Question about Polyview V17E 17" LCD Flat Panel Monitor
No sound I cannot figure out how to get sound out of my polyview V293. I need it because i broke my speakers. Please help
    President:
  • 2,961 Answers
If your monitor has speakers, and it should  built in; then you will see a separate lead with  green plug on the end of it which is to be located in the rear of your pc with the green marked socket.
If theres no lead, then there must be a connector on the rear of the monitor
Posted on Oct 22, 2007
Hi, I have a Polyview V293 LCD Monitor with a power supply output of 19v 3.42A. The power supply has failed. Most i have found being offered as direct replacement for this monitor have an output of 19v...
If the power adapter is a separate from the monitor then check the monitor's label on the back of the screen for the power rating.If the rating on the label is greater than 3.16A then I would not purchase this adapter.
I suggest you purchase an adapter with a current rating greater than what is stated on the monitor's label.
Check out this WEB site for power adapters - a 19Volt 90 watt = 4.7A power supply is suitable.
http://www.cheaperoz.com/z/result.jsp?ga=sc1&q=19v+power+adapter
Apr 01, 2011 | Amptron POLYVIEW 19" Monitor
A Polyview V293 monitor suddenly stopped working and fails to show any activity at all. There was no trauma at the time. Is this likely to be able to be repaired? Bruce Jones, Australia
Well, common failure in the LCD monitor after a couple years are due to failed DC filter caps in the power supply as you can see in my albums.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 20, 2010 | Amptron POLYVIEW 19" Monitor
Trying to find a video device driver for an Amptron Polyview V293
try this link below to download the driver
http://www.driverstart.com/start592730.html
Aug 10, 2010 | Amptron POLYVIEW 19" Monitor
No sound monitor speakers
hmm the monitor is connecting to the pc sound card ...and for that you have to have a sound driver installed...if you know what kinda pc you have its easy ..but if its a built one ..you gonna either look inside to see what is the sound card name ...or try to see if you have a previous sound driver installation .....if you did had sound or still have on the ear pieces you have to have on the monitor too..just see the volume ...and the cable connection ..if it has a separate one (3.2 jack )or it connects directly with a HD cable
Aug 03, 2009 | Polyview V17E 17" LCD Flat Panel Monitor
Polyview v17e - microphone?
G'day Matt,
No microphone. It has a line in socket to drive the stereo speakers.
cheers,
dave.
Jul 03, 2008 | Polyview V17E 17" LCD Flat Panel Monitor
I have problems with my LCD polyview
These monitors are plug and play compliant and should not require any drivers. If you are having video problems it may be the video card.
Apr 06, 2008 | Polyview V17E 17" LCD Flat Panel Monitor
Sound from monitor speakers distorted and high-pitched
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 16, 2008 | Computers & Internet
Polyview V17E 17" LCD Flat Panel Monitor Logo
167 people viewed this question
Top Polyview Computers & Internet Experts
David Payne
David Payne
Are you a Polyview Computer and Internet Expert? Answer questions, earn points and help others
