Question about RCA F32649 32" TV
Rca color tv 32
The  color  stays  red   and  want change
    Scholar:
  • 135 Answers
Hi there!
The colour Amp may have failed or the Tube itself may have a faulty Cathode. There may also be loose solder connections on the Board. If not familiar with TVs, please refer to a repair Technician. Good Luck, JUS004
Posted on Mar 09, 2008
2 Suggested Answers
  • 250 Answers
SOURCE: RCA 32'' TV
Unfortunately, the Power Supply has spat the dummy out. It is giving enough power to light the LED but not enough to run the set. To replace it will probably cost more than buying a new set. But ask around your local repairers for a price before you make any decisions...
Posted on Feb 23, 2010
What do i replace koleston perfect 5/75 with ? i dont like red violet but i want to stay wit the same range
I have a couple questions. A: What is your natural color and do you have any gray?B: What is your target color? C: Do you want to be Auburn or more of a solid red?
Jan 25, 2013 | Wella Koleston Perfect Permanent Creme...
My rca tv screen is red i cannot see clearly the picture
1) test the power supply for color you will get +12Vdc.
2) test a) demo color b) ampli out for color some is defective. see the block attached.
God bless you
Sep 22, 2012 | RCA F32650 32" TV
How to make a remote responed to a rca tv model f32450
Hello
Setup codes for RCA TV are given here. Try with them, and get the proper code, y which you can get more functions to operate with:
Three digit codes for RCA TV are:
000/ 003/ 004/ 005/ 007/ 009/ 011/ 048/ 078/ 082/ 083/ 094/ 096/ 098/ 099/ 101/ 102/ 103/ 107/ 113/ 129/ 133/ 167/ 179/ 181/ 187/ 188/ 194
Four digit codes are:
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    Five digit codes with RCA RCR 312W remote control are:
    10000, 11447, 10051, 10093, 10679, 11047, 11147, 11247, 11347, 11781, 12002, 12187
Feb 12, 2012 | RCA F32450 32" TV
I have an RCA L32HD31R LCD tv that has: - Double imaging - Red, blue and green are unaligned - 2/3 of the screen is has a background that flickers random colors (usually purple to turquoise) - Lines and...
I have one doing the same thing. I noticed capacitors on the power supply were bulged slightly but everything else looked fair but dirty. I blew it out with compressed air and there seemed to be a change but I am still stuck in the same place myself....
Jan 30, 2011 | RCA L32HD31 32 in. LCD HDTV
My RCA 32" TV 2001 is black and white but the menu
Ours had a problem like that. The digibox and the dvd player (anything plugged in with a SCART lead) only played in black and white but the tv menu screen was in colour.
Also anything plugged in with those three little thingies, the red/yellow/white thingies, played in colour so we just bought a converter between SCART and the three thingies.
Sorry for how useless this was, I'm not great with all the technical language. Hope it helped in some way.
Dec 04, 2010 | RCA F32672SB 32" TV
My 19 inch ViewSonic monitor shows red /voilet
Please check the VGA cable at both ends to make sure there are no bent pins and fit into the socket properly at both ends. Also try this monitor with other PC also since it can be in the video card.
Apr 25, 2010 | ViewSonic VX912 19" LCD Monitor
Can't hook vcr to tv
on the back of your VCR there will be a yellow colored port - most likely labeled "OUT" as well as possibly a white/red pair of ports.
The yellow is for a VIDEO hookup, the white and red are for AUDIO hookups.
These ports use what is called an RCA type connection.
Radio Shack, or just about any department store should be able to sell you an inexpensive set of RCA cables.
now on the back of the TV (possibly on the side) you will also have the yellow, white and red ports.
Hook one end of the RCA cable to the colored ports on the VCR, the other end of the cable to the colored ports on the TV.
last thing - the TV most likely has multiple inputs. there is probably a input button on the TVs remote, you need to press that button to cycle through the inputs until you get to the one the VCR is hooked up to.
its easiest to put a tape in the VCR and press play - when you get to the right input, you will see your tape...
good luck
Apr 05, 2010 | Dynex DX-L32-10A 32" LCD HDTV
Can my alpine 9883 change colors?
The screen stays white but there is a way to change button color blue/red can't remember exactly I think it is in the func/setup button
Mar 22, 2010 | Alpine CDA-9883 CD Player
RCA F32649 32" TV Logo
41 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
