Dvd says 'bad disc' - how can I fix this?
Dvd says 'bad disc' - Conia DVD player, how can I fix?
I solved this on my CH-DVD 300. The laser slides in and out on two rails. It's supposed to be in the far inside position to load/read a DVD. If it's too far out of position it does not automatically return to the far inside position on startup or eject/load. I manually pushed the laser assembly to the far inside position and now my player is working perfectly again.
The laser was evidently jarred out of position by a mechanical shock, or perhaps the power failed while playing a DVD and left it out of position.
Posted on Sep 17, 2009
  • 67 Answers
If it is a bad disc buy a new one or clean the lense
Posted on May 29, 2009
2 Suggested Answers
Dipu007
  • 2110 Answers
SOURCE: any disc put into dvd player shows up as BAD DISC
your DVD player lens needs to be cleaned by a lens cleaner...
Posted on Feb 09, 2009
I have a HD video file to burn to dvd. Need to know What compression function I can use , so I can use to burn and play on the Conia dvd player
Winrar compress it if it is too large to be loaded on a CD. You can compress to parts then extract the parts to he burned on a CD
for the burn cd you can download nero for free
May 07, 2015 | Conia Televison & Video
Just got an RCA TV from a friend. It is the 32 inch DVD combo. The DVD player isn't working. I can slide the DVD in and it will attempt to play it but it can't seem to read it. Does anyone know how to fix...
Now u put in a DVD movie disc into the DVD player slot.The DVD disc still register on the tv LCD screen,but just don't read the DVD disc?Yes.Tries websites like Amazon.com,Ebay.com to buy a DVD cleaning disc kit to used to clean the DVD laser eye of the DVD player slot,after this it should work.If tv still have the same result,than this tv problems DVD player slot can't be fix or worth fixing because the DVD player slot laser eye is bad or dead alredy.
Apr 24, 2011 | RCA L32HD32D 32 in. LCD HDTV
I put a disc into the machine and it keeps saying no disc
Check the disc,see if it dirty or cracks?Tries it,with other DVD disc,same result.Ur DVD player have a bad Laser eye data's readers.Not,worth fixing as u know totay DVD players are really cheap,these days.U can get a brand new DVD player for like $40.
Nov 03, 2010 | KLH DVD8350 DVD Player
Any disc put into dvd player shows up as BAD DISC
Feb 09, 2009 | Conia DVD8500 DVD Player
Conia M580 DVD player has died, cannot open disc tray to retrieve DVD disc from player. Cannot unlatch the disc tray manually, as there's no pin-hole near the disc tray, unlike most (more expensive) DVD...
Easy... follow these instructions
  • unplug from the mains
  • take the cover off (3 screws on back panel, 1 screw each side, sticker on top front)
  • You will see the DVD disk in the player drive
  • Remove the plastic ******** top of the drive - 2 x small phillips screws
  • Lift out the DVD disk.... done.
Oct 31, 2008 | Conia DVD8500 DVD Player
Dvd player problem
get a dvd cleaner from best buy. mine did the same thing, it would not play any dvds so i resorted to vhs, and once i had watched all of those, i finally got a dvd cleaner and now it works fine
Jan 20, 2008 | GoVideo DV2150 DVD VCR
DVD eating discs
It's obvious that the DVD is stuck in the player. There's only one way to get it out! You have to open the DVD player. If you have never done this before, I don't recommend that you do it.
Apr 17, 2007 | Conia DVD8500 DVD Player
Firmware for conia 160gb dvd recorder
sir try this link! http://www.dtvforum.info/index.php?showtopic=32172&pid=632554&st=40&#entry632554
Apr 06, 2007 | Conia DVD8500 DVD Player
Conia dvd player problem
Dale, Have you tryed yet to clean the lens surface on the dvd player yet ?? A small build-up of film or dust can make a cd/dvd player's tracking ability to go downhill quit fast. The lens Im talking about it on the Laser Pick-Up assy. Us an approved cleaning disc to do this or take off the top cover and take a small q-tip with just damped with alcohol. Very carefully clean the surface in a circular motion and let dry then clean again with a dry q-tip to get off anything lefyt on the lens. Now for the disc. Those small scratchs can be gotten rid of with a disc resurfacer. The disc resurfacer will work on very minor and shallow scratchs. you can only get rid of them if you dont see any dark inside the scratch or you can barley feel the scratch with your thumb nail. If the cleaning dosent assist you then the unit will neeed a tracing/focus alighnment and thi is something you cannot do unles you have an alighnment/service manual and the proper equipment-ie scope & alighnment disc's. Good Luck
May 02, 2006 | Conia DVD8500 DVD Player
Televison & Video Logo
884 people viewed this question
Top Televison & Video Experts
