Question about HP LaserJet IIIp Printer
HP LaserJetIIIP - just won't switch on - cable and fuse OK
One last week day this venerable machine in daily home use (bought 1991!) just didn't switch on; No clues at all; power source OK. Is there an internal fuse or a reset button inside. Was working perfectly up to failure;
  • 489 Answers
I can't believe that someone is still using one of the first LaserJet printers I got certified on!!! If you really want to gut the machine, there is a fuse in the power supply that could have blown. It is also possible that the power supply has finally died on its own after all of these years. You may just want to check the output voltages first to make sure of the status. If some voltages are present and not others, the fuse is still good, but the output circuitry is shot, in which case you would need to get a replacement power supply (if they are even available anymore).
Be careful with the disassembly process. The plastic clips may be brittle after almost 2 decades and could easily snap apart.
Posted on May 29, 2009
Should i go for an Espresso machine or coffee maker?
I can't really start my day without my espresso, so I'd say go with the espresso machine! I need my strong, black coffee fix every morning. But then again, it's a question of what you like. If you prefer different kinds of coffee every morning, buying a coffee maker might be the best way to go. I use the Gaggia Espresso Pure Semi-Automatic that I bought off Daily Cuppa Coffee for my espresso, in case you were wondering. They offer a wide range of both espresso machines and coffee makers; you can browse through them at www.dailycuppacoffee.com and select the one you like.
Jun 06, 2013 | Cuisinart DCC Coffee Makers & Espresso...
Won't start
Check the fuel injectors, with the key on one side of the two wire connector will have battery voltage, if none is present then check the ECM fuses in the underhood fuel box.
Jun 22, 2017 | 1999 GMC Sonoma
I just got a new computer, tried to add my old trusty LaserJetIIIP, but isn't on the list of printer models. Any ideas?
Your printer may be "trusty", but the real operative here is OLD.
The IIIp was introduced in 1991, that makes it almost 20 years old.
It isn't supported anymore. If your new computer is running Win7, you might
want to try the 'universal print drivers'. Just plug the printer in and see if
the OS picks it up.
If it doesn't, you are going to have to retire the beast.
Jan 27, 2011 | HP LaserJet IIIp Printer
Bought a Toshiba Regza 37rv635d last week.
I have had the same problem today. I think it might be to do with the master power button on the side, as it seems loose on my tv. Did you ever solve the problem on yours?
Apr 06, 2010 | Televison & Video
WLAN not being detected in HP Pavilion tx1210 laptop
first of all is the wireless adaptor recognized under the device manager?
no, you need a new mini pci wireless lan card
yes, the wrong driver is installed, the windows utility is not enabled
Mar 02, 2009 | HP Pavilion tx1000z Notebook
Check Engine light 95 Lincoln Town Car
Top off all fluid levels. Clean air filter.
Remove and clean oxygen sensor.
Remove battery cable for 30 minutes.
Put black tape over aggrevating light.
Dec 27, 2008 | Kenmore 24032\24036 Top Load Washer
Panasonic 1200btu air conditioner
you must check the fuse of pc board.its a glass fuse and propably had burned,replace it,if the fuse is ok then is the varistor and you must get an expert to fix it.
Oct 01, 2008 | Panasonic CW-C60RU Air Conditioner
Won't switch on.
Your expert reckoned it was definitely the mains cable, but in fact I bought a new one, still no luck, and the machine has definitely died it final death. I am buying a new A3 printer (some expense!).
Thanks anyway.
Jul 22, 2008 | HP DeskJet 1220c InkJet Printer
Samsung smart wash b1245s doesn t work
motor brushes are worn and nead to be replaced easy job if you turn washer on to its side remove the 2 screws at the bottom and take off the plastic panel you can see the motor and the brushes are red plastic bits remove them and replace with new ones that should sort out the problem and cost about £25.00 to do .
Oct 13, 2007 | Washing Machines
HP LaserJet IIIp Printer Logo
181 people viewed this question
Ben Johnson
