Question about Sharp Office Equipment & Supplies
Set up i am a newbe and i am having problems setting it up to copy and work thanks
  • 122 Answers
Setting up the Copier
  1. Open the HP Color Copier product box and remove the User’s Guide. Review the information in the User’s Guide.
  2. Finish unpacking the HP Color Copier. This is best accomplished by resting the box on its side with the unit in the upright position. Pull the unit (foam and all) out of the box. Step 2: Unpacking the HP Color Copier set up - c00222172.jpg
  3. Remove any tape or other packing materials from the unit. Be sure to check inside the machine by opening the cartridge access door.
  4. Verify that you have the power adapter, power cord, print cartridges. If any of these items are missing contact the HP Customer Care Center in your region.
  5. Set the HP Color Copier on a level surface large enough to support it fully.
  6. Load the paper supply tray with paper following the directions in the User's Guide.
  7. Verify that the paper tray is fully inserted into the HP Color Copier and that the rear access door in the back is in the locked position (the copies will be skewed or paper will misfeed if it is not fully locked). Step 7: Verifying that the rear access door is locked
  8. Owners of HP Color Copier 280 and 290 models should verify that the ADF (automatic document feeder) cable is securely plugged into the base unit and secured in the holding clip. Step 8: Checking the ADF cable
  9. Plug the power cord into the power adapter. Step 9 and 10: Connecting the power c00222175.jpg
  10. Plug the power adapter cable into the unit, then plug the power cord into a power source, preferably a wall outlet.
  11. Press the Power button on the right side of the front panel to power it up.
  12. Open the front panel to access the print carriage. Raise both cartridge latches after the print carriage comes to the center. Step 12: Opening the front panel and raising the cartridge latches c00222176.jpgc00222177.jpg
  13. Remove both print cartridges from their containers being careful to only touch the black plastic portions. CAUTION: Do not touch or remove the gold colored contacts.
  14. Carefully remove the tape that covers the print nozzles on the bottom end of the print cartridge. Step 14: Removing the protective tape c00222178.jpg
  15. One at a time, insert the cartridges into the print carriage and latch them into place. Step 15: Inserting the print cartridges
  16. Close the access door.
  17. Observe the display and confirm and/or set the language by entering the language code. The following steps will change the language on the front panel:
    1. Press MENU.
    2. Press 3, then 5.
    3. Scroll to the correct language and press ENTER.
  18. The display should read “Press ENTER to Align Cartridge”. Press the ENTER button on the front panel to accomplish this task. The self-alignment process will begin and an alignment page will be printed. Verify that each task has a green check mark beside it. Step 18: Ink cartridge aligset up - c00222181.jpg> c00222181.jpg
Posted on May 29, 2009
Is my display broken?
Hi try this if correct for you https://img.musicworld.bg/pdf/i/2/5/3/25352/AxiomPro_Manual_EN.pdf
Also YouTube has some people so may be you could ask after reading the instructions as it may be just an update required.
No such thing as a Newb we all start from base so you are a rung up now good luck and please reply as it can help others
Dec 26, 2017 | M-Audio Axiom Pro 61 Advanced 61-Key USB...
My copies come out way too light but when printing from computer prints fine. do i need to change out something that is specific to copying rather than in the actual printing of things? Thanks for any...
That not a problem, that OK
some of the printer low quality is working like that as you have not specify your printer brand name and model name that all i can answer it
Mar 19, 2011 | Office Equipment & Supplies
Printed copy in correct page order- HP officejet 6110
Hi :)
This may work and its only a few simple clicks :) but it will take less time then re ordering you pages :)
IN the printer settings or Print preferrences there should be a tab for "Advanced settingings"
Go to Control Panel and select "Printers"
Select the general tab and at the bottom of the window select "PRINTING PREFERENCES"
another window will open
from here select the Advanced tab
Find Layout Options in the list
click it you should see "Page Order" and a drop down menu for front to back or back to front.
switch it to whatever order it is that you need and test it out.
or if that doenst work try this:
Set the most frequently used copy settings as the default. This includes changes to Copy Setup options in the menu system, as well as other front panel copy settings.
  1. Make any desired changes to the copy setup from the menu or the front panel copy option.
  2. Press Menu .
  3. Press 1 , then press 4 . The settings are now saved.
these are the only ways I have found to correct the problem.
May 18, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Trying to print multiple copies and only one copy prints
Hi, my name is Juanita and I will try to help you with your problem.
What kind of printer do you have? And when you say you can't print multiple copies, is it the problem with setting the number of copies in the print dialogue box, or is it the problem for printer settings?
For this problem, I contacted the Inti Prima Karya. It is a cheap printing solution for all your printing needs. It would be much cheaper to use their offset printing solution.
Nov 05, 2017 | HP DeskJet 6122 InkJet Printer
My hp 1320 prints multiple copies instead of one copy
Go to "printers and faxes."
Right click on your printer and select "Printing preferences."
Select "Advanced" tab
Double click "paper output"
If "Copy count=2" then change to 1 and apply
IF IT ALREADY IS SET TO 1 THEN:
Set "copy count=2" then APPLY
Repeat the above and now set "copy count=1"
The process of setting and resetting the copy count fixed my issues.
Dec 03, 2008 | HP LaserJet 1320 Printer
Xp pro no sound
I had the same problem.....and at first even i had reinstalled the realtek driver n it dint work..!!......................Try reinstalling your operating system n it should WORK....!!!!!!!!
Oct 20, 2008 | Computers & Internet
Problem with the LCD Screen
I think your problem is the ccd image sensor,this is a common fault with some sony digital cameras
Sep 11, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
Just brought a Fax JX200 and am having great diffuclty working out a problem , problem being we also have a 2 phone dual handset and the problem is when the phone rings it goes straight to fax on all 3...
It sounds like Tel/Fax mode is not set, but that the machine is likely in Fax Only mode. The JX200 has four modes of fax receipt - Fax/Tel, Manual, Answering Machine, and Fax Only. The Fax/Tel mode, which you have indicated is your desire, is meant to let the fax machine automatically switch between fax and voice calls. Documents are received automatically, and the machine rings for voice calls.
Set the mode by pressing [Receive Mode/Resolution]. Every time you press [Receive Mode/Resolution], the mode changes cyclically. If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings:
• Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting).
• Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting).
• Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting).
1. Press [Menu].
2. Use arrows to select <DATA REGISTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>.
3. Use arrows to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>.
4. Use arrows to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>.
5. Press [Start/Copy]. The LCD displays <8SEC.>
6. Use the numeric buttons, or arrows to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice. (This is the time the machine spends checking for a fax signal before ringing for the call to be answered as a telephone call.)
7. Use the numeric buttons, or arrows to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>.
8. Use arrows to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6.
9. Press [Stop].
Setting ends and the fax returns to standby mode. The machine will now handle calls as indicated in the settings you input.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Aug 11, 2008 | Office Equipment & Supplies
How to use buttons on front of Monitor for vertical Horizontal settings
Oldie, The first thing to do is set the monitor resolution, color depth and monitor refresh rate to what you want then adjust the monitor accordingly. Adjust resolution, color depth and refresh rate for Windows 2000/XP: -Right click any clear spot on your desktop and select properties from the menu that appears. -From the Display Properties box that appears click on the Settings tab. -In the screen resolution section (lower left corner) experiment with the resolutions and see what you like. -The color quality box should be set to the highest (most colors) color setting listed. -Click on the advanced button in the lower right corner. -In the next window click on the monitor tab. -Typically you would want to set it at 70 Hertz or better. The higher the setting the less flicker you will notice, however, there is always a trade off. I would start with 70 Hertz and gradually move up; at some point your monitor will reach a setting it can?t support. If the screen blanks out Windows will reset back to the previous settings as long as you don?t hit any keys. -click the OK button twice. More to follow?.
Mar 14, 2007 | ViewSonic E790 Monitor
85 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
