Question about Smeg DWI614 Built-in Dishwasher
Wash cycle starts but does not run.
My DW 1614 dishwasher comes up with error code E1 which isn't listed in the troubleshooting guide, the lid to the soap /tablet dispenser does not open either. Thanks.
  • mark_palm495 May 29, 2009
    I was impressed how soon i got a solution to my problem.
    Sergeant:
  • 187 Answers
please rate my suggestion..Thank u for using Fixya...
Posted on May 29, 2009
We have a dw1614 our program wont start at all
Posted on Jun 29, 2009
Hi. Can you tell me what E1 means on the display
LG Dishwasher Error Code E1 How To Clear
Based on your model number ... it is probably an LG appliance.
Use the link above to learn about the E1 error code. According to the web site ... there is a chance that nothing is broken and the code may have been caused by how the dishwasher was loaded. The web site lists 7 reasons why the E1 code came on.
Helpful?
Good luck with your troubleshooting
Jan 25, 2018 | Dishwashers
How do we put it through a test mode?
Here you go, both answers :>)
Bosch Dishwasher Troubleshooting Your Bosch dishwasher can run a test cycle which will quickly go through each stage of a wash programme in order to find out at what point a fault is occurring. It will only give you a general idea of where the problem lies but is a useful first step in diagnosing the issue.
The steps to start the test cycle vary depending on what model you have but the basic method is similar across the range. It might be that your dishwasher doesn't have the same button labelling as described in the steps below. In that case try holding down the buttons which have similar names. After a little trial and error you'll find the right combination.
  • Make sure the dishwasher is switched off.
  • Press and hold the Power Scrub Plus and Regular Wash buttons.
  • Turn on the dishwasher, then release the two buttons.
  • The light above each of these buttons should flash.
  • Start the test cycle by pressing the Power Scrub Plus and Regular Wash buttons again.
  • The test programme will begin and an error code will be displayed at the end of the cycle if a fault has been detected.
You can find a list of Bosch dishwasher error codes and their definitions here.
Error Codes are also here;
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/dishwasher-fault-codes/3058-bosch-sms-series-dishwasher-fault-codes.html
Sep 30, 2015 | Bosch Dishwashers
What is E1 error code
The E1 error code indicates a water inlet error. Do you still have your manual to test for this?
Jun 20, 2014 | Kenwood KDW243A Builtin Dishwasher
Hi, we have a Bosch SHU53EO6UC/14 dishwasher. It is getting stuck in wash and isn't advancing. We think it may be the timer but there are lots of references to running a test program. Unfortunately...
My Bosch DW SHU5302 also got stuck during a cycle and ran and ran. Turns out this is a known problem with these DW's. The problem is that a trace on the main board burns off that controls the heater. If the heater doesn't come on then the DW keeps running waiting for the water to heat up. Re-soldering this trace fixes this problem. If you get a repair guy out, he will only change the board. They are not allowed to re-solder which doesn't fix the problem for long as the same trace will burn off. Did this about 8 years ago and it is still fine.
Aug 29, 2011 | Bosch 24 in. SHU53 Built-in Dishwasher
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
Have a 2+year old LG LDF6810ST dishwasher that shows no error codes but is not cleaning like it used to. Have city water, do not leave excess food on dishes when loading, am only using powder after...
Try these things in order:
-Try to use a name brand powder, rather then a generic. Even a small box. I had similar problems with my LG dishwasher when I tried to save money by buying a generic powder. My dishes did not get clean and white marks were left behind on my stainless steel DW liner and the dishes. When you ad the powder, do not over fill the dispenser. Add less than the full dispenser cup and close it. Place some powder in that shallow square indent on the dispenser lid to help the pre-wash cycle. Also, run the water in the sink until hot water runs immediately before you start the DW.
-If, after using Electrosol or Cascade for 2 - 3 loads and your dishes do not come out clean, then I would run a load of dishes without adding the soap. Start the dishwasher and wait for it to fill and begin to wash. Open the door and add one cup of vinegar (white vinegar is fine.) Feel free to ad another cup after the first wash water drains and the second wash water enters and the DW begins the wash cycle again. Run a load of dirty dishes with the soap and check for good cleaning.
-If the problems continue, it is time to remove the filter assembly by removing the 9 silver phillips screws from the filter assembly. You will also need to remove the lower sprayer arm by pulling straight up and then out. With a flashlight, inspect the sump area that was hidden by the filter assembly, looking for any debris that has jammed into anywhere down there. Watch out for broken glass as you feel around. Reassemble and test with a load of dirty dishes.
The poor drying may be caused by not keeping the rinse aid re-filled. Check that first.
Also, these water and energy conserving dishwashers actually use the "dirt" from the dirty dishes to help clean the dishes during the first two wash cycles. Simply clear the big chunks off the dishes and put the dishes in the DW.
Please report back what you find or if you have more questions. OK?
Aug 12, 2009 | LG LDF6810ST Stainless Steel Built-in...
E1 Error code - no leaks - new pump - new pc board in Dec. 09
The most common reason for an E1 error on an LD dishwasher (that does not have a leak, including directly under the dishwasher) is the drain hose between the dishwasher and the drain does not have a rise in it between the DW and the drain. Either install a proper AirGar valve or attach the hose to the bottom of the counter top so that it raises 30" between the DW and the drain. When that raise does not exist, the laws of physics tell you that you WILL have a siphoning effect from the DW into the drain, causing the LG to report error code "E1", which is true because of the water leaving the DW during all the wash and drain cycles.
Good Luck!
Apr 03, 2009 | Dishwashers
What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
Feb 15, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
Smeg DWI614 Built-in Dishwasher Logo
204 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
