Question about HP Office Equipment & Supplies
Printing coloured lines on paper across the page
On print out it has random horizontal coloured lines across the page !! Every pafge run clean and it is still doing this !! think it is fuser any ideas would be greatful !!
  • HP Master
  • 511 Answers
Try to clean the area around the head output (sprayer). I think it's caused by the waste ink around the head.
Posted on May 29, 2009
This evening I bought a new HP Photosmart C4780 printer. I am trying to print photos now and the photos are being printed with small vertical lines across the whole photo. How do I get rid of them?
> I bought a new printer
Take it back, and get one that does work correctly.
> VERTICAL lines ACROSS the whole photo
Hold the paper in "portrait" mode, not "landscape" mode.
Are the lines HORIZONTALLY-ACROSS the paper,
or VERTICALLY-DOWN the paper?
If those lines are WHITE and HORIZONTAL,
then some of the many ink-jets inside the print-head are *CLOGGED*.
Run a "print-head-cleaning-cycle" to try to unclog it.
Or, exercise the WARRANTY, and get it replaced.
Sep 24, 2010 | HP Office Equipment & Supplies
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Lines running horizontally across the printed colour page
Checked ink cartridge's, two had dried out, still had ink in them but the exit apertures were blocked.
So new set of ink cartridges and problem fixed.
Thank you
Jim
Feb 05, 2010 | Canon PIXMA MP610 InkJet Printer
Colour printing comes out in lines across the whole page
Is the nozzle is perfect? i dont think so. But, if you print with best/photo mode is ok.
Jun 01, 2009 | Canon i850 InkJet Photo Printer
I put a new ink cartrige and printer prints low coulour tone.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark Color JetPrinter 5700 InkJet
Horizontal black lines across page.
Horizontal lines usually indicate a toner cartridge that is not cleaning properly.
A. If the distance between defects is 38 mm (1.5 inches), 47 mm (1.85 inches), or 94 mm (3.7 inches), the print cartridge might need to be replaced.
B. Clean the printer.
1. Clean the inside of the printer and run a cleaning page to clean the fuser.
Over time, particles of toner and paper accumulate inside the printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems.
To clean the inside of the printer
1. Turn the printer off and unplug the power cord.
2. Open the top cover.
3. Remove the print cartridge.
4. With a dry, lint-free cloth, wipe any residue from the paper path area and the print cartridge
cavity.
5. Reinstall the print cartridge and close the top cover.
6. Plug in the power cable and turn the printer on.
Cleaning the fuser:
Run the printer cleaning page to keep the fuser free of toner and paper particles that can sometimes accumulate. Accumulation of toner and particles can cause specks to appear on the front or back side of your print jobs. To ensure optimum print quality, HP recommends that you use the cleaning page every time that you
replace the print cartridge or on an automatic interval that you can set up. The cleaning procedure takes about 2.5 minutes to complete. A CLEANING message appears on the printer control panel display while the cleaning is taking place.
To run the cleaning page:
In order for the cleaning page to work correctly, print the page on copier-grade paper (not bond, heavy, or rough paper).
1. If your printer model includes a duplexer, open the rear output bin.
2. Press Menu to open the menus.
3. Use (Up button) or (Down button) to scroll to CONFIGURE DEVICE, and then press (Select button).
4. Use (Up button) or (Down button) to scroll to PRINT QUALITY, and then press (Select button).
5. Use (Up button) or (Down button) to scroll to CREATE CLEANING PAGE, and then press (Select button).
6. Follow the instructions on the cleaning page to complete the cleaning process.
7. If your printer model includes a duplexer, close the rear output bin.
If this helps resolve the problem, please post a reply. Binary Bob
Sep 11, 2008 | HP LaserJet 2420 Printer
Epson stylus photo R2400
I had this trouble, went through cleaning & realignment, then various print options. What i found was that dark colours had faint dark horizontal lines 5mm apart when printing on Photo in the epson driver. Changing it to Best Photo solved it.
Jul 31, 2008 | Epson Stylus Photo R2400 InkJet Printer
Epson Photo R265 Lines every 2.5 cm
Check status monitor see if cartridges are low or nearly empty , if new or full take out all cartridges and soak nozzles upright in cleaning solution overnight , or untill ink starts to bleed out:
Dab dry and re - fit , make up a A4 paper page with 6 colour bands about 1" high x 8" wide and print about 4 to 6 pages ,
check which colours are poor , if improvement is observed run
again a few times:
If one colour is poor take out that cartridge and soak again for a few hours , try again:
If no improvement replace with new cartridge or use a cleaning cartridge ( available on-line ) :
Using the head-cleaning utility shortens the life of the printer as the printer is set to lock-out after a pre-set use of the cleaning facility: and will have to be re-set instore:
cx3200@tiscali.co.uk
Dec 17, 2007 | Epson Stylus R265 InkJet Photo Printer
Horizontal line on prints
Put plain paper in the printer and try to clean the nozzles.
-Start->All Programs->Lexmark 5400 Series->Lexmark Solution Center->Maintenance->Clean to fix horizontal streaks.
Steve
Sep 12, 2007 | Lexmark X5470 All-In-One InkJet Printer
Colour lines across the page
Hey Paul, Can you post a scan of the printed paper? It may help diagnose your problem. The most common cause of lines accross the page is either the PhotoConductor Unit or the 2ND BTR Assy.
Nov 30, 2006 | Epson Aculaser C1100 Printer
212 people viewed this question
Seeker5211
Seeker5211
