Question about Nokia E71 Smartphone
Doesn't charge I connected mine e71 from nokia to a 12 volts outlet SHAME ON ME instead of 5 volts. Now the e71 doesn't charge anymore. The phone is still working on the battery. Iám looking for an electronis schematic.
  • schippt May 31, 2009
    Today i fixed the no charging problem on my nokia e71.
    A safety fuse was blowned up. I replaced it and the phone is working verywel.
    I'am very happy now.
    Thanks to curtisg890 for the hint.
  • 48 Answers
You might have blown somthing oops and probs your phone might need replacing but you might have to pay for it
Posted on May 29, 2009
The nokia e71 smartphone does not charge properly i have replaced the battery with a new one yet the problem has not gone away. is there anything else i can do to fix this ?
This phone has a problem with a loose charging socket. With mine, if I hold the plug tightly into the socket it will charge. When I let go it stops charging. The inexpensive solution is to tie a 3 inch rubber band to the charging wire at the plug. When you need to charge, put the plug in the socket and stretch the rubber ban up around the top of the phone. This will keep the plug securely into the socket and it will charge.
Nov 10, 2012 | Nokia E71 Smartphone
How reset secury code in e71
First try this without powering on the phone How to Generate Your Phone Security code..Only for Nokia bb5 if not work try this How to Reset the forgot sim security in Nokia bb5 by using the Previous Sim Card instead of powering on the phone Press Power Button after connecting the USB.In case these two doesn't work visit mobile repairing shop.Good luck thanks for visiting fixya
Feb 23, 2012 | Nokia Cell Phones
I m not able to connect my BH 208 headset to nokia E71 set
Make sure that the headset is properly charged before following the instructions below.Please follow the detailed instructions in the correct manner to successfully pair your Nokia E71 with the BH-208 Headset.
Charge the battery
The headset has an internal, non removable, rechargeable battery.Do not attempt to remove the battery from the device, as you may damage the device.
1. Connect the charger to a wall outlet.
2. Connect the charger cable to the charger connector. The red indicator light is on while charging.
It may take a while before charging
Switch the headset on or off
To switch on, press and hold the power key until the headset beeps and the green indicator light is displayed. To switch off, press and hold the power key until the headset beeps and the red indicator light is displayed briefly.
Pairing the headset
1. Ensure that your phone is switched on and the headset is switched off.
2. Press and hold the power key until the green indicator light starts to flash quickly.
3. Activate the Bluetooth feature on the phone, and set the phone to search for Bluetooth devices.
4. Select the headset from the list of found devices.
5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones you may need to make the connection separately after pairing. You only need to pair the headset with your phone once.
If the pairing is successful, the headset beeps and appears in the phone menu where you can view the currently paired Bluetooth devices.The headset is now ready for use.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex.
Jun 14, 2011 | Nokia BH-208 Wireless Headset
I have replaced the batteries on my Gardenmate Dual Outlet Tap timer, and it is still not working. The system is only 12 months old, and I am unable to solve it. Can you please help me.
I reckon they're useless. New batteries still aren't powerful enough to drive the whirring gears of the timer inside (they only take AAA batteries).
I have the same problem as you, which has happenede on both timers I've bough...they usually give out after a month or so and nothing gets them going again,
Sadly a dreadful product, poor design and waste of money. Shame really as it could be so good to really "set and forget"
Feb 20, 2011 | Garden
Why is my Nokia E71 mobile phone not charging fully
Ok could be 3 things.
1.Go to your dealer and ask to try a new battery.
2.If that doesn`t help ask to try a different charger.
If the above 2 didn`t solve it , then its the phone.
At this stage if you are under warranty ask for your money back or another phone.
Hopeive helped a bit .
Dec 15, 2009 | Nokia E71 Smartphone
Camera: feature not supported
this is a common hardware issue with Nokia. sometimes it will start working again by itself.
there is nothing that can be done apart from taking the phone back to Nokia.
Sep 15, 2009 | Nokia E71 Smartphone
Which fuse controls the 12-volt outlets. I have
check the accessory fuse, might be labeled as a cigarette lighter or accessory.
Aug 24, 2009 | Subaru Outback Cars & Trucks
1996 Cavalier 12 Volt power outlet in car doesn't work right?
Even thought the plug in is 12 volt. It's ouput is different. Most electronics have different ranges from 3-9 volts.
Does the 12 volt charger put out 12 volts? If so, it would burn up the electronics' capacitors on their power supplies.
How is the car's electronics doing? Are they too failing? If so, that would be a faulty voltage regulator, if not, I would hook up anything you use to the radio wires.
You cannot plug in anything directly to battery no matter what the person told you. Batteries charge, than release charge, a contiuous cycle. The power output is speratic and anything hooked straight up to the battery will need a fuse.
Jun 08, 2009 | 1999 Chevrolet Cavalier
Nokia E71 Smartphone Logo
255 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
