Question about Epson Stylus S20 InkJet Photo Printer C11CA22303
Epson s20 genuin ink not recognised
Epson stylus s20 printer not working. Only 3 weeks old. Status monitor window says "printer not ready to print" Ink tank icons are blanked out as grey. Cannot find the device in device manager. Cannot uninstall or install the driver. i only had the s20 for bout 3 weeks and all of a sudden i got an error mesage while printin sayin sumink bout ink cartridges not being recognised when i have the genuine ink installed. replaced tha ink and den tha problem kept comin bak.. aint got time or tha money to keep gettin tha ink.. even bought a chip resetter that dont even work.. need to find a way of overidin tha epson printer monitor. need help :|
  • Epson Master
  • 511 Answers
I think the problem is in your windows, try to reinstall your windows. I suggest, don't reset the original chip, cause it's damage the chip.
Posted on May 29, 2009
Ho do i know which ink cartridge is low
Hi
the easiest way is to send a print job to printer. If any cartridge is empty, the printer should refuse to print and display an error message. This should indicate which cartridge is empty/not recognised - with a red X above the empty colour. Another way is to go to 'printer properties' then 'maintenance' page and click on 'Status monitor' button.
Hope this helps & good luck with it.
Oct 03, 2014 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Epson 2100 will not recognise new cartridges
Change ink tank using "How to..." at Epson status monitor. Check contactor that connected to ink tank chip at carriage. Other possibility is CSIC board (behind the contactor)
Jan 21, 2013 | Epson Stylus Photo 2100 InkJet Printer
Epson s20 cannot recognize ink cartridges
have you bought genuine ink cartridge?? if it isnt genuine or original the printer wont recognize it at all..
Jun 02, 2010 | Epson Stylus S20 InkJet Photo Printer...
My epson stylus s20 printer wont recognise genuine ink cartridge
If you are having issues printing, this could be caused from your printhead needing to be replaced.
May 31, 2010 | Epson Stylus S20 InkJet Photo Printer...
How do I know WHICH of the ink cartridges is out?
I found this on the Epson Web Site. If you find this information helpful, pls rate me.
You can download the Reference Guide with pictures and all.
http://files.support.epson.com/htmldocs/r220__/r220__rf/index.htm
Windows
You can check the amount of ink remaining in the ink cartridges using EPSON Status Monitor 3 or the progress meter. Refer to the sections below for details.
EPSON Status Monitor 3 Access EPSON Status Monitor 3 in one of the following ways.
  • Double-click the printer-shaped shortcut icon on your Windows taskbar. To add a shortcut icon to the taskbar, see the section below.
    font26.gif See Monitoring Preferences
  • Open the printer software, click the Maintenance tab, then click the EPSON Status Monitor 3 button.
A graphic displays the remaining amount of ink.
If any of the ink cartridges installed in the printer is broken, incompatible with the printer model, or improperly installed, EPSON Status Monitor 3 will not display an accurate calculation for the amount of ink remaining in any of the ink cartridges. Be sure to replace or reinstall any ink cartridge indicated by EPSON Status Monitor 3.
Pls rate me. Thanks and Good Luck.....
Feb 09, 2010 | Epson Stylus Photo R220 InkJet Printer
Epson S20 inkjet printer does not recognise genuine Epson inks
This is usually a sign of the print head being done. Printer heads are usually more than the price of a new printer. Too bad about the inks though. Most places wil take them back even if they are opened. Solution is to buy a new printer. I have had much better luck with my Canon.
Cheers
Allen
Sep 11, 2009 | Epson Stylus S20 InkJet Photo Printer...
EPSON Stylus S20 print cartridges not recognised.
Try reinstalling cartridges make sure you remove the yellow strip.Ok turn your printer off and back on while installing cartridges ,if this dosen't work disconnect printer cable then turn printer on then off reconnect cable turn on again also disconnect power to printer then reconnect if all fails call Epson and your warranty may cover this
Aug 27, 2009 | Epson Stylus S20 InkJet Photo Printer...
The printer won't recognise the printer cartridges. I tried replacing older cartridges with new ones and even this doesn't work. They are genuine epson cartridges and the same ones I have always bought.
Check chip connnector at ink tank and at head carriage. It's may be dirty. Check status monitor? what ink tank not recognized. Press ink light (1-4 times) depends on number ink tank not recognized, press 1 time again, carriage will move co replacement position, unplug and plug again all ink tank, press ink light 1 more.
Jun 29, 2009 | Epson Stylus C46 InkJet Printer
Epson S20 does not recognise cartridges
It should be returned to the seller for exchange under warranty.
I presume you have removed the tags on the cartridge and ensured they have chips on the cartridge case? If all that has been done then i would be making a warranty claim
Jun 21, 2009 | Epson Stylus S20 InkJet Photo Printer...
Epson Stylus S20 InkJet Photo Printer C11CA22303 Logo
1,592 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
