Question about Maxtor 160GB OneTouch III Mini USB 2.0 External 160 GB Hard Drive
Plug area damaged-can this be repaired? - Maxtor 160GB OneTouch III Mini USB 2.0 External 160 GB Hard Drive
It is fixed==had a friend who opened the drive and
soldered the pushed in plug area back into place.
Thanks for responding
Toni
Posted on May 30, 2009
My dyson dc30 is completely dead. What is a proper sequence to find out what is wrong
Is it plugged in?
Is there a power outage currently happening in your area?
is there power at the socket?
Is the plug fuse intact?
Is it switched on?
Is there any visible signs of damage on the cable?
Is there any visible signs of damage on the vacuum?
All above but still not working then bring it to a repair depot!!
Nov 10, 2016 | Dyson Vacuums
Repair facilities in my area area code 30642
We have no way to look up repair facilities from here. We are in California USA
Jun 24, 2016 | Pride Mobility Products New Pride Mobility...
Need a replacment power cord. how do I order one?????
I'm not sure where to order an OEM cord, but if the cord is damaged between the unit and the plug, it can often be repaired and still be safe. It generally requires heat-shrink but(t)-connectors and/or a heat-shrink covering for the damaged insulation area. If you know anyone that has used those things, either in something mechanical or something electrical, the process is the same, and you could see if that person could look at the damage.
Aug 25, 2015 | Televison & Video
Hi, your nokia was very good in services thank for nokia company. But i have a problem in nokia5130 contact service in red? how to solve it,i have chech the software also but still like that please tell...
hi, for repair nokia 5130 CONTECT SERVICE you have these option,s.
1- Try to full flash whith latest software ver. if problem is still...................
2- Try to repair it,s security area like simlock , super dongle area etc. If phone is PA SL3 the you cant able to repair these area,s...............
3- Final and last solution is BUY RPL file from nokia server & write it on phone .
Important :
Dont try to repair it throw hardware, when you see it,s SIMLOCK area is Damage.You must buy RPL to repair comtect service.If you try throw Hardware, you may Damage your Phone Permanently.
Sep 03, 2011 | Nokia 5130 Cellular Phone
We had bad weather lights went out ..had tv plugged into a power surge plug ...now that i have power back tv wont come on
Some will say a surge protector will save electronics. I can tell you they may not help at all. A power surge is extremely fast and can over ride the surge protector. If you think you can repair this TV, I would certainly remove the back cover and inspect. Occasionally the only problem for repair is to replace the main fuse. Remember, this happens rarely. Most cases after a surge the TV will need to be inspected by a TV tech. Almost anything, in a power surge will damage the TV. There is no certain area that will not be damaged, expect it any where. Thanks for asking and show all hands of support!
Mar 30, 2011 | Philips 47PFL3704D 47 in. LCD TV
How do u repair a freeze plug or replace it
I would not recommend repairing it although there are materials out there that say it will fix the leak. You'll need to pull the old plug out with a slide hammer or pry bar. BE CAREFUL NOT TO DAMAGE the area that the freeze plug seats into on the engine block. After removal, clean the area very well. Use a sealant (auto store has a variety) and a socket or seal driver to tap in the new one. Rubber expansion plugs are used in an EMERGENCY, See this website for pics and details: http://www.automedia.com/Replacing_a_Freeze_Plug/ccr20070401fp/1
Good Luck
Jan 06, 2011 | 1998 Cadillac DeVille
Had wheelbarron repaired and now brake light and abs light are on was put on computer and no codes show problems please help
SOUND LIKE THE ABS WHEEL SENSOR WIRES IS DISCONNECTED OR DAMAGED OR THE WHEEL SENSOR IS DAMAGED OR BAD.
Apr 02, 2010 | 2004 Ford Freestar
My aerial has had the plug pulled off and I want to fix it. Do you have a wiring diagram or can you tell me which pins go where Thanks Chris
Repairing MMMC or MMX plugs is no guarantee that they will work. Often when these plugs are ripped out there is other damage. it is such a minute area of solder you would need a special spot solder unit ($6000) as this is what is used to integrate components onto the board.
I repair GPS for a living but to fix this it is easier to change the whole board than to try and fiddle around with this.
Aug 17, 2009 | GPS
Dropped daewood tv from bed. no pictures.
The circuit board inside is cracked and has broken circuit traces. This is common if a set is dropped. The usual area that gets damaged is around a part called the horizontal output (or "flyback") transformer. It's the part with a red wire leading up to a rubber cap connected to the top of the picture tube. The flyback is fairly heavy and usually there's not much support for the circuit board in that area. When the set gets dropped, the weight of the flyback can break the circuit board. This can sometimes be repaired depending on the extent of the damage. Often the breaks are very obvious and sometimes not. Some of the circuit traces are very thin and close together which makes finding and repairing the damage difficult. In some cases other parts and areas can be damaged as well. This kind of repair requires considerable troubleshooting and soldering skills, so you might want to let a professional shop give you an estimate for the repair.
Jun 05, 2009 | Toshiba 32A60 32" TV
THE TRUCK IS HARD TO START SOMETIMES
Inspect Fuel Injector Pressure Regulator Faulty Fuel Injector Pressure Regulator.
Inspect Fuel Injector Cold Start Valve Damaged or Faulty Cold Start Valve.
Inspect PCV Valve Plugged or Damaged PCV Valve.
Inspect Spark Plugs Fouled Spark Plugs.
Inspect Relay - Fuel Pumpat Faulty Fuel Pump Relay.
Inspect Hose (PCV)at Clogged or Collapsed PCV Hoses.
Inspect EGR Valve Improperly Functioning or Faulty EGR Valve.
Inspect Valve Burned, Worn, or Sticking Exhaust Valves.
Inspect Wireset Worn or Damaged Spark Plug Wires.
Hi, i have listed a cluster of problem spots that you will need to inspect for damage. You will find that your hard starting issue will be the cause of damage in one or more of the above problem areas listed above. Please check each area thoroughly for ware and tare and possible damaged components as well. replace any damaged or worn device listed above.
Please rate and god bless:)
May 04, 2009 | 2003 Chevrolet Blazer
Maxtor 160GB OneTouch III Mini USB 2.0 External 160 GB Hard Drive Logo
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
