
Hmmm,
1) May be you need to connect an external keyboard to your laptop and check whether the same happens.
else
2) Check whether the Num Lock is turned ON or OFF. If it is turned ON please turn it OFF by pressing the Num Lock on your keyboard.
else
3) Click Start and go to Control Panel In the left hand side click the Classic View. Now you will have a number of Icons. Double-click on Regional and Language Options. Choose the Keyboard and Language tab. Click Change Keyboards. In the Text Services and Input languages window, make sure the default language is set to English (US) Just below that check the Installed Services window to check whether the correct option is being shown.Click OK. else 4) Turn off computer. Remove both Battery and power cord. Keep pressing the power button for 20 seconds with no battery and power supply. This will make sure no static charges are present in the laptop. Put them back on and check the keyboard. else 5) Call the Dell Technical Support team to run Dell Diagnostics on the system to check keyboard functionality. They can help you replace the keyboard if it faulty and provided the laptop is covered under warranty Good Luck !!! Hope it works asap !!!
Posted on May 29, 2009
Could anyone here help me? i have problem with my e machine N450 laptop keyboard, the key r,t,u,y and backspace are not working..and the other keys like i,o,p,m,k and l are malfunctioning too, when i
The first thing I would try is to open the computer and make sure the keyboard ribbon cable is firmly, and correctly, attached. If it is, then you need to buy a new keyboard.
When you plug a PC keyboard into the USB port, does it work correctly? That's the part that will definitely tell you to replace the keyboard.
Dec 16, 2011 | Acer eMachines 350-2074 Netbook
I have a hp laptop and when ever i press the number five and six key it is not working mcan anyone help plz
you usually find,that setting the keyboard is done at first install of operating system.if you do not choose your correct country and keyboard layout you could find malfunction of the keyboard.
The other scenario could be the keys themselves have begun to malfunction,the first option will require a reinstall of your operating system and the correct options chosen at this stage.
Jul 15, 2011 | HP Pavilion dv5-1138nr Notebook
The volume keys stopped working and the right caps key does not engage capitals on a, s, d or f.
Hi rbjones219 ,
These are the symtoms that you see when the keyboard is about to be damaged completely.
Ususally you find instances where few keys malfunction or stop functioning , and then you have that problem with other keys as well , till the time you have problems with many keys together.
I would recommend you to give it a try by opening up the keyboard and cleaning the circuit , and check if it works fine, if not then it's about time you replace your keyboard.
Note :- If your keyboard is still under replacement warranty , please get it replaced.
Hope ths helps ...:)
May 09, 2011 | Gear Head WIRELESS keyboard/Mouse
Anyone know how to fix this keyboard problem? My Laptop's keyboard is malfunctioning. Only a couple of keys have this problem. Whenever i press the apostrophe key i.e. ' key, nothing happens, it doesn't...
This may be caused by dirt. You need to clean your keyboard.
- A quick first step is to turn your machine upside down with the keyboard on your palm
- Then bang your palm against the keyboard. This will help free up some dirt
Oct 07, 2010 | HP Computers & Internet
How can fix my keyboard's problem? and what's the cause of keyboard malfunction? The "i" key has not been typing since yesterday. Please help
You can try pop the key off ( use a knife or screwdriver)
There may be some muck/dust stuck under it.
If this does not fix it, the membrane under the keys may be damaged.
New KB time
Aug 13, 2010 | Acer NSK8458AN Keyboard
Toshiba at the rate and invertd comma keys are interchanged
Dead easy, go to the Control Panelselect region and language settings.
On opening you will get a pop up with 3 tabs
!st tab change region to UK
2nd tab click details and change all options to UK
That's it done.
Aug 25, 2009 | Toshiba Satellite L305-S5933 Notebook
I lost my Ctrl Key. Can I have the keyboard replaced?
Yes keyboards are interchangable for desktops and fairly inexpensive.
Apr 18, 2009 | Computers & Internet
I fitted a plug and play usb wireless keyboard and mouse now my laptop keyboard gives incorrect stokes ie. m=0 k=2 '=` can anyone advise please
are those keys placed on corect spot?, try to use it on a desktop and if still malfunctioning then somethings wrong with ur usb keyboard .better replace or buy new usb keyboard if problems still occur
May 30, 2008 | Computers & Internet
Popped a key off my Notebook's Keyboard
Dear titomb345
Try the following guide.
http://www.laptoprepair101.com/laptop/2007/03/20/key-fell-off-keyboard/
There are no guides available for the DV1000 but this guide will be more than enough to help you through this one.
Regards
Please don’t forget to rate this solution if it was helpful, it keeps us going!
Mar 25, 2008 | HP Pavilion dv1000 Notebook
Open Questions:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.OverflowException: Value was either too large or too small for an Int32. at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) at BmLauncher.SystemInfo.GetPropertyInt(ArrayList info, String propertyName, Int32 property_index) at BmLauncher.SystemInfo.GetPropertyIntBest(ArrayList info, String propertyName, Boolean select_highest) at BmLauncher.SystemInfo..ctor() at BmLauncher.Form1.Initialise() at BmLauncher.Form1.OnLoad(Object sender, EventArgs e) at System.Windows.Forms.Form.OnLoad(EventArgs e) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WmShowWindow(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.6407 (Win8RTMGDR.050727-6400) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- BmLauncher Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Program%20Files%20(x86)/Eidos/Batman%20Arkham%20Asylum%20Demo/Binaries/BmLauncher.exe ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.6402 (Win8RTMGDR.050727-6400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.6401 (Win8RTMGDR.050727-6400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.6401 (Win8RTMGDR.050727-6400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Management Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.6387 (Win8RTM.050727-6300) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll ---------------------------------------- Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.6387 (Win8RTM.050727-6300) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
Oct 20, 2013 | Dell Studio XPS 16 Notebook
Dell Studio XPS 16 Notebook Logo
341 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
