I just replaced the heat exchange unit. It ran ok for a while then after it got up to temperature and shut down it wouldn't turn on again by itself. Fumes. I took off the cover for the burner and could see soot on all over. Flame burns yellow.
    President:
  • 3,433 Answers
Be careful opening combustion chamber with fumes present. The soot means the gas, or fuel to air mixture is incorrect. The inlet of the burner should have an adjustment that slides. That is an air coke . It may be closed or completly open. Adjust it to a blue flame. Close the combustion chamber when lighting.. If fumes build up, Ther is an explosion hazard when working on heaters. Any type . good luck
Posted on Jun 01, 2009
Not heating, no fault codes, everything seems normal. Checked heat exchanger ok, flow switches ok, thermal reset ok just no power to the ceramic heating elements please help me ;-(
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or
overheating.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!!
Apr 28, 2015 | Dryers
Meile fridge freezer ice on floor of fridge
This fix procedure is simple and should not daunt anyone. First switch off the unit - best by removing any electrical connection, plug, socket, etc. At the rear of some (?) Miele fridge freezer units inside the compartment, is a large plastic panel. Remove this by first removing the food trays and then, use the screws in place on this panel. You wioll probably have to manoevre out the small cabled temperature "sender" control unit. Also see the drain hole at the bottom of the unit's back wall. Above this is a heat exchanger (like a car radiator). You need to pour hot water into the heat exchanger body at the top so the probable ice build-up is melted. This can take several jugs full of hot water and the drained water needs to be recovered at the bottom and lost elsewhere. I think I used a combination of old towels and drain cooking tray. If you don't do this, you will simply have a big water mess. When you feel the water flows easily the ice has probably been melted. The hot water shouldn't damage the heat exchanger at all. Dry all the components you can see around the heat exchanger. Then turn your attention to the drain hole. This discharges through a small plastic outlet into a water overflow tray and this is likely to be blocked with either more ice, or dirt. Poke a plastic rod or wooden stick down this hole and wiggle it about. You are trying to ensure that the drain hole is free to drain any auto-defrost water away by itself. When all is clear and dry, replace the large plastic panel, switch on the unit and hopefully see that the fredige freezer comes back down to the right temperature. You may need to refer to your User Manual to see how the temperature and settings all work. Good luck.
Jun 03, 2014 | Miele KFN8762SDED Bottom Freezer...
Heil epm36f19a1 runs but no heat
Fan relay is stuck among other things. The thermostat turns on the combustion air fan and puts power to the spark unit. If the burner comes on after the temperature in the heat exchanger rises the indoor fan will then come on. After the thermostat comes to temperature the power to the gas valve which shuts off the burner. Then after the heat exchanger cools a bit the indoor fan will stop. That's the sequence of events. look at the switches that control the fans. There is a wiring diagram somewhere on one of the panels that access the unit for service.
Mar 06, 2013 | Electronics - Others
Sime ecomfort plus 30 HE keeps cutting out and shows a flashing green light. Sometimes it will run ok for a couple of hours before cutting out.
I had the identical problem with the same model. Technician eventually diagnosed faulty fan; the fan cools the heat exchanger. When fan fails, exchanger overheats and boiler automatically shuts down. It is possible to restart the boiler when it cools down but when the heat rises again - off it goes! Only answer is to replace the fan. My technician did the same as yours - on first visit he got the boiler running and left. Half hour later, boiler shut down. I read the installation manual and operating instructions and when he called again I pointed him in direction of fan, which had failed completely. These guys!
Apr 11, 2012 | Televison & Video
Hello, When I set my AC unit to "Heat" and turn it on, the air will come out warm, then after a few hours the air starts to come out cool. To make it warm again I need to set the...
It sounds like you have a heat pump. When you first turn on the system the heat strips will come on and produce warm heat (referred to as supplemental heat strips), as temperatures rise the heat strips will turn off and the "A" coil will just exchange heat to maintain temperature thus conserving energy. . Initially the temps will be around 125 degrees at the register, and drop down to about 105 after the strips turn off.
On some TXV controlled outdoor condensing units the Thermostatic Expansion Valve will stick in the cool position and require replacement this will cause this symptom. It takes several hours to do and requires a licensed technician to do as it involves recovery of refrigerants. I hope this helps
Feb 17, 2011 | Heating & Cooling
I am renting a house which has a Trane heat pump
If it is a heat pump it may not have enough oomph.
Oct 20, 2009 | Amana PTH123B25AJ Heat Pump Air...
Honeywell fan&limit stat manual reset control
Okay, the red button is a manual reset that is the heat enchanger gets to hot it opens the safety cicruit. The new one does not have the red button so therefore it will automatically reset itself once the temperature of the heat exchanger cools down. Once you install the new one verify the control shuts the unit down. The easiest way for you to do this is to cover the return grilles with a plastic bag with a little tape to hold it to the grille. Then start the heat cycle and observe the furnace operations. There should be a little tab near the 200 degree temp. once it gets to the 12 oclock point the burners should shut down. If it shuts down properly pull plastic bags off returns and satisfy tstat. now turn heat on again and observe what temp the blower comes on
Jan 24, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Boiler shuts down repeatidly
i think you will find that instead of modulating as demand requires the boiler is overheating and then re operating after the safety thermostat has operated.
i wilud put some de scaler into the main heat exchanger circuit or add it to the radiators and let it circulate for a while.
also make sure the pump is operating properly to ensure proper water flow.
Nov 17, 2008 | Water Heaters
Rx-V2400 Shut Down
Hi Seems like you have a shorted output channel, remove all your speaker connections and try again, if the problem persist, good chances are that you need to replace a couple of power transistors, let me know if you need more help, I've fixed some Yamaha amplifiers with this problem Good Luck Miguel
Oct 06, 2007 | Yamaha RX-V2400 Receiver
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
