Question about Sanyo Car Audio & Video
Wiring diagram Sanyo Model FXR-71LB car stereo
I need the wiring layout ie colour codes and what goes where power earth speakers etc
Cerfer39
  • 709 Answers
SOURCE: sony cdx-gt170
Hi MalJars,
Clarion normally uses the following colors for each channel.
Front Right Gray and Gray/Black -
Front Left White and white/black
Rear Right Purple and purple/black
Rear Left Green and Green / black
Yellow is memory backup Stays at 12 volts all the time
Red is Switched power and comes on only with Key on.
Posted on Nov 30, 2007
techman
  • 3130 Answers
SOURCE: 1998 ford el xr6, need stereo wiring harness colours
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+ White/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Blue/Black Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Light Blue/White Left Front (-) Orange/Light Green Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 6" x 8" Rear Doors Left Rear (+) Tan/Yellow Left Rear (-) Gray/Light Blue Right Rear (+) Brown/Pink Right Rear (-) Orange/Red
1998 Ford Explorer Stereo Wiring Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Door Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Posted on Feb 23, 2008
shaggyrat
  • 1224 Answers
SOURCE: car stereo wiring diagram
Main power wires
Yellow to constant always on power
red to accessories
black to ground
blue if you have an amp this will be remote wire if you dont have amp then just cap off
the other wires are as follows
top section speaker wires right and left
bottom section speaker wires right and left
the speaker wires come in colors like purple purple line
grey grey line
orange orange line
white white blueline
these are your speaker wires simple just remember power lines grounds
Posted on May 07, 2008
SOURCE: WIRING FOR PIONEER DEH 16 CAR STEREO
you need to find the Pioneer website, or something similer... google the DEH 1600 diagram. really you just need something that tells what the different wires represent by color. then find a wiring diagram for the make and model of your ride that cooresponds to your stereo set up... then just match up the wires and there you go... personally i suggest haveing one of the boys at Best buy throw a harness... it costs like 15 bucks or something. plus you know it will be done right, and you can take it back if its not and have it fixed... bottom line they will be liable for any problems... hope this helps.
Posted on May 26, 2008
SOURCE: Car stereo wiring color codes for Proton Satria
want to know wiring colour codecs standard
Posted on Apr 02, 2009
I need a radio wiring diagram for a Holden Commodore LS 1991
Regardless of colour coding, please follow the following instructions (require multimeter):
Note: Attach multimeter earth wire (black) to the vehicle body. Convenient places may be the metal ignition barrel, the vehicle's car arial plug, cigarette socket body etc.
1) Testing for voltage with key out of the ignition, locate the permanent positive wire. This will wire into the yellow wire on your new stereo. The yellow wire circuit powers the stereo's memory.
2) Testing for voltage again. This time you are testing for a wire which only offers power with the ignition turned on. This one will wire into the red wire on your new stereo, and will power the unit only with the ignition on.
3) Now you know which your vehicle's positive wires are you can now test for an earth wire. Switch the multimeter to the resistance setting. There is one setting which will allow a buzzer to sound once you find continuity. With the ignition off test each wire until you get a buzz and a low resistance reading. This should be your earth wire. Double check this with the ignition in the on position. It should remain the same. If it changes to a positive with the ignition on and with the vehicle's lights switched on, then this is the dimmer feed for the stereo's screen. If you unintentionally found the dimmer feed, then you can ignore this wire, and search again for a wire which only offers an earth.
Now you have your power and earth wires located and can wire these into your stereo before continuing.
4) Next you need to use the stereo's balance and fade controls to allow only one speaker output to work from the stereo. So let's start with Left Front speaker output only. turn the stereo volume to mid way so that you can hear when you have connected to the right speaker. bare the remaining wires on the car side and test combinations of the remaining wires until you find the front left speaker of the car. Wire your stereo's wires once you find the correct connections.
5) Repeat the above steps with all remaining wires, remembering to adjust your stereo's balance and fade controls to only allow one speaker output at a time, to ensure the only one possible channel to work and help you identify which of the car's wires power the speaker you have selected.
Before re-assembly of the dash panel, check that your stereo and all functions work properly, being sure to use your fade and balance controls again to test all speakers individually.
If you want to be extra careful and wire the vehicle's speakers positive and negative, according to your stereo's outputs, not that this makes much difference on standard stereo arrangements, then follow this next step:
Make sure you can see the speakers themselves and connect a 1.5 volt AA or AAA battery to the speaker wires. If the speaker's cone pushes forwards, then the wire you connected to the battery's + terminal is indeed the positive wire and should be wired as such. If the speaker does the reverse, then you have the wires the wrong way around. Do not repeat this test for extended periods as damage may be caused to the speaker circuit.
Tip: Always solder all connections and insulate well from each other. Stereo connections can corrode over time and are prone to movement behind the dash. Poor connections may cause faults and low quality sound.
Oct 30, 2012 | Cars & Trucks
Changing the factory stereo need the color coded wiring diagram
you can buy,well we can,adaptor plugs to connect to the h/unit and to the wiring loom plug.normally its yellow=constant power 12v +,red=ignition feed 12v+,[some are other way round]black=earth,blue=power antennae,grey/greyblack,RF speaker,white/whiteblack,LH speaker,Purple/purple black,RR speaker andgreen/green black LR,,orange =illumination dash lights.Those are our standard colour codings,we get in New Zealand.
Jul 01, 2010 | 2001 Ford Mustang
I need a circuit diagram for a 2000 Hyundai accent sterio plug. ie colours for speaker wires, power, ign, dash lights etc.
speaker wires you can connect one at a time to see which is which as for the others black is earth, red is usually ignition, yellow is constant power (memory) and sometimes you'll have a blue wire for power out or you can usually just buy an adaptor plug to suit most stereos
May 18, 2010 | 2000 Hyundai Accent
Looking for wiring diagram for 1988 escort 1.8 tdi. need to fit cd/radio existing wiribng just on chp block..
you need a volt meter and 9v battery. earth black contact from meter & then
  1. with ign off probe wire to find a live , thats the memory feed goes to yellow on radio
  2. with ign on probe wires that the constent live goes to red on radio
  3. when lights on probe wires thats the illumination feed (if fitted to car, but not used on many new radios
  4. then get 9v battery and with remaining wires pair and connect to battery, when speaker buzz's mark pair as they are ( ie front right rear left etc ) the speaker wires from the new radio are paired by colour ( one with black stripe with is the negative of the pair)
  5. there should be a ground/earth which if you cant find just hook one to the body/chassis
Jan 03, 2010 | Car Audio & Video
Wiring diapgram and color code for clarion drx6475
hey hey,
Dont have a diagram but if you wanna know the colours they are
Red - Accessory Power
Yellow - Battery+
Black - Ground/Chassis
Orange/White - Illumination
Blue - Power Antenna
Blue/White - Amp remote wire
Brown - Celluar phone mute lead
Speakers:
Front Right - +Grey -Grey/Black
Frount Left - +White -White/Black
Rear Right - +Purple -Purple/Black
Rear Left - +Green -Green/Black
Hope this helps you out
Kind Regards
Brad
Jan 01, 2010 | Clarion DRX6475
PEUGEOT 306 L REG 14.0 XL WIRING TO FIT A STEREO AS PREVIOUS OWNER HAS CHOPPED & CHANGED THE CONNECTORS & WIRING I HAVE THE COLOURS INDICATED ON A STICKER FOR THE STEREO IM TRYINYG TO FIT ON A
need to no what colours cables u have would be easy to talk u through it on the phone.but here we go anyway red is power and yellow is constant power (for memorey ie radio stations )back is earth. blue is remote for an amp to turn it on vier the head unit.and all the rest are speaker cables ie two greens two purple two black and two grey colour.but your peugeot electrial harness mite be different colours though thats why its better to talk on the phone about it let me no an illl let u have me number hope this helps.
May 22, 2009 | Kenwood Car Audio & Video
Request for the wiring diagram for a 1989 UK spec Toyota Corolla Hatchback
Sure. Glad to provide assistance.
89 Corolla radio wiring colours:
Power- Solid GREY -
from the 7.5 amp RADIO fuse
Backup power - BLUE w/YELLOW tracer
from the 10 amp DOME fuse
RF speaker - LIGHT GREEN and BLUE
LF speaker - PINK and VIOLET
RR speaker - RED and WHITE
LR speaker - BLACK and YELLOW
Ground/Earth - BROWN
The graciousness of a FixYa rating would be greatly appreciated.
Jan 19, 2009 | 1989 Toyota Corolla 2 Door
Wiring colour code
what is your email i will email you the diagram
Mark
Jul 18, 2008 | Pioneer CDX-P670 6-Disc CD Changer
Stereo wiring
test all gronds and powers then the remaining cables use a AA batterie and conect one cable on each end on the baterie like on of on of like toching at times and that will make the speakers to sound for a little then you will identify every speaker then read the diagram on the radio and plug it in acording to the radio diagram
Jun 01, 2008 | 1993 Nissan NX
Feb 22, 2008 | Car Audio & Video
Car Audio & Video Logo
536 people viewed this question
Top Sanyo Car Audio & Video Experts
Colin Stickland
Colin Stickland
xxxxxx xxx
Are you a Sanyo Car Audio and Video Expert? Answer questions, earn points and help others
