Question about Samsung CoolTech Plus / Basic Bottom Mount Refrigerator SR-L676EV
Change the light in the fridge of the cooltech plus
How do i get the cover off
  • 158 Answers
Try pressing sides then pull
Posted on May 29, 2009
I have a Samsung Cooltech Fridge/Freezer.....I changed the internal light bulbs and have no Internal light....what do I do ?????
before I sugest an idea I will ask you to make sure the new bulbs are not damage you can make a test with anything you may have at home that requieres a bulb less than 100 watts.if the new bulb is working unplug the fridge and try to pull out the center of the socket were the bulb rest is a small metal plate.use a pen,pensil plastic knif or regular kitchen knife tu open it but no to break it all the way just make sure your fridge/freezer is completly UNPLUG FROM THE POWER OUTLET
Aug 12, 2012 | Samsung CoolTech Plus / Basic Bottom Mount...
My Samsung Cooltech plus fridge's temperature keeps on skipping back to 9 degrees celcius. Freezer is working fine, what can the problem be?
Every time I select my fridge and freezer temperature from -16 and 3 degrees C respectively it keeps on going back to 20 and 18 degree C. Please assist.
Mar 11, 2011 | Samsung CoolTech Plus / Basic Bottom Mount...
Please help me I have a samsung refrigerator cooltech plus but no could refrigerator & frizer
Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. I hope this helps you. Best of luck.
Feb 15, 2011 | Samsung CoolTech Plus / Basic Bottom Mount...
I have a Samsung Cooltech Plus fridge that seems not be able regulate the temperature correctly. At times the temparature is 22 celcius and food gets spoilt, I tried switching it off and on again but that...
Keep your hand on condenser coil if it's visible or left and or right side body of the fridge. If you feel hot the gas is o.k. Otherwise no gas or chock. You have to repair and refill the gas.
Dec 08, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Samsung Cooltech fridge - type SR-52NXA - when working very strange noise coming from the fridge. The "pole" from air mixing flow system is not turning/spinning
Yes, I had this problem. $85 visit from a very condescending repair man located a piece of old hard cheese that had become wedged in and stopped the thing from turning - the noise had been terrible. Fixed in 2 minutes - embarrassment lasted much longer.
Jun 05, 2009 | Samsung CoolTech Plus / Basic Bottom Mount...
We own a samsung cooltech plus, something, something. The freezer is working fine, but the fridge's temperature suddenly jumped from 3 degrees celsius to 9 degrees celsius. We can't seem to change the...
Im no expert, but you can try this, take the back bottom cover off and you will see two drairn pipes going into a drip tray. remove those pipes ( just pull them down ) make SURE they are not blocked ( there is a rubber thing at the top that can close up--- just cut it open ) place a bucket under those pipes and leave your fridge off and the doors OPEN........ it may take a couple of days for ALL the ice to defrost. when you think its done--- leave it a few hours and if there is any water being collected --- you still have ice in there. i was amazed at how much and for how long water kept dripping out of the fridge drain pipe.... the pipe nearest to the compresser is for the frezzer, If the sensor that tells the fridge to get cold is all iced up it wont even try to get cold--- it thinks it is already.
Dec 18, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Cooltech super xflow not circulating
hi
there is problem with x flow motor which is located inside the ref temp. assy. in frige section.this problem dosen't affect the cooling of fridge.this problem can resolved by replacing the x flow motor
yours
sandesh
May 15, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Assistance required
A thermostat would have nothing to do with this problem. Condensation occurs when warm air moves into a cold place. Check door gaskets or any possible way that warm air is getting into the cabinet.
Nov 07, 2007 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
380 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
