Question about Dometic Rooftop RV Air Conditioner
Ac running but no air is coming in - Dometic Rooftop RV Air Conditioner
  • 122 Answers
Check your furnace fan. The air conditioner unit can be running but the air circulation is usually done with the fan on the furnace. If you have a fan switch on the thermostat, check to see if it is in the auto position. If it has the settings on/auto/off, you can switch it to the on position and see if you get any air movement then. If not, you could have a broken belt.
Posted on May 29, 2009
RV. when furnace is turned on , fan on rooftop AC unit runs continually
i would say its the relay board or communication cabl between stat and board.
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
1995 Oldsmobile 88 Royale - AC Issues
So the ac is not working. Is the compressor running when you have the control set for ac ?
Jun 27, 2013 | Oldsmobile Eighty Cars & Trucks
Ac was running when driving to the store, stopped to gas car then on the way out turned on ac no air coming out and the ac light does not turn on. i checked the fuses all are working but no power running...
Most likely the AC compressor clutch isn't engaged. This happens when the refrigerant pressure switch doesn't detect pressure in the coolant lines. The cause is usually a refrigerant leak.
This way the AC compressor is protected from running dry and possible damage.
Let your local repairshop check AC line pressure - if no pressure, look for the leak first then refill with fresh refrigerant.
Jul 01, 2011 | 2006 Scion xB
I have my dometic Rooftop ac unit. The heatstrip/fan run perfectly but when I turn on the ac...the fan runs good but when the compressor kicks on it just hums.
The compressor coming on does make a slight "humming" sound which is normal. Is the unit cooling properly? Do you think it is louder than before?
May 09, 2010 | Dometic Rooftop RV Air Conditioner
1990 model RUUD AC unit. Fan runs, no cooling
Is the outside unit running? Fan and compressor?
Jun 29, 2009 | Heating & Cooling
Freezing up, home ac unit no air flow after running a while
A low freon level in the unit can cause them to freeze up. Are the fins behind the filter clean?
Jun 19, 2009 | Whirlwind FH-778 Air Conditioner
Compressor will not stay on
do you know if the fans are running constantly? and if so when the compressor comes on it trips out and the fan remains constant? i would like to know the running amps are they correct.
Jun 08, 2009 | Heating & Cooling
Keeps tripping breaker when running ac
you need to check that the breaker it rated high enough for the ac unit
Jun 04, 2009 | Dometic Rooftop RV Air Conditioner
AC working but no air coming in the house
Unit iced up or bad fan or fan relay. Goodmans have time delay fan relay and they go out often.
May 29, 2009 | Goodman CLJ30AR32 Air Conditioner
AC STOPPED BLOWING COLD; ONLY BLOWS ON MAX MANUAL SETTING
Your AC is low on refrigerant; The AC compressor needs a minimum amount of regrigerant to run. If and when it does run (while low on refrigerant) the air coming out of the vents will not be cold. The refrigerant you require is R-134A and is available over the counter but if you are the least bit unsure as to how to add refrigerant, taking it to a garage that does AC recharging would be your best play. If you want to try to add refrigerant on your own you will need the following, 1LB can of R-134A, an AC hose adapter to deliver the refrigerant, and preferably an AC pressure guage to ensure you are not overfilling the AC line which will damage the system.
May 10, 2009 | 2004 Honda Odyssey
Dometic Rooftop RV Air Conditioner Logo
137 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
