Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Trouble installing I am trying to follow the wizard set up on my new d link dsl-2740B wireless router but I can't get passed the plug in the wire stage! I even tried different wires. It say's to check the wires again or something about a network card. HELP!
    Guru:
  • 523 Answers
Initially check wither u can ping from ur PC the ip 127.0.0.1(go to start--->run---->type cmd---> in the black screen type ping 127.0.0.1).If u got the reply then the nic card is installed properly.
The wire connectivity should be as follows,
1.Connect the RJ 11 to phone pine jack at the back side
2.Connect the PC to the other any one of the Port and try to login in to the router with the help of the browser 192.168.1.1.
3.U will get the page of the router and try to configure the ip address in hte particular columns
4.If its dymanic then once u have connected u will get the internet.
Regards,
Ayyasam
Posted on May 29, 2009
Problem with modem router DSL-2740B
1.Reset-
The factory reset button is located in the back panel of therouter, and requires a thin, sharp and robust object (like anunfolded paperclip) to be pushed in.
To factory reset, power up the device and wait for 1min. Pressand hold the reset button until the STATUS LED turns off. Releasebutton and wait 1min.
2.Update the firmware-download the required files from the D-Link Support page
3.Contactct your ISP
Jun 13, 2012 | D-Link Wireless-n Adsl2 4-port Modem...
My D-Link DSL-2740B modem Router is already installed and working for all the computers but trying to hook up the Vista OS computer and wireless access is asking for to enter 8 digit PIN. I can not find 8...
Well the PIN number is Usually on the router itself on the back side and its a 8 digit number if that works well and good. Open an Internet Explorer browser page on your wired computer(desktop).In the address bar type - http://192.168.1.1 and press Enter... Leave Username blank & in Password use admin in lower case...8 Dec 2011
Need PIN number! - Networking, Internet, Wireless Forum ...
en.community.dell.com/support-forums/network-internet-wireless/f/3324/.../19426225..or go to this link and see if it helps you find were it is..... Link DSL 2740B modem Router pin number Google Search
Oct 23, 2017 | Computers & Internet
PPP Password doesn't match error
1. You should better check the power supply if it is plug on, properly on a 220AC Voltage. 2. After installing your disk suppose to be you should reset the configuration of your DSL 2740B so that it will restore back to the main configuration of the system. (to reset your DSL 2740B try to look for a small button on it. then press according to standards then your done. Good luck and i hope this steps will help you accurately. God Bless.
Apr 07, 2010 | Zoom X6 Adsl Wireless Gateway Rohs Router
Dsl wont pass thru router wired or wireless I have reset the router several times, the computer shows connected ,signal strenght excellent, but will not connect to the internet wired or wireless as long as...
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 28, 2010 | D-Link 802.11g Wireless Router WBR-1310...
D-link range booster installed on main PC, still
Check your wiring:
Cable-modem (or DSL-modem) <---> WAN-port on Router
LAN-port on router <--> network-port on your desktop computer
Follow the instructions that came with the router,
to access the built-in web-server "inside" the router.
Run the "Wireless Networking Setup Wizard" to configure your wireless network.
Now, try to access your newly-defined network from your laptop.
Jan 08, 2010 | Acer Aspire 5500 5570-2609 Laptop
Driver
not sure why you will need USB drivers for your adsl2+ modem/ wireless router and 4 port LAN switch. It would help you had provided the model number.
The device uses a LAN ethernet port to connect to the computer. You will need atleast one computer to be on the LAN port for setting it up. Once setup is complete you can use wireless connection for every computer.
The user manual & drivers or the DSL-2740B which appears similar to your product description
http://www.dlink.com.au/tech/Download/download.aspx?product=DSL-2740B
Not sure if you need these. Your computers will need LAN or wireless drivers to connect to this DLINK modem/ router.
Good luck
Dec 25, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Can not get wireless router to work
Follow this link
http://www.dlink.com/products/?pid=474&sec=0
D-LINK WILL HELP YOU...
Set up your new D-Link networkinghardware in minutes using our new Quick Setup Wizard. The wizard willguide you through an easy to follow process to install your newhardware and connect to your network. If you need additional help,visit D-Link’s award-winning Customer Support Web Site for answers tofrequently asked questions, product downloads, and easy access toD-Link’s friendly customer support team.
Do you clean your internet browsing history and temporary files on a regular basis?
Also: Try calling your DSL provider for tech assistance. The modem may need to be reset or upgraded.
Jun 08, 2008 | D-Link 802.11g Wireless Router WBR-1310...
ISP blocking access after new router installed.
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix and use supportcall as your promo code for 1 free technical support.
May 26, 2008 | NetGear WGR614 Wireless Router
ROUTER NO T BEING DETECTED
The DSL filter shouldn't be hanging from the computer. DSL filters are supposed to go on the cables that your phones are plugged into.
Jan 18, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
We bought a wireless router can you help me set it up where do the wires go
Hello, The wire from your cable modem plugs into the WAN (labelled "connect to modem") port on your wireless router. You then need to install the software on your PC to set up the router.
Sep 30, 2007 | Belkin (F5D9230-4) Wireless Router...
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
162 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
