Question about Saws
Loose cicular saw and nut tightened fast all the way.
I have a Hyundai HD-7500 circular saw. The blade is loose and wobbles despite the central nut being tightened all the way. Now I can not tighten or untighten the nut since it rotates both ways with the dormant motor. How do I solve this so that I can tighten the saw in place to start working?
  • Samuel Charles Spriggs May 11, 2010
    Is there a washer on the saw-blade bolt?
Lester and SCSpriggs,
Thanks for suggesting a solution. I've just managed to solve it with the help of someone in a technical store. We released the nut and found out that the plate that secured the blade in place was back-to-front. The side that should have faced inside has a bevelled edge and this was causing the loose contact of the blade that wobbled. So thanks anyway for your advice.
TaskerGHM
Posted on May 31, 2009
    Sergeant:
    Champion:
  • 226 Answers
2 POSSIBLE THING'S ,1 THE BLADE IS BENT ,A CAUSE OBEING PINCHED IN MIDSTROKE OF CUTTING OR IF NOT THAT YOU CAN GET A FLAT WASHER TO USE AS A SPACER BETWEEN THE ARBOR BOLT AND THE BLADE TO MAKE UP THE DIFFERENCE.MAKE SURE YOU HAVE THE RIGHT ARBOR DIAMATOR BLADE IN THE SAW FIRST HOPE THIS HELPS.(PLEASE RATE THIS) THANK'S
Posted on May 30, 2009
Macallister chop saw blade problem, the motor runs but when half way through cutting wood the blade stops ?
I'm not sure if you have a chop saw or circular saw. Either way, it sounds like the nut and washer are not tight enough to hold the blade. If you have a circular saw clockwise will tighten the nut and washer onto the blade and hold it in place. Most chop saws are a left hand thread and then you would turn the nut counter clockwise to hold the blade tighter. The blade wobbles because it is not tight.
Feb 23, 2015 | Saws
Why does the blade stop working on my circular saw when I'm using it
Your either pushing the saw crooked into the cut or the nut holding the blade it loose. Make sure you unplug it before you start fooling around with the blade.
Oct 13, 2014 | Skil 7 1/4" Circular Saw Corded 2.5 Hp...
Why won't my saw blade go on tight. the mechanism that secures the blade won't tighten down good enough.
You need to make sure the blade is centered properly on the washer on the spindle as you tighten the nut. It can slip off while you tighten the nut. Tighten the nut a little at a time while you wiggle the blade to make sure it's seated properly in the washer.
Sep 14, 2014 | Dewalt Heavy-Duty 36V Cordless 7-1/4"...
Circular saw motor turns when tightening saw blade
Insert a tool such as a screwdriver across the blade guard and against a tooth to prevent blade rotation, then tighten the blade nut. Be sure to remove the wedging device before operating the saw
Dec 29, 2012 | Now Evolution #Fury 7 1/4" Mp Circular Saw
Saw will not tighten when wrenching center nut blade slips
Unplug the saw. Put the blade on and finger-tighten the nut. Then rest the blade on a piece of scrap wood so that it won't slip. Then tighten down the nut and you should be fine.
May 21, 2011 | Craftsman Saws
Can't tighten circular saw blade, actually when it tight the blade is blocked and if I loosen it, is too loose.
You need to use the correct (reduction) ring adapter for the cicular blade you intend to use: the adapter 'washer' needs to be the exact size for the middle blade hole and the motor shaft. If ensure, as it is a lethal tool, ask your friendly hardware shop handyman for advise and direction.
Hope it helps.
Sep 27, 2010 | Ace Hardware Power Glide Circular Saw with...
Can't tighten the blade- it spins
Use a round shaft screwdriver place between the blade teeth to prevent it from turning.
Mar 04, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Ryobi 18v circular saw owners manual - blade is loose!
Usually there is a button to press that locks the shaft arbor and then you use a wrench to tighten OFTEN is a left hand thread!
Check for lock button behind the blade guard toward the motor.
Sep 28, 2009 | Ryobi P501 18v Circular Saw Only
Loose replacement blade
I completely removed the blade and put it back on, tightening the locknut, and now it works perfectly. The blade has not come loose and have used the machine for the last 3 months. The only thing I can think of is that somehow I didn't have the blade correctly installed in the first place, although it didn't wobble or anything.
Jan 25, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Saws Logo
307 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
